Teensyduino 1.29 Beta #3 Available
Paul
Administrator
Staff member
Here is a third (and hopefully final) beta test for Teensyduino 1.29.
EDIT: beta test link removed.
Changes since Teensyduino 1.29-beta2:
  • Many fixes for K66 beta test
  • Fix WCharacter and ctype functions
  • Allow SPI setMOSI, setMISO, setCLK after SPI.begin()
  • Serial1 setTX & setRX support pins 24-25 on Teensy LC
  • Update FastLED
I had two orphaned Teensy_gateway processes I had to kill on Win 10 before I could complete install.
Did that and BACK and Install completed properly. Working on my K66.
Had a T_3.2 online with the K66 and hit Upload and it picked the T_3.2 as first device and gave appropriate 'conflict' dialog - unplugged T_3.2 and K66 button press was ignored - like it didn't rescan - I had to IDE Upload again to get it seen.
Win_7 machine not happy with K66 staring at this for a couple minutes - then went to error - I suppose this was the HID device that went away before it completed install:
In the end it is working fine - on com port #9 as indicated. No problems uploading.
In TD: 1.29-beta3 and previous beta2 I have been getting a lot of "Error compiling for board Teensy 3.2 / 3.1." Usually it is a syntax error in my sketch and it made a library blow up for some reason. Having the least helpful error message being the last one displayed results in lots of tedious scrolling up in the small console of the Arduino IDE. I always get the error below the first time I try to compile and often several times thereafter. But "Unable find Teensy Loader. Is the Teensy Loader application running?" is off screen.
So there are 2 issues,
Teensy loader is running, but not reliably detected.
Order of display of errors has large effect on workflow.
This is an older Dell Latitude E6400 so HD is often busy, that could be a contributor if timeouts are responsible. What other info do you need?
The relevant error is almost always the first to occur. Could the verify process save that error and then redisplay it on the final line.
Arduino: 1.6.9 (Linux), TD: 1.29-beta3, Board: "Teensy 3.2 / 3.1, Serial, 96 MHz optimized (overclock), US English"
/opt/arduino-1.6.9/arduino-builder -dump-prefs -logger=machine -hardware "/opt/arduino-1.6.9/hardware" -hardware "/home/slo/.arduino15/packages" -tools "/opt/arduino-1.6.9/tools-builder" -tools "/opt/arduino-1.6.9/hardware/tools/avr" -tools "/home/slo/.arduino15/packages" -built-in-libraries "/opt/arduino-1.6.9/libraries" -libraries "/home/slo/Arduino/libraries" -fqbn=teensy:avr:teensy31:usb=serial,speed=96opt,keys=en-us -ide-version=10609 -build-path "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp" -warnings=all -verbose "/home/slo/Arduino/HanksTractorTeensy3x/HanksTractorTeensy3x.ino"
/opt/arduino-1.6.9/arduino-builder -compile -logger=machine -hardware "/opt/arduino-1.6.9/hardware" -hardware "/home/slo/.arduino15/packages" -tools "/opt/arduino-1.6.9/tools-builder" -tools "/opt/arduino-1.6.9/hardware/tools/avr" -tools "/home/slo/.arduino15/packages" -built-in-libraries "/opt/arduino-1.6.9/libraries" -libraries "/home/slo/Arduino/libraries" -fqbn=teensy:avr:teensy31:usb=serial,speed=96opt,keys=en-us -ide-version=10609 -build-path "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp" -warnings=all -verbose "/home/slo/Arduino/HanksTractorTeensy3x/HanksTractorTeensy3x.ino"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/sketch/HanksTractorTeensy3x.ino.cpp" -o "/dev/null"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/sketch/HanksTractorTeensy3x.ino.cpp" -o "/dev/null"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/sketch/HanksTractorTeensy3x.ino.cpp" -o "/dev/null"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/sketch/HanksTractorTeensy3x.ino.cpp" -o "/dev/null"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM" "/home/slo/Arduino/libraries/FreqMeasureMulti/FreqMeasureMulti.cpp" -o "/dev/null"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM" "/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo/Servo.cpp" -o "/dev/null"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM" "/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM/EEPROM.cpp" -o "/dev/null"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/sketch/HanksTractorTeensy3x.ino.cpp" -o "/dev/null"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/sketch/HanksTractorTeensy3x.ino.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/preproc/ctags_target_for_gcc_minus_e.cpp"
"/opt/arduino-1.6.9/tools-builder/ctags/5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/preproc/ctags_target_for_gcc_minus_e.cpp"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/sketch/HanksTractorTeensy3x.ino.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/sketch/HanksTractorTeensy3x.ino.cpp.o"
HanksTractorTeensy3x: In function 'void loop()':
HanksTractorTeensy3x:100: warning: unused variable 'tempMinThrottlePedalValue'
   static uint16_t tempMinThrottlePedalValue = minThrottlePedalValue;
HanksTractorTeensy3x:101: warning: unused variable 'tempMaxThrottlePedalValue'
   static uint16_t tempMaxThrottlePedalValue = maxThrottlePedalValue;
HanksTractorTeensy3x:102: warning: unused variable 'minCount'
   static uint16_t minCount = 0;
HanksTractorTeensy3x:103: warning: unused variable 'maxCount'
   static uint16_t maxCount = 0;
In file included from /home/slo/Arduino/HanksTractorTeensy3x/HanksTractorTeensy3x.ino:14:0:
/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM/EEPROM.h: In instantiation of 'const T& EEPROMClass::put(int, const T&) [with T = short unsigned int]':
/home/slo/Arduino/HanksTractorTeensy3x/HanksTractorTeensy3x.ino:87:55:   required from here
/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM/EEPROM.h:144:15: warning: variable 'e' set but not used [-Wunused-but-set-variable]
         EEPtr e = idx;
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM" "/home/slo/Arduino/libraries/FreqMeasureMulti/FreqMeasureMulti.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/FreqMeasureMulti/FreqMeasureMulti.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM" "/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo/Servo.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/Servo/Servo.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM" "/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM/EEPROM.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/EEPROM/EEPROM.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/memcpy-armv7m.S" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/memcpy-armv7m.S.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/memset.S" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/memset.S.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/analog.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/analog.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/eeprom.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/eeprom.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/keylayouts.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/keylayouts.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/math_helper.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/math_helper.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/mk20dx128.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/mk20dx128.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/nonstd.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/nonstd.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/pins_teensy.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/pins_teensy.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/ser_print.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/ser_print.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/serial1.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/serial1.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/serial2.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/serial2.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/serial3.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/serial3.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/serial4.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/serial4.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/serial5.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/serial5.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/touch.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/touch.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/usb_desc.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_desc.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/usb_dev.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_dev.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/usb_joystick.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_joystick.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/usb_keyboard.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_keyboard.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/usb_mem.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_mem.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/usb_midi.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_midi.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/usb_mouse.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_mouse.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/usb_mtp.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_mtp.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/usb_rawhid.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_rawhid.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/usb_seremu.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_seremu.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/usb_serial.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_serial.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/usb_touch.c" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_touch.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/AudioStream.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/AudioStream.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/DMAChannel.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/DMAChannel.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/HardwareSerial1.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/HardwareSerial1.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/HardwareSerial2.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/HardwareSerial2.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/HardwareSerial3.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/HardwareSerial3.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/HardwareSerial4.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/HardwareSerial4.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/HardwareSerial5.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/HardwareSerial5.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/IPAddress.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/IPAddress.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/IntervalTimer.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/IntervalTimer.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/Print.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/Print.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/Stream.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/Stream.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/Tone.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/Tone.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/WMath.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/WMath.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/WString.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/WString.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/avr_emulation.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/avr_emulation.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/main.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/main.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/new.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/new.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/usb_audio.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_audio.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/usb_flightsim.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_flightsim.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/usb_inst.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_inst.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/yield.cpp" -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/yield.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/memcpy-armv7m.S.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/memset.S.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/analog.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/eeprom.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/keylayouts.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/math_helper.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/mk20dx128.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/nonstd.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/pins_teensy.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/ser_print.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/serial1.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/serial2.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/serial3.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/serial4.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/serial5.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/touch.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_desc.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_dev.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_joystick.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_keyboard.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_mem.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_midi.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_mouse.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_mtp.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_rawhid.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_seremu.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_serial.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_touch.c.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/AudioStream.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/DMAChannel.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/HardwareSerial1.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/HardwareSerial2.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/HardwareSerial3.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/HardwareSerial4.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/HardwareSerial5.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/IPAddress.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/IntervalTimer.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/Print.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/Stream.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/Tone.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/WMath.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/WString.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/avr_emulation.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/main.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/new.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_audio.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_flightsim.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_inst.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/yield.cpp.o"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1466939080 "-T/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/mk20dx256.ld"  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/HanksTractorTeensy3x.ino.elf" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/sketch/HanksTractorTeensy3x.ino.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/FreqMeasureMulti/FreqMeasureMulti.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/Servo/Servo.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/EEPROM/EEPROM.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "-L/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp" -larm_cortexM4l_math -lm
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/HanksTractorTeensy3x.ino.elf" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/HanksTractorTeensy3x.ino.eep"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/HanksTractorTeensy3x.ino.elf" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/HanksTractorTeensy3x.ino.hex"
"/opt/arduino-1.6.9/hardware/teensy/../tools//teensy_post_compile" "-file=HanksTractorTeensy3x.ino" "-path=/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp" "-tools=/opt/arduino-1.6.9/hardware/teensy/../tools/" "-board=TEENSY31"
Opening Teensy Loader...
Multiple libraries were found for "FreqMeasureMulti.h"
 Used: /home/slo/Arduino/libraries/FreqMeasureMulti
 Not used: /opt/arduino-1.6.9/hardware/teensy/avr/libraries/FreqMeasureMulti
Using library FreqMeasureMulti at version 0.22 in folder: /home/slo/Arduino/libraries/FreqMeasureMulti
Using library Servo at version 1.1.2 in folder: /opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo
Using library EEPROM at version 2.0 in folder: /opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM
I frequently experience this problem reported for beta 2 on teensy 3.1. It will even report "download complete" when there is no Teensy connected to the computer at all. That message needs to be fixed.
The suggested workaround, Loading the blink sketch, was very hit and mis due to the circular problem of loading it in the first place, but it did help in some cases. For this reason, I request that the next Teensy Hardware version please bring RESET out to a hole, or a button. lsusb showed that the teensy would frequently disappear from the list. Best results were obtained with high quality(short) USB cables and laptop running on AC. Teensy fails to load ~80% when laptop running on battery.
Perhaps when program mode button is pressed, it could save context and disable some of the high current, high resource peripherals, interrupts, and tristate output pins and wait for current to settle down before looking for teensy loader. Likewise, Teensy Loader might wait a bit longer for an overloaded Teensy to respond.
Teensy 3.2, Arduino 1.6.9 (Arduino 2), empty sketch. Verify is OK but download results in 'download complete' from Arduino IDE but
Teensy did not respond to a USB request to automatically reboot
Please press the PROGRAM MODE BUTTON on your Teensy to upload your sketch
No amount of pressing that button/in any order before/during/after the above error results in anything but a repeat of that error message.
Thoughts?
Please note that NO code has changed from the time this project compiled and worked on beta 2, through the 4 compile attempts on beta 3. Yet, identical code resulted in 4 different messages from the IDE.
The next compile attempt resulted in
Teensy Loader error responding to comment
This sketch compiled fine on TD: 1.29-beta2 with everything else the same.
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/sketch/HanksTractorTeensy3x.ino.cpp" -o "/dev/null"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM/EEPROM.cpp" -o "/dev/null"
Using previously compiled file: ... (DELETED DUE TO CHARACTER LIMIT)
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1466947689 "-T/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/mk20dx256.ld"  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/HanksTractorTeensy3x.ino.elf" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/sketch/HanksTractorTeensy3x.ino.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/FreqMeasureMulti/FreqMeasureMulti.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/Servo/Servo.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/EEPROM/EEPROM.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "-L/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp" -larm_cortexM4l_math -lm
The next compile "Teensy Loader could not find the file HanksTractorTeensy3x.ino"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/sketch/HanksTractorTeensy3x.ino.cpp" -o "/dev/null"
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/EEPROM" "-I/home/slo/Arduino/libraries/FreqMeasureMulti" "-I/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo" "/opt/arduino-1.6.9/hardware/teensy/avr/libraries/Servo/Servo.cpp" -o "/dev/null"
         EEPtr e = idx;
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/FreqMeasureMulti/FreqMeasureMulti.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/Servo/Servo.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/EEPROM/EEPROM.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/memcpy-armv7m.S.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/memset.S.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/analog.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/eeprom.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/keylayouts.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/math_helper.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/mk20dx128.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/nonstd.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/pins_teensy.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/ser_print.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/serial1.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/serial2.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/serial3.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/serial4.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/serial5.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/touch.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_desc.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_dev.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_joystick.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_keyboard.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_mem.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_midi.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_mouse.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_mtp.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_rawhid.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_seremu.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_serial.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_touch.c.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/AudioStream.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/DMAChannel.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/HardwareSerial1.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/HardwareSerial2.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/HardwareSerial3.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/HardwareSerial4.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/HardwareSerial5.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/IPAddress.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/IntervalTimer.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/Print.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/Stream.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/Tone.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/WMath.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/WString.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/avr_emulation.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/main.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/new.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_audio.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_flightsim.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/usb_inst.cpp.o
Using previously compiled file: /tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/yield.cpp.o
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1466948799 "-T/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/mk20dx256.ld"  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/HanksTractorTeensy3x.ino.elf" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/sketch/HanksTractorTeensy3x.ino.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/FreqMeasureMulti/FreqMeasureMulti.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/Servo/Servo.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/EEPROM/EEPROM.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "-L/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp" -larm_cortexM4l_math -lm
Error compiling for board Teensy 3.2 / 3.1.
Finally, success.
"/opt/arduino-1.6.9/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1466949141 "-T/opt/arduino-1.6.9/hardware/teensy/avr/cores/teensy3/mk20dx256.ld"  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/HanksTractorTeensy3x.ino.elf" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/sketch/HanksTractorTeensy3x.ino.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/FreqMeasureMulti/FreqMeasureMulti.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/Servo/Servo.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/libraries/EEPROM/EEPROM.cpp.o" "/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp/core/core.a" "-L/tmp/build0361cbb29f46556c2b9542bfcf0f3649.tmp" -larm_cortexM4l_math -lm
Sketch uses 23,508 bytes (8%) of program storage space. Maximum is 262,144 bytes.
Global variables use 5,676 bytes (8%) of dynamic memory, leaving 59,860 bytes for local variables. Maximum is 65,536 bytes.
Project modifies a Peg Perego 2 speed child's ride on toy John Deer Tractor from on/off control, to proportional throttle and R/C control.
/* FreqMeasureMulti - Servo
 * http://pjrc.com/teensy/td_libs_FreqMeasure.html
 * http://pjrc.com/teensy/td_libs_Servo.html
 * Board            FreqMeasureMulti Supported Pins on FTM0
 * Teensy LC        6, 9, 10, 20, 22, 23
 * Teensy 3.1       5, 6, 9, 10, 20, 21, 22, 23
 * Teensy 3.2       5, 6, 9, 10, 20, 21, 22, 23
#include <FreqMeasureMulti.h>
#include <Servo.h>
#include <EEPROM.h>
#define debug
#define CHANNELS 4
#define NEUTRAL 1500
#define REVERSE_LIMIT 1200
#define FORWARD1_LIMIT 1800
#define FORWARD2_LIMIT 2000
#define MAX_FRAME_INTERVAL 22000
#define NEW_EEPROM_COUNT_THRESHOLD 100
#define RESERVED_EEPROM_ADDR 0
#define MIN_THROTTLE_ADDR sizeof(uint16_t)
#define MAX_THROTTLE_ADDR sizeof(uint16_t)*2
elapsedMicros sinceFrame;
enum states {NOT_RC, RC_STOPPED, RC_DRIVING, STOPPED, REVERSE, FORWARD1, FORWARD2};
states state;
// Measure width of 4 individual Futaba servo channels(R2004GF)
// channels 1 and 2 begin simultaneously, and channel 3 and 4 begin simultaneously a few ns after start of 1 and 2.
FreqMeasureMulti channel1;
FreqMeasureMulti channel2;
FreqMeasureMulti channel3;
FreqMeasureMulti channel4;
// store the updated value in ch[x], for now, put default values there.
uint16_t ch_microseconds[CHANNELS +1] = {0,NEUTRAL,NEUTRAL,NEUTRAL,NEUTRAL};
// and output 4 regular servo channels
Servo servo1;  // create servo objects
Servo servo2;
Servo servo3;  // create servo objects
Servo servo4;
static const uint8_t throttlePedalPin = 14;
uint16_t throttlePedalValue = 0;
uint16_t minThrottlePedalValue = 400;
uint16_t maxThrottlePedalValue = 600;
static const uint8_t blueShifterPin= 2;
static const uint8_t blackShifterPin= 3;
uint16_t leftMCvalue  = NEUTRAL;
uint16_t rightMCvalue = NEUTRAL;
#ifdef debug
  Serial.begin(57600);
  while (!Serial) ; // wait for Arduino Serial Monitor
  delay(10);
  Serial.println("FreqMeasureMulti and Servo Begin");
  delay(10);
  channel1.begin(9,FREQMEASUREMULTI_MARK_ONLY);  // purple wire
  channel2.begin(10,FREQMEASUREMULTI_MARK_ONLY); // blue wire
  channel3.begin(20,FREQMEASUREMULTI_MARK_ONLY);  // green wire
  channel4.begin(22,FREQMEASUREMULTI_MARK_ONLY);  // yellow wire
  servo1.attach(4);  // white wire
  servo2.attach(5);  // grey wire
  servo3.attach(6);  // brown wire
  servo4.attach(7);  // orange wire
  pinMode(throttlePedalPin, INPUT);
  pinMode(blueShifterPin, INPUT_PULLUP);
  pinMode(blackShifterPin, INPUT_PULLUP);
  pinMode(13, OUTPUT); // LED
  uint16_t temp;
  EEPROM.get(MIN_THROTTLE_ADDR, temp);
  if(0 == temp)
  {EEPROM.put(MIN_THROTTLE_ADDR, minThrottlePedalValue);} // first time only
  EEPROM.get(MAX_THROTTLE_ADDR, temp);
  if(0 == temp)
  {EEPROM.put(MAX_THROTTLE_ADDR, maxThrottlePedalValue);} // first time only
  // every time
  EEPROM.get(MIN_THROTTLE_ADDR, minThrottlePedalValue);
  EEPROM.get(MAX_THROTTLE_ADDR, maxThrottlePedalValue);
  sinceFrame = 0;
{ // min and max of throttle are checked
    if (channel1.available() && channel2.available() && channel3.available() ) // valid RC frame
      // read RC controls
      sinceFrame = 0;
      ch_microseconds[1] = FreqMeasureMulti::countToMicroseconds(channel1.readLatest());
      ch_microseconds[2] = FreqMeasureMulti::countToMicroseconds(channel2.readLatest());
      ch_microseconds[3] = FreqMeasureMulti::countToMicroseconds(channel3.readLatest());
      ch_microseconds[4] = FreqMeasureMulti::countToMicroseconds(channel4.readLatest()); // don't care if ch 4 is valid, but we'll take it anyway
#ifdef debug
Serial.print("in RC loop. sinceFrame ");
Serial.println(sinceFrame);
Serial.print(ch_microseconds[1]);
Serial.print(", ");
Serial.print(ch_microseconds[2]);
Serial.print(", ");
Serial.print(ch_microseconds[3]);
Serial.print(", ");
Serial.println(ch_microseconds[4]);
      if(ch_microseconds[3] > NEUTRAL + 200)// left stick vertical, ratchet, non-spring-return, down
      {// RC signal received, and override selected
        ch_microseconds[0] = 1;// boolean indicator for RC control
        if(((ch_microseconds[1] > NEUTRAL-60)&&(ch_microseconds[1] < NEUTRAL+60))&&(((ch_microseconds[2] > NEUTRAL-60)&&(ch_microseconds[2] < NEUTRAL+60))))
        {// right stick within deadband
          state = RC_STOPPED;
#ifdef debug
Serial.print("state RC_STOPPED. sinceFrame ");
Serial.print("leftMCvalue ");
Serial.print(leftMCvalue);
Serial.print("       rightMCvalue ");
Serial.println(rightMCvalue);
        {// RC_1pulse = steer- increases to right, RC_2pulse = speed- increases to up
          state = RC_DRIVING;
          leftMCvalue  = ch_microseconds[2]+(ch_microseconds[1]-(NEUTRAL+20));
          rightMCvalue = ch_microseconds[2]-(ch_microseconds[1]-(NEUTRAL+20));
#ifdef debug
Serial.print("state RC_DRIVING. sinceFrame ");
        servo1.writeMicroseconds(leftMCvalue);
        servo2.writeMicroseconds(rightMCvalue);
        servo3.writeMicroseconds(ch_microseconds[3]);// unused as output, push DOWN to override, UP to hand over local control
        servo4.writeMicroseconds(ch_microseconds[4]);// might be used as pass through, but just as easy to wire directly from receiver to servo
#ifdef debug
Serial.print("writing to ESC RC. sinceFrame ");
Serial.print("ch_microseconds[3] ");
Serial.println(ch_microseconds[3]);
Serial.print("ch_microseconds[4] ");
        ch_microseconds[0] = 0;
        state = NOT_RC;
 #ifdef debug
Serial.print("state NOT_RC. sinceFrame ");
    if(sinceFrame > MAX_FRAME_INTERVAL || state == NOT_RC)// RC equipment off, out of range, one or more critical channels disconnected, or ch3 stick is down
      // read local controls
      sinceFrame = 0;
      ch_microseconds[0] = 0;// can be used as a boolean flag to determine if under RC control
#ifdef debug
Serial.print("in local control loop.  sinceFrame ");
      if((throttlePedalValue = analogRead(throttlePedalPin)) < (minThrottlePedalValue + 40))
      { // no throttle applied
        state = STOPPED;
#ifdef debug
Serial.print("state STOPPED, throttle ");
Serial.print(throttlePedalValue);
Serial.print("  sinceFrame ");
      else if(digitalRead(blueShifterPin) ) //blue high  note: If shifter pins are disconnected, they will both be pulled high and state will default to REVERSE
      { // low top speed reverse
        state = REVERSE;
        leftMCvalue  = map(throttlePedalValue, minThrottlePedalValue, maxThrottlePedalValue, NEUTRAL, REVERSE_LIMIT);
        rightMCvalue = map(throttlePedalValue, minThrottlePedalValue, maxThrottlePedalValue, NEUTRAL, REVERSE_LIMIT);
#ifdef debug
Serial.print("state REVERSE, throttle ");
      else if(digitalRead(blackShifterPin)  && !(digitalRead(blueShifterPin)))   //black high
      { // low top speed forward
        state = FORWARD1;
        leftMCvalue  = map(throttlePedalValue, minThrottlePedalValue, maxThrottlePedalValue, NEUTRAL, FORWARD1_LIMIT);
        rightMCvalue = map(throttlePedalValue, minThrottlePedalValue, maxThrottlePedalValue, NEUTRAL, FORWARD1_LIMIT);
#ifdef debug
Serial.print("state FORWARD1, throttle ");
      { // high top speed forward
        state = FORWARD2;
        leftMCvalue  = map(throttlePedalValue, minThrottlePedalValue, maxThrottlePedalValue, NEUTRAL, FORWARD2_LIMIT);
        rightMCvalue = map(throttlePedalValue, minThrottlePedalValue, maxThrottlePedalValue, NEUTRAL, FORWARD2_LIMIT);
#ifdef debug
Serial.print("state FORWARD2, throttle ");
      servo3.writeMicroseconds(ch_microseconds[3]);// unused, just push up to override, down to handover local control
      static uint16_t tempMinThrottlePedalValue = minThrottlePedalValue;
      if(throttlePedalValue <= minThrottlePedalValue)// flirting with a new min
        if(throttlePedalValue == tempMinThrottlePedalValue)// not the first time at this value, make sure it isn't a transient
          minCount++;
          if(minCount > NEW_EEPROM_COUNT_THRESHOLD)// we have a new bottom
            minThrottlePedalValue = tempMinThrottlePedalValue;// this affects scaling of throttle and may change the feel of throttle response
#ifdef debug
Serial.print("new min throttle ");
Serial.println(minThrottlePedalValue);
        else // new temp minimum
          tempMinThrottlePedalValue = throttlePedalValue; // new candidate for bottom.  Perhaps the potentiometer mount shifted.
          minCount = 0;
       if(throttlePedalValue >= maxThrottlePedalValue)// flirting with a new max
        if(throttlePedalValue == tempMaxThrottlePedalValue)// not the first time at this value, make sure it isn't a transient
          maxCount++;
          if(maxCount > NEW_EEPROM_COUNT_THRESHOLD)// we have a new top
            maxThrottlePedalValue = tempMaxThrottlePedalValue;// this affects scaling of throttle and may change the feel of throttle response
#ifdef debug
Serial.print("new max throttle ");
Serial.println(maxThrottlePedalValue);
        else // new temp maximum
          tempMaxThrottlePedalValue = throttlePedalValue; // new candidate for top.  Perhaps the potentiometer mount shifted.
          maxCount = 0;
#ifdef debug
Serial.print("writing to ESC local. sinceFrame ");
    }// RC receiver has LED to indicate good RC signal(green) or bad(red).  The Teensy LED lights (orange) to indicate that the tractor is under Hank's local control.
    // if the receiver LED is ever Red or dark, and the Teensy LED is not orange, there is a problem.
    // RC receiver green and Teensy LED orange, means that RC can take control at any time by moving stick 3 down.
    digitalWriteFast(13, ch_microseconds[0]?LOW:HIGH);  // does this line get the fast optimization?  The parameter is technically a constant, but a variable must be accessed for the ternary.
    //almost same as
    //if(ch_microseconds[0]){digitalWriteFast(13, LOW);}
    //else {digitalWriteFast(13, HIGH);}
Modified library to read servo signals /home/slo/Arduino/libraries/FreqMeasureMulti
#ifndef FreqMeasureMulti_h
#define FreqMeasureMulti_h
#include <Arduino.h>
#define FREQMEASUREMULTI_BUFFER_LEN 24
// capture modes
#define FREQMEASUREMULTI_RAISING 1
#define FREQMEASUREMULTI_FALLING 2
#define FREQMEASUREMULTI_INTERLEAVE 3
#define FREQMEASUREMULTI_SPACE_ONLY 5
#define FREQMEASUREMULTI_MARK_ONLY 6
#define FREQMEASUREMULTI_ALTERNATE 7
// result constants for fmultiRecord.level
#define LEVEL_SPACE_ONLY 0
#define LEVEL_SPACE_MARK 1
#define LEVEL_MARK_SPACE 2
#define LEVEL_MARK_ONLY 3
#define LEVEL_UNDEFINED 255
typedef struct {
	uint8_t level;
	uint32_t count;
} fmultiRecord;
class FreqMeasureMulti
public:
	bool begin(uint32_t pin);
	bool begin(uint32_t pin, uint8_t mode);
	bool begin(uint32_t pin, uint8_t mode, uint8_t bufferLength);
	uint32_t available(void);
	uint32_t read(void);
	uint32_t readLatest(void);
	uint8_t readLevel(void);
	uint8_t channelToPin(uint8_t);
	static float countToFrequency(uint32_t count);
	static float countToNanoseconds(uint32_t count);
	static uint16_t countToMicroseconds(uint32_t count);
	friend void on_new_sample(void);
	void end(void);
private:
	void isr(bool inc);
	friend void ftm0_isr(void);
	fmultiRecord buffer_value[FREQMEASUREMULTI_BUFFER_LEN];
	uint8_t buffer_len;
	uint8_t buffer_head;
	uint8_t buffer_tail;
	uint8_t channel;
	uint8_t last_read_level;
	uint32_t raiscap_previous;
	uint32_t fallcap_previous;
	bool act_on_fall, act_on_raise, read_diff;
	bool next_is_falling;
/* FreqMeasure Library, for measuring relatively low frequencies
 * http://www.pjrc.com/teensy/td_libs_FreqMeasure.html
 * Copyright (c) 2015 PJRC.COM, LLC - Paul Stoffregen <paul@pjrc.com>
 * Extended 2016 by Thierry Frenkel <theremingenieur@gmail.com>
 * Version 0.22
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE.
#include "FreqMeasureMulti.h"
#define FTM_SC_VALUE (FTM_SC_TOIE | FTM_SC_CLKS(1) | FTM_SC_PS(0))
#define FTM_CSC_RAISING (FTM_CSC_CHIE | FTM_CSC_ELSA)
#define FTM_CSC_FALLING (FTM_CSC_CHIE | FTM_CSC_ELSB)
#define UPDATE_ON_RAISING 1
#define UPDATE_ON_FALLING 2
#define UPDATE_DIFFERENCE 4
static uint8_t channelmask = 0;
static uint16_t capture_msw = 0;
static FreqMeasureMulti * list[8];
void on_new_sample(uint8_t ch) __attribute__ ((weak));
void on_new_sample(uint8_t ch){}
bool FreqMeasureMulti::begin(uint32_t pin)
	return begin(pin, (uint8_t)FREQMEASUREMULTI_RAISING, (uint8_t)FREQMEASUREMULTI_BUFFER_LEN);
bool FreqMeasureMulti::begin(uint32_t pin, uint8_t mode)
	return begin(pin, (uint8_t)mode, (uint8_t)FREQMEASUREMULTI_BUFFER_LEN);
bool FreqMeasureMulti::begin(uint32_t pin, uint8_t mode, uint8_t bufferLength)
	uint8_t capture_mode;
	switch (pin) {
		case 22: channel = 0; CORE_PIN22_CONFIG = PORT_PCR_MUX(4); break;
		case 23: channel = 1; CORE_PIN23_CONFIG = PORT_PCR_MUX(4); break;
		case  9: channel = 2; CORE_PIN9_CONFIG  = PORT_PCR_MUX(4); break;
		case 10: channel = 3; CORE_PIN10_CONFIG = PORT_PCR_MUX(4); break;
		case  6: channel = 4; CORE_PIN6_CONFIG  = PORT_PCR_MUX(4); break;
		case 20: channel = 5; CORE_PIN20_CONFIG = PORT_PCR_MUX(4); break;
#if defined(KINETISK)
		case 21: channel = 6; CORE_PIN21_CONFIG = PORT_PCR_MUX(4); break;
		case  5: channel = 7; CORE_PIN5_CONFIG  = PORT_PCR_MUX(4); break;
		default:
			channel = 8;
			return false;
	switch (mode) {
		case FREQMEASUREMULTI_FALLING:
		case FREQMEASUREMULTI_INTERLEAVE:
		case FREQMEASUREMULTI_MARK_ONLY:
		case FREQMEASUREMULTI_SPACE_ONLY:
		case FREQMEASUREMULTI_ALTERNATE:
			capture_mode = mode;
		default:
			capture_mode = FREQMEASUREMULTI_RAISING;
	act_on_raise = (capture_mode & UPDATE_ON_RAISING);
	act_on_fall = (capture_mode & UPDATE_ON_FALLING);
	read_diff = (capture_mode & UPDATE_DIFFERENCE);
	NVIC_DISABLE_IRQ(IRQ_FTM0);
	if (FTM0_MOD != 0xFFFF || (FTM0_SC & 0x7F) != FTM_SC_VALUE) {
		FTM0_SC = 0;
		FTM0_CNT = 0;
		FTM0_MOD = 0xFFFF;
		FTM0_SC = FTM_SC_VALUE;
		#ifdef KINETISK
		FTM0_MODE = FTM_MODE_WPDIS; //allow reconfiguring the CSC on the fly
	capture_msw = 0;
	raiscap_previous = 0;
	fallcap_previous = 0;
	next_is_falling = false;
	buffer_len = bufferLength;
	buffer_head = 0;
	buffer_tail = 0;
	volatile uint32_t *csc = &FTM0_C0SC + channel * 2;
	#if defined(KINETISL)
	*csc = 0;
	delayMicroseconds(1);
	*csc = FTM_CSC_RAISING; // first capture is always rising
	list[channel] = this;
	channelmask |= (1 << channel);
	NVIC_SET_PRIORITY(IRQ_FTM0, 48);
	NVIC_ENABLE_IRQ(IRQ_FTM0);
	return true;
uint32_t FreqMeasureMulti::available(void)
	uint32_t head = buffer_head;
	uint32_t tail = buffer_tail;
	if (head >= tail) return head - tail;
	return buffer_len + head - tail;
uint32_t FreqMeasureMulti::read(void)
	if (head == tail) return 0xFFFFFFFF;
	tail = tail + 1;
	if (tail >= buffer_len) tail = 0;
	uint32_t value = buffer_value[tail].count;
	last_read_level = buffer_value[tail].level;
	buffer_tail = tail;
	return value;
uint32_t FreqMeasureMulti::readLatest(void)
	tail = head;
	buffer_tail = tail;
	return value;
uint8_t FreqMeasureMulti::readLevel(void)
	return last_read_level;
float FreqMeasureMulti::countToFrequency(uint32_t count)
#if defined(__arm__) && defined(TEENSYDUINO) && defined(KINETISK)
	return (float)F_BUS / (float)count;
#elif defined(__arm__) && defined(TEENSYDUINO) && defined(KINETISL)
	return (float)(F_PLL/2) / (float)count;
#else
	return 0.0;
float FreqMeasureMulti::countToNanoseconds(uint32_t count)
	return (float)(count * 1000) / (float)(F_BUS / 1000000);
	return (float)(count * 1000) / (float)(F_PLL / 2000000);
#else
	return 0.0;
uint16_t FreqMeasureMulti::countToMicroseconds(uint32_t count)
	return (uint16_t)(count /(F_BUS / 1000000));
	return (uint16_t)(count /(F_PLL / 2000000));
#else
	return 0;
uint8_t FreqMeasureMulti::channelToPin(uint8_t ch)
	switch (ch) {
		case 0: return 22;
		case 1: return 23;
		case 2: return 9;
		case 3: return 10;
		case 4: return 6;
		case 5: return 20;
		case 6: return 21;
		case 7: return 5;
		default: return 0xFF;
void FreqMeasureMulti::end(void)
	switch (channel) {
		case 0: CORE_PIN22_CONFIG = 0; break;
		case 1: CORE_PIN23_CONFIG = 0; break;
		case 2: CORE_PIN9_CONFIG  = 0; break;
		case 3: CORE_PIN10_CONFIG = 0; break;
		case 4: CORE_PIN6_CONFIG  = 0; break;
		case 5: CORE_PIN20_CONFIG = 0; break;
		case 6: CORE_PIN21_CONFIG = 0; break;
		case 7: CORE_PIN5_CONFIG  = 0; break;
		default: return;
	channelmask &= ~(1 << channel);
	*csc = 0;
void ftm0_isr(void)
	bool inc = false;
	if (FTM0_SC & FTM_SC_TOF) {
		#elif defined(KINETISL)
		FTM0_SC = FTM_SC_VALUE | FTM_SC_TOF;
		capture_msw++;
		inc = true;
	uint8_t mask = FTM0_STATUS & channelmask;
	if ((mask & 0x01)) list[0]->isr(inc);
	if ((mask & 0x02)) list[1]->isr(inc);
	if ((mask & 0x04)) list[2]->isr(inc);
	if ((mask & 0x08)) list[3]->isr(inc);
	if ((mask & 0x10)) list[4]->isr(inc);
	if ((mask & 0x20)) list[5]->isr(inc);
	if ((mask & 0x40)) list[6]->isr(inc);
	if ((mask & 0x80)) list[7]->isr(inc);
void FreqMeasureMulti::isr(bool inc)
	uint32_t period = 0;
	uint8_t level = LEVEL_UNDEFINED;
	uint32_t capture = csc[1];
	next_is_falling = !next_is_falling; // toggle capture mode
	csc[0] = (next_is_falling ? FTM_CSC_FALLING : FTM_CSC_RAISING);
	csc[0] = (next_is_falling ? FTM_CSC_FALLING : FTM_CSC_RAISING) | FTM_CSC_CHF;
	if (capture <= 0xE000 || !inc) {
		capture |= (capture_msw << 16);
		capture |= ((capture_msw - 1) << 16);
	// compute the waveform period
	if (next_is_falling) {
		if (act_on_raise) period = capture - (read_diff ? fallcap_previous : raiscap_previous);
		raiscap_previous = capture;
		level = (read_diff ? LEVEL_SPACE_ONLY : LEVEL_MARK_SPACE);
	} else if (!next_is_falling ) {
		if (act_on_fall) period = capture - (read_diff ? raiscap_previous : fallcap_previous);
		fallcap_previous = capture;
		level = (read_diff ? LEVEL_MARK_ONLY : LEVEL_SPACE_MARK);
	if (period != 0) {
		uint32_t i = buffer_head + 1;
		if (i >= buffer_len) i = 0;
		if (i != buffer_tail) {
			buffer_value[i].level = level;
			buffer_value[i].count = period;
			buffer_head = i;
			on_new_sample(this->channel);
slomobile:
I believe the whole verbose log boiled down to:
Unable find Teensy Loader. Is the Teensy Loader application running?
If it were me, I would try reinstalling, the current beta. Make sure that Arduino is not running, and likewise the Teensy loader app.
First, let me acknowledge there is some sort of subtle synchronization bug between Arduino and Teensy Loader. I believe it's harmless, if annoying. It happens differently on Linux and Mac. It's certainly not going to be fixed for the 1.29 release.
Soon I'm going to be digging into this stuff as part and also the timing of reboots in the K66 beta, so there's a good chance I'll manage to find and fix this issue (for all boards) within the coming month or two. I really wish I had something more definitive to say on this matter right now, but the best I can give you at this moment is that I've seen it here occasionally. This sort of infrastructure code rarely gets much attention, but I'm definitely going to be looking into these details as we move from round 2 to 3 in the K66 beta.
@KurtE almost. The whole verbose log boiled down to:
I figured it was a subtle timing problem as Paul acknowledged, and wanted to provide any info that might help with debugging, but unfortunately did not know what might be relevant, thus verbose vomit.
Sorry if you tried to read through all that. It isn't particularly troublesome or important, just curious.
Thank you Paul.
FWIW, as long as the code is already in this thread, my modifications to the FreqMeasureMulti library worked for capturing servo pulses. Perhaps its worth looking at adding
bool begin(uint32_t pin, uint8_t mode, uint8_t bufferLength); // only to limit stale data in buffer, does not free memory, or increase buffer
uint32_t readLatest(void); // reads the most recent sample, flushes the rest
static uint16_t countToMicroseconds(uint32_t count); // convert to type used by servo library.
option to register a callback function(maybe a lower priority software interrupt) on new sample.
Needs bounds checking before being ready for the real world, but served my immediate purpose.
AudioSynthSimpleDrum needs to be added to Audio library's keywords.txt
I am a n00b and not sure if that affects more than syntax highlighting in the Arduino IDE. But I'm also getting "error: 'AudioSynthSimpleDrum' does not name a type" when trying to compile a sketch that includes a drum object from the audio design tool. Simplest sketch to replicate:
AudioSynthSimpleDrum     drum1;
actually after a little more investigation i found that this needs to be added to Audio.h to fix the compile issue:
#include "synth_simple_drum.h"
No problems on Win7 with a T3.2 and a k66 other than the audio library bug I mention in the Audio section. I've done a Pull Request on a fix.
Pete
Unable to compile with v1.69 and beta3 teensyduino on teensy 3.1/3.2
Missing 'maintainer' from library in C:\Sketches\libraries\SD
Multiple libraries were found for "SD.h"
Used: C:\Sketches\libraries\SD
Not used: C:\arduino-1.6.9\hardware\teensy\avr\libraries\SD
Not used: C:\arduino-1.6.9\libraries\SD
Multiple libraries were found for "EEPROM.h"
Used: C:\Sketches\libraries\EEPROM
Not used: C:\arduino-1.6.9\hardware\teensy\avr\libraries\EEPROM
Multiple libraries were found for "Adafruit_NeoPixel.h"
Used: C:\Sketches\libraries\Adafruit_NeoPixel
Not used: C:\arduino-1.6.9\hardware\teensy\avr\libraries\Adafruit_NeoPixel
Using library Wire at version 1.0 in folder: C:\arduino-1.6.9\hardware\teensy\avr\libraries\Wire
Using library SPI at version 1.0 in folder: C:\arduino-1.6.9\hardware\teensy\avr\libraries\SPI
Using library SD at version 1.0 in folder: C:\Sketches\libraries\SD
Using library Audio at version 1.03 in folder: C:\arduino-1.6.9\hardware\teensy\avr\libraries\Audio
Using library SerialFlash at version 0.4 in folder: C:\arduino-1.6.9\hardware\teensy\avr\libraries\SerialFlash
Using library EEPROM in folder: C:\Sketches\libraries\EEPROM (legacy)
Using library Adafruit_NeoPixel in folder: C:\Sketches\libraries\Adafruit_NeoPixel (legacy)
Using library Adafruit_Sensor at version 1.0.2 in folder: C:\arduino-1.6.9\hardware\teensy\avr\libraries\Adafruit_Sensor
Using library Adafruit_ADXL345 at version 1.0.0 in folder: C:\arduino-1.6.9\hardware\teensy\avr\libraries\Adafruit_ADXL345
I had to delete the 'Libraries' folder from my existing sketch folder. After this seems OK.
Compile Error in analog.c when trying to use overclocked F_BUS on Teensy 3.2 via uncommenting in kinetis.h :
After modifying kinetis.h as follows :
#elif (F_CPU == 96000000)
 #define F_PLL 96000000
 #ifndef F_BUS
 //#define F_BUS 48000000
 #define F_BUS 96000000
Building file: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/analog.c
Starting C compile
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Os -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=129 -DARDUINO=10609 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_FRENCH   -I"/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" -I"/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/FreqMeasureMulti" -MMD -MP -MF"core/analog.c.d" -MT"core/analog.c.o" -D__IN_ECLIPSE__=1 "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/analog.c"  -o  "core/analog.c.o"   -Wall
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/analog.c:95:2: error: #error "F_BUS must be 60, 56, 54, 48, 40, 36, 24, 4 or 2 MHz"
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/analog.c: In function 'analog_init':
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/analog.c:108:15: error: 'ADC_CFG1_8BIT' undeclared (first use in this function)
   ADC0_CFG1 = ADC_CFG1_8BIT + ADC_CFG1_MODE(0);
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/analog.c:108:15: note: each undeclared identifier is reported only once for each function it appears in
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/analog.c:115:15: error: 'ADC_CFG1_10BIT' undeclared (first use in this function)
   ADC0_CFG1 = ADC_CFG1_10BIT + ADC_CFG1_MODE(2) + ADC_CFG1_ADLSMP;
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/analog.c:122:15: error: 'ADC_CFG1_12BIT' undeclared (first use in this function)
   ADC0_CFG1 = ADC_CFG1_12BIT + ADC_CFG1_MODE(1) + ADC_CFG1_ADLSMP;
/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/analog.c:129:15: error: 'ADC_CFG1_16BIT' undeclared (first use in this function)
   ADC0_CFG1 = ADC_CFG1_16BIT + ADC_CFG1_MODE(3) + ADC_CFG1_ADLSMP;
make: *** [core/analog.c.o] Error 1
No firewall, but bitdefender free antivirus is installed. This message was generated on verify only so it shouldn't be trying to reboot the teensy anyway.
Arduino: 1.6.9 (Windows 7), TD: 1.29-beta3, Board: "Teensy 3.2 / 3.1, Serial, 96 MHz optimized (overclock), US English"
Is a firewall (eg, ZoneAlarm) blocking localhost communication?
BitDefender log reads:
Scan Results
Active Virus Control blocked a process.
Scan Results
File Name Action
c:\arduino169\hardware\tools\teensy_reboot.exe Blocked
Note: there are times when I am getting some strange interactions with Teensy Loader and Debug Monitor.
Running current beta+ (updated cores) 1.6.9.
On Teensy 3.1 board, at times not wanting to program first time after I plug in. Then if I hit button, it uploads correctly, but if I hit Debug Monitor, it shows a debug monitor window with no COmm port associated with it.
Arduino Message area shows:
Sketch uses 37,860 bytes (14%) of program storage space. Maximum is 262,144 bytes.
Global variables use 5,920 bytes (9%) of dynamic memory, leaving 59,616 bytes for local variables. Maximum is 65,536 bytes.
C:\arduino-1.6.9\hardware\teensy/../tools/teensy_post_compile -test -file=RC_Receiver_Attach_PulsePosition.ino -path=C:\Users\Kurt\AppData\Local\Temp\buildfa34247fa2405ad6e06d0c9b490f31c5.tmp -tools=C:\arduino-1.6.9\hardware\teensy/../tools -board=TEENSY31 -reboot
Teensy did not respond to a USB-based request to automatically reboot.
no serial port name defined
Yet bottom Arduino status shows. Teensy 3.2/3.1, Serial, 120mhz optimized(overclock), US English on COM20.
After this, if I close debug monitor and try to reopen, sometimes it looks like a partially drawn window, does not respond, takes a long time to close,
Sometimes when I see this the main Arduino window will show something like:
Error while setting serial port parameters: 115,200 N 8 1
Will try to localize when this might happen...
Edit: Probably when my app is doing lots of Serial.print... stuff. Once I download blink app, it works again
Starting C compile
Should be ok with an update ("core") from Github - this is fixed already.
#error "F_BUS must be 120, 108, 96, 90, 80, 72, 64, 60, 56, 54, 48, 40, 36, 24, 4 or 2 MHz"
Sorry for a mostly Windows question: Right now I have Arduino 1.6.6 + Teensyduino 1.26 beta 3 installed. I did that when I was running Windows 7. Recently I upgraded the laptop from Win7 to Windows 10. That seemed to work OK. Now I want to uninstall 1.6.6 so I can install the current Arduino 1.6.9 and current Teensyduino 1.29 b3, but I cannot. In Win10 System/Settings/Apps & Features, I found Arduino and there is an "Uninstall" button. Clicking that pops up a box with another button: "This app and its related info will be uninstalled. <uninstall>" but clicking that button does exactly nothing. I seem to be stuck. I am administrator on this machine.
I assume you can run the IDE right now? If so is it from a shortcut - does properties show the directory in 'C:\Program Files (x86)'?
Did you do a 'true' install - that is, is there is a "C:\Program Files (x86)" directory for Arduino 1.6.6? In that directory is there anything like 'uninst*.exe'? Can you run it if so? Is all of Arduino (and JAVA, TeensyDuino) out of memory? Not open? Windows Restarted?
If not what happens if you just run the 1.6.9 installer and point to the same directory? If not, maybe redo 1.6.6 over that install? If that fails - go into "C:\Program Files (x86)" and rename 'Arduino?' to "XXX_Arduino" then do the install to the same directory as before.
Not being able to see it - I think those are safe best steps in the right order. Something moved the uninstall.exe from where it was registered - or the Win_10 upgrade lost track of it.
I did the installer the first couple times last year when I started on 1.6.0 with Beta - I quickly stopped and only pull down the ZIP and extract that now. I put it safely on another drive/partition or anywhere but 'Program...' and never use anything in '...documents...'
Thanks for the notes! In the past I've installed many versions of Arduino, and at one point must have simply copied one version over another without properly installing. My 1.6.6 is in C:\Program Files (x86)\Arduino and sure enough, there is no uninstall.exe there. When running the 1.6.9 installer, it says "Arduino 1.6.0 is still installed. [...] Click OK to uninstall from C:\Program Files (x86)\Arduino" (note: not 1.6.6). Clicking OK does nothing. Simply downloading the 1.6.9 zip file and copying over, instead of using the installer, solved the problem.
