View Full Version : fft doesn't run fft.available() always returns 0
dimivb01
03-08-2016, 07:27 AM
Hi guys,
I m trying a simple project with Teensy 3.1. I want to read and adc input and perform an fft on it. For troubleshooting I cutout all the irrelevant code and I am left with this.
The problem is that myFFT.available() call always returns a 0.
I have an adafruit electret microphone I am powering from the teensy 3.3Vout. I can disconnect it - no difference. I know the code runs since the LED blinks and I do get some output on the serial monitor.
#include <SerialFlash.h>
AudioInputAnalog adc1;
AudioAnalyzeFFT1024 myFFT;
AudioConnection patchCord1(adc1, 0, myFFT, 0);
float level[16];
AudioMemory(12);
pinMode(10, OUTPUT);
// Configure the window algorithm to use
myFFT.windowFunction(AudioWindowHanning1024);
Serial.println("start: ");
digitalWriteFast(10, !digitalReadFast(10));
Serial.println(myFFT.available());
level[1] = myFFT.read(1);
Serial.println(level[1]);
Serial.print(" cpu:");
Serial.println(AudioProcessorUsageMax());
// delay(1000);
Any thoughts on why I keep getting myFFT.available() always = 0?
Thanks
Theremingenieur
03-08-2016, 07:36 AM
The question is if the signal of the electret microphone is strong enough... You could check that with your oscilloscope or by connecting the DAC output directly to the ADC input as a kind of "monitor" function. Or you take your function generator and feed a 400Hz 1Vpp sine wave into the ADC.
WMXZ
03-08-2016, 07:40 AM
Are you sure the put the actual code here ?
Teensy3.1 LED is on pin 13 and not Pin10.
please give a functioning code that demonstrates the problem
PaulStoffregen
03-08-2016, 07:47 AM
Make sure you have the CPU speed set to 96 MHz.
dimivb01
03-08-2016, 08:19 AM
Thanks Paul. It seems the clock speed was the problem. I set it to 96MHz and now I can read values. YAY!
