Hi. I'm programming a LFO with Teensy 3.2. At the beginning I didn't use the audio library, just the analogWrite() function. When the program is stopped, the output should be 0v, I managed to do this by writing analogWrite(A14, 0); .
But now for simplicity I started using the audio library, and when the amplitude is 0, the output is at 1.7v~. The thing is I don't need that offset, the output voltage will be unipolar, so no need to move the 0 to 1.7v. So, how can I make the output go to 0v when the amplitude is 0, is there any line I can modify in the library? Thanks
edit: Oh, I saw the output range is 1.2v, mine is 3.3v, that's ok, maybe I modified the lib and I don't remember heh. Just to avoid confusion
