Hello,
I am working with a teensy 3.1. I have 2 light to frequency sensors with a maximum sensibility of 1Mhz
I am using the FreqCount library for measuring frequencies and I need to get the frequency every 2ms but
FreqCount.begin(time) accepts only time > 10ms. Can I just modify the source code for accepting values lower than 10ms ?
The only pin available for FreqCount is the led Pin 13, could I add an other input pin for my second sensor ?
I tried to use 2 intervalTimer with 2 attachInterrupt but the teensy is blocking when the frequency is too high.
Thanks for your help,
Best Regards
Best Regards
