Hi!
This is my first Teensy program, and, though I can't yet test it on my Teensy (a component from my setup broke, and the replacement is still shipping), I'm sure I'm doing something obviously wrong, and I have a few questions.
I want to take two audio signals (one from each ADC), low-pass filter them, scale them so that they're of equal amplitude, then invert one and add it to the other. By going through and writing every bin-value below a threshold to zero, I was hoping this would allow me to "cancel" the noise in one signal with the inverted noise from the other (a control).
For one, how do I determine how much audio memory to allocate? Also, does this "scaling" I'm doing work as scaling, or does it simply mess up the data? What sort of other errors jump out as obvious to experienced programmers?
Thanks so much!
Thanks so much!
#include <SerialFlash.h>
AudioInputAnalog adc1; //xy=82,93
AudioInputAnalog adc2; //xy=82,143
AudioAnalyzePeak peak1; //xy=243,26
AudioFilterStateVariable filter1; //xy=249,97
AudioFilterStateVariable filter2; //xy=250,163
AudioAnalyzePeak peak2; //xy=252,230
AudioAnalyzeFFT1024 fft1024_1; //xy=433,86
AudioAnalyzeFFT1024 fft1024_2; //xy=437,167
AudioConnection patchCord1(adc1, peak1);
AudioConnection patchCord2(adc1, 0, filter1, 0);
AudioConnection patchCord3(adc2, peak2);
AudioConnection patchCord4(adc2, 0, filter2, 0);
AudioConnection patchCord5(filter1, 0, fft1024_1, 0);
AudioConnection patchCord6(filter2, 0, fft1024_2, 0);
double scale_factor_1;
AudioMemory(12); // how do I choose how much audio memory?
fft1024_1.WindowFunction(AudioWindowHanning1024); // which window?
fft1024_2.WindowFunction(AudioWindowHanning1024);
scale_factor_1 = 0;
filter1.frequency(1000);
filter2.frequency(1000);
// FIRST: SCALE PEAKS
if (peak1.available() && peak2.available()) {
scale_factor_1 *= (peak1.read() / peak2.read()); // ratio?
} // peak, or peak-to-peak? I'm thinking the second...
if (fft1024_1.available() && fft1024_2.available()) { // if these have 500+ bins why tf does the ex code only cycle through 40???
for(int i = 0; i <= 511; i++){
if ( abs( fft1024_1.read(i) * scale_factor_1 + fft1024_2.read(i) ) > 0.1 ) { // replace .01 with "SIGNIFICANT" defined static var.
// implementation
} // Is it bad/incorrect to scale frequency bins in this manner?
