Hi guys, this a is a bit of an odd one so I'll start by explaining what I'm doing.
I'm using some TLC5955 chips to drive LEDs. These have 16bit colour depth but my data is only 8bits.
So simple enough I transmit one byte of my data then one byte of 0x00 padding, like so:
Now that's great and all but I'm now trying to use DMA to reduce my CPU load and up the speed. I can quite easily pad my data with 0x00 every other byte, which works as you would expect. However, this takes up a lot more memory then I would like.
So I decided to attempt to use a second DMA channel triggered after every write to transmit the 0x00s. Here's what I have so far:
Now the issue I think I'm having is that 'dmachannel2' is trying to fill the SPI0_PUSHR buffer with 0x00 before it is ready, which is usually marked by the DMA request on DMAMUX_SOURCE_SPI0_TX.
Can anyone give me any pointers as to a possible solution?
I was potentially thinking to use one DMA channel and use it's modulo register to send the same data twice everytime. This would also be acceptable
I believe the SPI buffer is 16 bits as well so I could DMA data to a temporary buffer like so:
Neither of these solutions seem elegant though
0 0 1 0 2 0 3 0 4 0 5 0 6 0 7 0 8 0 9 0 A 0 B 0 C 0 D 0 E 0 F 0 10 0 11 0 12 0 13 0 14 0 15 0 16 0 17 0 18 0 19 0 1A 0 1B 0 1C 0 1D 0 1E 0 1F 0 20 0 21 0 22 0 23 0 24 0 25 0 26 0 27 0 28 0 29 0 2A 0 2B 0 2C 0 2D 0 2E 0 2F 0
uint8_t dmaData[48];
uint8_t emptyBuffer = 0x00;
dmachannel1.destination((volatile uint8_t&)SPI0_PUSHR);
dmachannel1.sourceBuffer(dmaData, 48);
dmachannel1.disableOnCompletion();
dmachannel1.triggerAtHardwareEvent(DMAMUX_SOURCE_SPI0_TX);
dmachannel2.destination((volatile uint8_t&)SPI0_PUSHR);
dmachannel2.source(emptyBuffer);
dmachannel2.triggerAtTransfersOf(dmachannel1);
dmachannel2.triggerAtCompletionOf(dmachannel1);
dmachannel2.enable();
dmachannel1.enable(); // Begin transfer
uint16_t tempBuffer = 0x0000
DMA transfer of 8bits to tempBuffer
tempBuffer now = 0xFF00
DMA tempBuffer to SPI 16 bit buffer
