Alright, this is my teensy ++2.0 code, i have the same problem on my teensy 3.2 on pin 13.
Pin6 on the ++2, and pin13 on the T3.2, have the same problems.
They have LEDs on them, and when i use this code, they don't trigger.
These are all common Ground buttons, and i need to keep them common ground, so i can't have P6/P13 as a normal input. it has to have the internal pullup.
This code as is, has pin37 also shared to joystick button 7
Any way to fix this without physically removing the LED? Is there something that i'm simply missing?
What ever fix you can come up with, i'd like for it to work for the Teensy 3.2 as well. Thank you.
//Teensy++2.0
#include <Bounce.h>
// Create Bounce objects for each button. The Bounce object
// automatically deals with contact chatter or "bounce", and
// it makes detecting changes very simple.
Bounce button0 = Bounce(0, 10);
Bounce button1 = Bounce(1, 10); // 10 = 10 ms debounce time
Bounce button2 = Bounce(2, 10); // which is appropriate for
Bounce button3 = Bounce(3, 10); // most mechanical pushbuttons
Bounce button4 = Bounce(4, 10);
Bounce button5 = Bounce(5, 10);
Bounce button6 = Bounce(6, 10);
Bounce button7 = Bounce(7, 10);
Bounce button8 = Bounce(8, 10);
Bounce button9 = Bounce(9, 10);
Bounce button10 = Bounce(10, 10);
Bounce button11 = Bounce(11, 10); // 10 = 10 ms debounce time
Bounce button12 = Bounce(12, 10); // which is appropriate for
Bounce button13 = Bounce(13, 10); // most mechanical pushbuttons
Bounce button14 = Bounce(14, 10);
Bounce button15 = Bounce(15, 10);
Bounce button16 = Bounce(16, 10);
Bounce button17 = Bounce(17, 10);
Bounce button18 = Bounce(18, 10);
Bounce button19 = Bounce(19, 10);
Bounce button20 = Bounce(20, 10);
Bounce button21 = Bounce(21, 10);
Bounce button22 = Bounce(22, 10);
Bounce button23 = Bounce(23, 10);
Bounce button24 = Bounce(24, 10);
Bounce button25 = Bounce(25, 10);
Bounce button26 = Bounce(26, 10);
Bounce button27 = Bounce(27, 10);
Bounce button28 = Bounce(28, 10);
Bounce button29 = Bounce(29, 10);
Bounce button30 = Bounce(30, 10);
Bounce button31 = Bounce(31, 10);
Bounce button32 = Bounce(32, 10);
Bounce button33 = Bounce(33, 10);
Bounce button34 = Bounce(34, 10);
Bounce button35 = Bounce(35, 10);
Bounce button36 = Bounce(36, 10);
Bounce button37 = Bounce(37, 10);
pinMode(0, INPUT_PULLUP);
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
pinMode(10, INPUT_PULLUP);
pinMode(11, INPUT_PULLUP);
pinMode(12, INPUT_PULLUP);
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
pinMode(15, INPUT_PULLUP);
pinMode(16, INPUT_PULLUP);
pinMode(17, INPUT_PULLUP);
pinMode(18, INPUT_PULLUP);
pinMode(19, INPUT_PULLUP);
pinMode(20, INPUT_PULLUP);
pinMode(21, INPUT_PULLUP);
pinMode(22, INPUT_PULLUP);
pinMode(23, INPUT_PULLUP);
pinMode(24, INPUT_PULLUP);
pinMode(25, INPUT_PULLUP);
pinMode(26, INPUT_PULLUP);
pinMode(27, INPUT_PULLUP);
pinMode(28, INPUT_PULLUP);
pinMode(29, INPUT_PULLUP);
pinMode(30, INPUT_PULLUP);
pinMode(31, INPUT_PULLUP);
pinMode(32, INPUT_PULLUP);
pinMode(33, INPUT_PULLUP);
pinMode(34, INPUT_PULLUP);
pinMode(35, INPUT_PULLUP);
pinMode(36, INPUT_PULLUP);
pinMode(37, INPUT_PULLUP);
// read analog inputs and set X-Y position
Joystick.X(analogRead(A0));
Joystick.Y(1023 - analogRead(A1));
Joystick.Z(analogRead(A2));
//Joystick.Xrotate(analogRead(A3)); //commenting these out so other people can use this.
//Joystick.Yrotate(analogRead(A4));
Joystick.Zrotate(analogRead(A5));
Joystick.sliderLeft(analogRead(A6));
Joystick.sliderRight(analogRead(A7));
// Update all the buttons. There should not be any long
// delays in loop(), so this runs repetitively at a rate
// faster than the buttons could be pressed and released.
button0.update();
button1.update();
button2.update();
button3.update();
button4.update();
button5.update();
button6.update();
button7.update();
button8.update();
button9.update();
button10.update();
button11.update();
button12.update();
button13.update();
button14.update();
button15.update();
button16.update();
button17.update();
button18.update();
button19.update();
button20.update();
button21.update();
button22.update();
button23.update();
button24.update();
button25.update();
button26.update();
button27.update();
button28.update();
button29.update();
button30.update();
button31.update();
button32.update();
button33.update();
button34.update();
button35.update();
button36.update();
button37.update();
// Check each button for "falling" edge.
// Update the Joystick buttons only upon changes.
// falling = high (not pressed - voltage from pullup resistor)
// to low (pressed - button connects pin to ground)
if (button0.fallingEdge()) {
Joystick.button(1, 1);
if (button1.fallingEdge()) {
Joystick.button(2, 1);
if (button2.fallingEdge()) {
Joystick.button(3, 1);
if (button3.fallingEdge()) {
Joystick.button(4, 1);
if (button4.fallingEdge()) {
Joystick.button(5, 1);
if (button5.fallingEdge()) {
Joystick.button(6, 1);
if (button6.fallingEdge()) {
Joystick.button(7, 1);
if (button7.fallingEdge()) {
Joystick.button(8, 1);
if (button8.fallingEdge()) {
Joystick.button(9, 1);
if (button9.fallingEdge()) {
Joystick.button(10, 1);
if (button10.fallingEdge()) {
Joystick.button(11, 1);
if (button11.fallingEdge()) {
Joystick.button(12, 1);
if (button12.fallingEdge()) {
Joystick.button(13, 1);
if (button13.fallingEdge()) {
Joystick.button(14, 1);
if (button14.fallingEdge()) {
Joystick.button(15, 1);
if (button15.fallingEdge()) {
Joystick.button(16, 1);
if (button16.fallingEdge()) {
Joystick.button(17, 1);
if (button17.fallingEdge()) {
Joystick.button(18, 1);
if (button18.fallingEdge()) {
Joystick.button(19, 1);
if (button19.fallingEdge()) {
Joystick.button(20, 1);
if (button20.fallingEdge()) {
Joystick.button(21, 1);
if (button21.fallingEdge()) {
Joystick.button(22, 1);
if (button22.fallingEdge()) {
Joystick.button(23, 1);
if (button23.fallingEdge()) {
Joystick.button(24, 1);
if (button24.fallingEdge()) {
Joystick.button(25, 1);
if (button25.fallingEdge()) {
Joystick.button(26, 1);
if (button26.fallingEdge()) {
Joystick.button(27, 1);
if (button27.fallingEdge()) {
Joystick.button(28, 1);
if (button28.fallingEdge()) {
Joystick.button(29, 1);
if (button29.fallingEdge()) {
Joystick.button(30, 1);
if (button30.fallingEdge()) {
Joystick.button(31, 1);
if (button31.fallingEdge()) {
Joystick.button(32, 1);
if (button32.fallingEdge()) {
Keyboard.press(KEY_1);
if (button33.fallingEdge()) {
Keyboard.press(KEY_2);
if (button34.fallingEdge()) {
Keyboard.press(KEY_3);
if (button35.fallingEdge()) {
Keyboard.press(KEY_4);
if (button36.fallingEdge()) {
Keyboard.press(KEY_5);
if (button37.fallingEdge()) {
// Check each button for "rising" edge
// rising = low (pressed - button connects pin to ground)
// to high (not pressed - voltage from pullup resistor)
if (button0.risingEdge()) {
Joystick.button(1, 0);
if (button1.risingEdge()) {
Joystick.button(2, 0);
if (button2.risingEdge()) {
Joystick.button(3, 0);
if (button3.risingEdge()) {
Joystick.button(4, 0);
if (button4.risingEdge()) {
Joystick.button(5, 0);
if (button5.risingEdge()) {
Joystick.button(6, 0);
if (button6.risingEdge()) {
Joystick.button(7, 0);
if (button7.risingEdge()) {
Joystick.button(8, 0);
if (button8.risingEdge()) {
Joystick.button(9, 0);
if (button9.risingEdge()) {
Joystick.button(10, 0);
if (button10.risingEdge()) {
Joystick.button(11, 0);
if (button11.risingEdge()) {
Joystick.button(12, 0);
if (button12.risingEdge()) {
Joystick.button(13, 0);
if (button13.risingEdge()) {
Joystick.button(14, 0);
if (button14.risingEdge()) {
Joystick.button(15, 0);
if (button15.risingEdge()) {
Joystick.button(16, 0);
if (button16.risingEdge()) {
Joystick.button(17, 0);
if (button17.risingEdge()) {
Joystick.button(18, 0);
if (button18.risingEdge()) {
Joystick.button(19, 0);
if (button19.risingEdge()) {
Joystick.button(20, 0);
if (button20.risingEdge()) {
Joystick.button(21, 0);
if (button21.risingEdge()) {
Joystick.button(22, 0);
if (button22.risingEdge()) {
Joystick.button(23, 0);
if (button23.risingEdge()) {
Joystick.button(24, 0);
if (button24.risingEdge()) {
Joystick.button(25, 0);
if (button25.risingEdge()) {
Joystick.button(26, 0);
if (button26.risingEdge()) {
Joystick.button(27, 0);
if (button27.risingEdge()) {
Joystick.button(28, 0);
if (button28.risingEdge()) {
Joystick.button(29, 0);
if (button29.risingEdge()) {
Joystick.button(30, 0);
if (button30.risingEdge()) {
Joystick.button(31, 0);
if (button31.risingEdge()) {
Joystick.button(32, 0);
if (button32.risingEdge()) {
Keyboard.release(KEY_1);
if (button33.risingEdge()) {
Keyboard.release(KEY_2);
if (button34.risingEdge()) {
Keyboard.release(KEY_3);
if (button35.risingEdge()) {
Keyboard.release(KEY_4);
if (button36.risingEdge()) {
Keyboard.release(KEY_5);
if (button37.risingEdge()) {
