Unable to access SD card
Hutchcmu
Was getting the error "unable to access the SD card" while trying to run CopyFromSD (trying to move raw audio files to serial flash). In an effort to figure out the issue, tried running the SdCardTest example but now have the following error and not sure where and how to declare "reportSpeed". Any help would be appreciated. Thanks!
Arduino: 1.6.7 (Windows Vista), TD: 1.27, Board: "Teensy 3.2 / 3.1, Serial, 96 MHz optimized (overclock), US English"
C:\Users\Mike\AppData\Local\Temp\arduino_ac665003c84b6f181bf227622b16a46f\SdCardTest.ino: In function 'void setup()':
SdCardTest:102: error: 'reportSpeed' was not declared in this scope
reportSpeed(1, 1000, usecTotal, usecMax);
SdCardTest:126: error: 'reportSpeed' was not declared in this scope
reportSpeed(2, 1000, usecTotal, usecMax);
SdCardTest:169: error: 'reportSpeed' was not declared in this scope
reportSpeed(3, 1000, usecTotal, usecMax);
SdCardTest:218: error: 'reportSpeed' was not declared in this scope
reportSpeed(4, 1000, usecTotal, usecMax);
exit status 1
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
// SD Card Test
// Check if the SD card on the Audio Shield is working,
// and perform some simple speed measurements to gauge
// its ability to play 1, 2, 3 and 4 WAV files at a time.
// Requires the audio shield:
//   http://www.pjrc.com/store/teensy3_audio.html
// Data files to put on your SD card can be downloaded here:
//   http://www.pjrc.com/teensy/td_libs_AudioDataFiles.html
// This example code is in the public domain.
  Sd2Card card;
  SdVolume volume;
  File f1, f2, f3, f4;
  char buffer[512];
  boolean status;
  unsigned long usec, usecMax;
  elapsedMicros usecTotal, usecSingle;
  int i, type;
  float size;
  // wait for the Arduino Serial Monitor to open
  while (!Serial) ;
  delay(50);
  // Configure SPI for the audio shield pins
  SPI.setMOSI(7);  // Audio shield has MOSI on pin 7
  SPI.setSCK(14);  // Audio shield has SCK on pin 14
  Serial.println("SD Card Test");
  Serial.println("------------");
  // First, detect the card
  status = card.init(10); // Audio shield has SD card SD on pin 10
  if (status) {
    Serial.println("SD card is connected :-)");
    Serial.println("SD card is not connected or unusable :-(");
    return;
  type = card.type();
  if (type == SD_CARD_TYPE_SD1 || type == SD_CARD_TYPE_SD2) {
    Serial.println("Card type is SD");
  } else if (type == SD_CARD_TYPE_SDHC) {
    Serial.println("Card type is SDHC");
    Serial.println("Card is an unknown type (maybe SDXC?)");
  // Then look at the file system and print its capacity
  status = volume.init(card);
  if (!status) {
    Serial.println("Unable to access the filesystem on this card. :-(");
    return;
  size = volume.blocksPerCluster() * volume.clusterCount();
  size = size * (512.0 / 1e6); // convert blocks to millions of bytes
  Serial.print("File system space is ");
  Serial.print(size);
  Serial.println(" Mbytes.");
  // Now open the SD card normally
  status = SD.begin(10); // Audio shield has SD card CS on pin 10
  if (status) {
    Serial.println("SD library is able to access the filesystem");
    Serial.println("SD library can not access the filesystem!");
    Serial.println("Please report this problem, with the make & model of your SD card.");
    Serial.println("  http://forum.pjrc.com/forums/4-Suggestions-amp-Bug-Reports");
  // Open the 4 sample files.  Hopefully they're on the card
  f1 = SD.open("SDTEST1.WAV");
  f2 = SD.open("SDTEST2.WAV");
  f3 = SD.open("SDTEST3.WAV");
  f4 = SD.open("SDTEST4.WAV");
  // Speed test reading a single file
  if (f1) {
    Serial.println("Reading SDTEST1.WAV:");
    if (f1.size() >= 514048) {
      usecMax = 0;
      usecTotal = 0;
      for (i=0; i < 1000; i++) {
        usecSingle = 0;
        f1.read(buffer, 512);
        usec = usecSingle;
        if (usec > usecMax) usecMax = usec;
      Serial.println("SDTEST1.WAV is too small for speed testing");
    Serial.println("Unable to find SDTEST1.WAV on this card");
    return;
  // Speed test reading two files
  if (f2) {
    Serial.println("Reading SDTEST1.WAV & SDTEST2.WAV:");
    if (f2.size() >= 514048) {
      f1.seek(0);
      usecMax = 0;
      usecTotal = 0;
        usecSingle = 0;
        f2.read(buffer, 512);
        usec = usecSingle;
      Serial.println("Reading SDTEST1.WAV & SDTEST2.WAV staggered:");
      f1.seek(0);
      f2.seek(0);
      usecMax = 0;
      usecTotal = 0;
        usecSingle = 0;
        usec = usecSingle;
      Serial.println("SDTEST2.WAV is too small for speed testing");
    Serial.println("Unable to find SDTEST2.WAV on this card");
    return;
  // Speed test reading three files
  if (f3) {
    Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV:");
    if (f3.size() >= 514048) {
      f1.seek(0);
      f2.seek(0);
      usecMax = 0;
      usecTotal = 0;
        usecSingle = 0;
        f3.read(buffer, 512);
        usec = usecSingle;
      Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV staggered:");
      f1.seek(0);
      f2.seek(0);
      f3.seek(0);
      usecMax = 0;
      usecTotal = 0;
        usecSingle = 0;
        usec = usecSingle;
      Serial.println("SDTEST3.WAV is too small for speed testing");
    Serial.println("Unable to find SDTEST3.WAV on this card");
    return;
  // Speed test reading four files
  if (f4) {
    Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV, SDTEST4.WAV:");
    if (f4.size() >= 514048) {
      f1.seek(0);
      f2.seek(0);
      f3.seek(0);
      usecMax = 0;
      usecTotal = 0;
        usecSingle = 0;
        f4.read(buffer, 512);
        usec = usecSingle;
      Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV, SDTEST4.WAV staggered:");
      f1.seek(0);
      f2.seek(0);
      f3.seek(0);
      f4.seek(0);
      usecMax = 0;
      usecTotal = 0;
        usecSingle = 0;
        usec = usecSingle;
      Serial.println("SDTEST4.WAV is too small for speed testing");
    Serial.println("Unable to find SDTEST4.WAV on this card");
    return;
unsigned long maximum(unsigned long a, unsigned long b,
  unsigned long c, unsigned long d)
  if (b > a) a = b;
  if (c > a) a = c;
  if (d > a) a = d;
  return a;
void reportSpeed(unsigned int numFiles, unsigned long blockCount,
  unsigned long usecTotal, unsigned long usecMax)
  float bytesPerSecond = (float)(blockCount * 512 * numFiles) / usecTotal;
  Serial.print("  Overall speed = ");
  Serial.print(bytesPerSecond);
  Serial.println(" Mbyte/sec");
  Serial.print("  Worst block time = ");
  Serial.print((float)usecMax / 1000.0);
  Serial.println(" ms");
  Serial.print("    ");
  Serial.print( (float)usecMax / 29.01333);
  Serial.println("% of audio frame time");
void loop(void) {
  // do nothing after the test
Make a function prototype that is placed before the code where it is called - or in an included header file. Arduino tries to hide that when it can - but it is how C works.
[B]void reportSpeed(unsigned int numFiles, unsigned long blockCount,  unsigned long usecTotal, unsigned long usecMax);[/B]
setup() {
void reportSpeed(unsigned int numFiles, unsigned long blockCount,  unsigned long usecTotal, unsigned long usecMax) {
Thanks for the help. I completely missed the function at the end of the code. Wouldn't everyone have this problem when running this example? Just a newbie trying to learn as I go...
