Stacking display...
jassing
I have the audio board, franks memory board, and of course a teensy3 which I plan to stack...
My question is, is the information on the touch-screen product page under "Usage With Audio Board Connections" still correct for also using the touch screen & purple adapter board?
The purple adapter board hard wires conflicting pins (to audio board) when the Teensy is mounted!
To me the edits were:
MOSI(dout) moves from #11 to #7 and SCK moves from #13 to #14
I looked at that last year hoping I could cut and solder two traces and I failed on the solder part to jumper passing pins - looked easy!
Perhaps if those pins don't go through to the Teensy and then you can wire (jumpers) to the proper pins.
Thanks! I have another (virgin) teensy32; so I can solder header pins on and leave those two off, and wire them manually.
So I should stack the board like this:
Audio Board
Memory board
Teensy board
Video board (with wires for 2 pins)
Am I correct in that it doesn't matter if that's reversed?
Thanks!
