Hi Paul (and other Teensy experts)
Last I checked in the Audio API documentation in the Design tool. The PWM output only works with a carrier frequency of 88.2 kHz. I am using PWM modulation to control motors and, as such, most motor control drivers don't work at anything over 20kHz. Wondering if there is a way to make this PWM function work on 20kHz? Also, would be great if it would work on more than one pin (or if it could be documented more clearly that this only works on the pins in the design tool diagram)??
Thoughts?
Thanks,
Cere
Thoughts?
Thanks,
Cere
