Help - where is write( i2c addr, val ) , which is used in control_sgtl5000.cpp
garytennyson
I'm trying to code up a simple Stereo In --> Teensy 3.2 CPU --> Stereo Out using the Audio Board. I'm trying to do this outside the Arduino/Teensyduino framework. I thought I could get a good start looking at the 'control_sgtl5000.cpp' code on the GitHub/Audio page. There is a function (write) called there that apparently writes a value to an i2c register on the chip. This looks like a function that I will need to understand, but I can't seem to find it.
It may be defined in 'Wire.h', but my Arduino/Teensyduino distribution doesn't have a 'Wire.h'. I also don't see it on the GitHub/Audio page. There is a header 'Wire.h' in the generic Arduino distribution, and it has prototypes for write functions, but these don't seem to have the same arguments.
Can somebody give me a pointer to the write functions used in 'control_sgtl5000.cpp' ?
Thanks
Gary Tennyson
If you look in control_sgtl5000.h, you will see:
class AudioControlSGTL5000 : public AudioControl
public:
        AudioControlSGTL5000(void) : i2c_addr(0x0A) { }
        void setAddress(uint8_t level);
        bool enable(void);
        bool disable(void) { return false; }
        bool volume(float n) { return volumeInteger(n * 129 + 0.499); }
        bool inputLevel(float n) {return false;}
        bool muteHeadphone(void) { return write(0x0024, ana_ctrl | (1<<4)); }
        bool unmuteHeadphone(void) { return write(0x0024, ana_ctrl & ~(1<<4)); }
        bool muteLineout(void) { return write(0x0024, ana_ctrl | (1<<8)); }
        bool unmuteLineout(void) { return write(0x0024, ana_ctrl & ~(1<<8)); }
        bool inputSelect(int n) {
                if (n == AUDIO_INPUT_LINEIN) {
                        return write(0x0020, 0x055) // +7.5dB gain (1.3Vp-p full scale)
                         && write(0x0024, ana_ctrl | (1<<2)); // enable linein
                } else if (n == AUDIO_INPUT_MIC) {
                        return write(0x002A, 0x0173) // mic preamp gain = +40dB
                         && write(0x0020, 0x088)     // input gain +12dB (is this enough?)
                         && write(0x0024, ana_ctrl & ~(1<<2)); // enable mic
                        return false;
        bool volume(float left, float right);
        bool micGain(unsigned int dB);
        bool lineInLevel(uint8_t n) { return lineInLevel(n, n); }
        bool lineInLevel(uint8_t left, uint8_t right);
        unsigned short lineOutLevel(uint8_t n);
        unsigned short lineOutLevel(uint8_t left, uint8_t right);
        unsigned short dacVolume(float n);
        unsigned short dacVolume(float left, float right);
        bool dacVolumeRamp();
        bool dacVolumeRampLinear();
        bool dacVolumeRampDisable();
        unsigned short adcHighPassFilterEnable(void);
        unsigned short adcHighPassFilterFreeze(void);
        unsigned short adcHighPassFilterDisable(void);
        unsigned short audioPreProcessorEnable(void);
        unsigned short audioPostProcessorEnable(void);
        unsigned short audioProcessorDisable(void);
        unsigned short eqFilterCount(uint8_t n);
        unsigned short eqSelect(uint8_t n);
        unsigned short eqBand(uint8_t bandNum, float n);
        void eqBands(float bass, float mid_bass, float midrange, float mid_treble, float treble);
        void eqBands(float bass, float treble);
        void eqFilter(uint8_t filterNum, int *filterParameters);
        unsigned short autoVolumeControl(uint8_t maxGain, uint8_t lbiResponse, uint8_t hardLimit, float threshold, float attack, float decay);
        unsigned short autoVolumeEnable(void);
        unsigned short autoVolumeDisable(void);
        unsigned short enhanceBass(float lr_lev, float bass_lev);
        unsigned short enhanceBass(float lr_lev, float bass_lev, uint8_t hpf_bypass, uint8_t cutoff);
        unsigned short enhanceBassEnable(void);
        unsigned short enhanceBassDisable(void);
        unsigned short surroundSound(uint8_t width);
        unsigned short surroundSound(uint8_t width, uint8_t select);
        unsigned short surroundSoundEnable(void);
        unsigned short surroundSoundDisable(void);
        void killAutomation(void) { semi_automated=false; }
protected:
        bool muted;
        bool volumeInteger(unsigned int n); // range: 0x00 to 0x80
        uint16_t ana_ctrl;
        uint8_t i2c_addr;
        unsigned char calcVol(float n, unsigned char range);
        unsigned int read(unsigned int reg);
        bool write(unsigned int reg, unsigned int val);
        unsigned int modify(unsigned int reg, unsigned int val, unsigned int iMask);
        unsigned short dap_audio_eq_band(uint8_t bandNum, float n);
private:
        bool semi_automated;
        void automate(uint8_t dap, uint8_t eq);
        void automate(uint8_t dap, uint8_t eq, uint8_t filterCount);
Note under the protected section is the function write. In the file hardware/teensy/avr/libraries/Audio/control_sgtl5000.cpp, you will see:
bool AudioControlSGTL5000::write(unsigned int reg, unsigned int val)
        if (reg == CHIP_ANA_CTRL) ana_ctrl = val;
        Wire.beginTransmission(i2c_addr);
        Wire.write(reg >> 8);
        Wire.write(reg);
        Wire.write(val >> 8);
        Wire.write(val);
        if (Wire.endTransmission() == 0) return true;
        return false;
So, it basically connects to the i2c device, sends 2 bytes from the first argument, and 2 bytes from the second argument in a big endian fashion (most significant byte first), and then ends the i2c message, and returns true/false depending on if there are errors.
