maximum file name size in characters on sd card
mubase
Hi guys. We have loads of Teensy audio boards and 3.2 boards for a project. We were just wondering if there is a size limit to the names of the wav files on the sd card. For instance, if I have a file called 123456789.wav, is that too big? Is there a limit to the number of characters you can use in your .wav file names?
Any help appreciated,
thanks,
Steve. x
The Arduino SD library only supports DOS 8.3 filenames. If you keep your names to 8 or fewer chars and only use uppercase, things are much easier.
OK Thanks again for your help Paul. :)
Also I just got the Demosauce sketch for the 2.2 TFT LCD working. :cool: Very nice!! As good as any Amiga Demo I ever saw.
Does that include suffix? For example is it:
“FILENAME” (8 chars) + “.TXT” (4 chars)
or
“NAME” (4 chars) + “.TXT” (4 chars)
