Hi there.
I've just switched from an UNO R3 to a Teensy 3.2 as I needed the extra analogue capabilities. Upon changing everything over, my ITG-3200 is not getting the same readings that it was getting with the UNO. With the UNO the ADC values were being converted to degrees per second just fine but now with the Teensy I'm getting deg/s in the range of -3000 to 3000 even though the sensor isn't rotating that fast.
I have 4K7 resistors on the I2C lines. I'm using a scale factor of 14.375 for conversion.
Many thanks.
View attachment Gyroscope.cpp
View attachment Gyroscope.h
View attachment crashSensorV3.ino
Many thanks.
