Novice questions about sound-reactive wearable project
skaurus
Hi!
I am looking to build yet-another sound-reactive wearable project (t-shirt with leds) for upcoming trance music festival :)
This is my first experience with Arduino's or microelectronics at all. No wonder I have a list of questions I need to find answers for to build it. I am trying to research it myself as well as I could but sometimes, being a novice, I have to ask others.
So, maybe you could give me some input about what microphone should I choose? It seems they all not that expensive so lets try to rule out price. I need a good resolution for doing FFT, low noise and it must work in a loud settings (festival after all...). Generally - best quality small-size microphone :)
Most probably I would be using Teensy 3.2 with it. Amazing possibilities for its price, size and power requirements!
At least at what specs should I look? Electret, mems, other type? Maybe "big" one like lavalier would work even better?
Probably best to start with the normal electret mic and the audio shield.
http://www.pjrc.com/store/microphone.html
For use in a wearable project, especially worn while dancing at a festival, the way to position the mic will make far more difference than the type of mic. Even these cheapest electret ones will have a noise floor that's far less than the noise you'll pick up from ruffling of clothes & costumes.
I do not know if that mic works with the audio lib. It might, or it might need a longer than 16 bit word format. The page says 24 bits. I can tell you the I2S code we have now uses 16 bits per LRCLK phase, not 24 or 32.
To get started, I recommend the well traveled path of the audio board and electret mic. You can always try to switch to a different mic later. By then, you'll have gained quite a lot of experience with the rest of the project, which should make these decisions clearer.
Oh. Not so promising then!
I will follow your advice. So, Teensy, Audio board, two 14x1-D pins and microphone?
edit: um, my time requirements and your shipping prices are quite incompatible it turns out! I've ordered Teensy and Audio board from another seller. No double insulator pins though... I'll think up something :)
Hello again.
Does 3.5" input jack on Audio board have "Plug in Power"? It is required for some external microphones.
Also it may be useful to know - is this jack wired OMTP way or CTIA / AHJ way?
Note, the 3.5" jack on the audio board is an output jack for sound output to headphones. There are line in pins and pins for a microphone, but these don't include a power pin.
Thanks for your reply.
Oh. So to connect some external microphone I will have to solder appropriate jack?
Yes, or at least solder wires to connect to the microphone. There is a microphone input/ground in the center of the board, plus left/right line-in pins on one side. I would imagine you could also hook up an i2s microphone to the audio shield.
If you wanted a basic microphone, PJRC sells one with a little custom washer that is made for the audio shield: http://www.pjrc.com/store/microphone.html
Onehorse makes a i2s microphone that is meant to attach to a Teensy, but I don't know if it would work with the audio shield: https://www.tindie.com/products/onehorse/ics43432-i2s-digital-microphone/?pt=full_prod_search.
@MM - the onehorse i2s mic was noted above p_3 - it is 24 bits ...
Question: The MIC section I assume has a suitable amp circuit to support the electret mic? What levels are 'line in'? My limited understanding suggests the line in would expect something driven to the level of a 'Mic on a breakout' with needed pre-amplification?
Also not sure if I read this right - but was it once stated - in this context - that the headphone output shouldn't be put into a amplifier system of a typical pc speaker system type arrangement?
Well, I had to order Teensy from another store and they didn't have this mic.
And then I found that for most of the mics I could buy near me (I'm outside of the USA) I can't even find datasheet.
Maybe I just don't know proper stores here, but anyway, I wasn't bothered much since I was going to use lavalier microphone with mini jack (1⁄8 in) for better quality.
Now, it turns out, it isn't so simple :) Can you confirm that I can (or can't) solder mini jack to line in R + L + 2xG pins and connect external microphone to it? Will it work or I will need some kind of amplifier or what else? If yes (I hope so!) maybe you can explain what solder to what? I find it hard to find microphone jack pinout :confused:
I guess MIC+GND pins are for microphones like from PRJC store only, not for "big" ones with mini jack?
Yeah, I know... Maybe it was a mistake to not order it at the same time as Teensy and now I can't - due to my project time restrictions :-(
Maybe I can solder microphone audio jack directly to MIC+GND pins and it will work?
Yes! I soldered audio jack, inserted microphone in and it works!
And pretty well :)
Cheap random lavalier model: Panasonic RP-VC201
