lintweaker
I just got the touch screen from the pjrc store. It is working great connected to a teensy 3.2.
Touch works just fine as long as I dot not enable IRQ usage.
For example with the ILI9341Test example (teensyduino), touch works as long as I do not use IRQs. I tried both the default IRQ 2 and using IRQ on digital pin 6.
I have connected a LED to the IRQ pin, when I touch the screen the LED lights up. So hardware wise the IRQ is working.
I am on arduino IDE 1.6.8 with teensyduino 1.28.
When running the below code with IRQs enabled, the serial print for 'Touch event' never occurs. WIthout IRQs enabled it works fine.
#include <ILI9341_t3.h>
#include <font_Arial.h> // from ILI9341_t3
#include <XPT2046_Touchscreen.h>
#define CS_PIN 8
#define TFT_DC 9
#define TFT_CS 10
// MOSI=11, MISO=12, SCK=13
//XPT2046_Touchscreen ts(CS_PIN);
#define TIRQ_PIN 6 // Was 2
//XPT2046_Touchscreen ts(CS_PIN); // Param 2 - NULL - No interrupts
//XPT2046_Touchscreen ts(CS_PIN, 255); // Param 2 - 255 - No interrupts
XPT2046_Touchscreen ts(CS_PIN, TIRQ_PIN); // Param 2 - Touch IRQ Pin - interrupt enabled polling
Serial.begin(38400);
tft.begin();
tft.setRotation(1);
ts.begin();
while (!Serial && (millis() <= 1000));
boolean wastouched = true;
boolean istouched = ts.touched();
if (istouched) {
Serial.println("Touch event");
TS_Point p = ts.getPoint();
if (!wastouched) {
tft.setTextColor(ILI9341_YELLOW);
tft.setFont(Arial_60);
tft.setCursor(60, 80);
tft.print("Touch");
tft.fillRect(100, 150, 140, 60, ILI9341_BLACK);
tft.setTextColor(ILI9341_GREEN);
tft.setFont(Arial_24);
tft.setCursor(100, 150);
tft.print("X = ");
tft.print(p.x);
tft.setCursor(100, 180);
tft.print("Y = ");
tft.print(p.y);
Serial.print(", x = ");
Serial.print(p.x);
Serial.print(", y = ");
Serial.println(p.y);
if (wastouched) {
tft.setTextColor(ILI9341_RED);
tft.setFont(Arial_48);
tft.setCursor(120, 50);
tft.print("No");
tft.setCursor(80, 120);
tft.print("Touch");
Serial.println("no touch");
wastouched = istouched;
