I am getting to know the teensy board and the audio shield and observe some noise I cannot explain.
My setup is simple:
- I have plugged a headset--call it headset A--into the 3.5mm plug of the audio shield
- I have taken apart another headset--call it B--, disconnected one of the left ear piece, and wired the left and ground signals from that ear piece to the left line in and ground of the audio shield. I connected the jack of this headset to my computer, which I use to stream audio. This way, I can listen to the audio streaming through the right ear piece and stream the left audio to the left line in port of the shield.
My observations:
- If I run the Example->Audio->HardwareTesting->PassthroughStereo, the playback sound quality through headset A is perfect, as good as what comes out of headset B
- If I run the Example->Audio->Recorder project and use the mic for the input, the sound quality on the playback is ok; it is what I would expect the microphone is capable of producing
- If I run the Example->Audio->Recorder project but use the line in for the input (myInput=AUDIO_INPUT_LINEIN instead of AUDIO_INPUT_MIC), the sound quality on the playback is poor: there is a constant background noise quite noticeable when the signal output is low. (That noise is much greater than the noise picked up by the microphone in the previous experiment.)
Is there an explanation for this noise?
Thanks
My setup is simple:
My observations:
Thanks
