View Full Version : Teensyduino 1.30 Beta #2 Available
Here is a second beta test for Teensyduino 1.30.
Arduino 1.6.10 has issues with some AVR-based boards (not Teensy). The Arduino devs are expected to release version 1.6.11 soon. I indent to hold off finalizing Teensyduino 1.30 until they've published 1.6.11 and we can test against 1.6.11 for at least a few days. Teensyduino 1.30 is likely to drop support for Arduino 1.6.10 after 1.6.11 is released.
Edit: old beta test linkes removed. Full non-beta release is here:
Changes since Teensyduino 1.30-beta1:
Fix for Teensy-LC (broken by recent K66 updates)
More K66 updates
Libraries updated: Audio, ADC, i2c_t3, IRremote
KurtE
08-03-2016, 02:21 PM
For the fun of it I tried installing Arduino 1.6.10 on an Odroid C2 which I installed a fresh copy of Ubuntu 16.04 (ARM 64 bit), to see if the 32 bit arm version would run on it, as I was earlier able to get the daily Arduino to run on the board, but I had played around a lot so was not sure what was needed...
The problem is their ARM version is setup to run 32 bit java and other stuff, so it needs the 32 bit versions of the libraries it uses...
I was able to get the basic Arduino to run by adding: sudo apt-get install libxtst6:armhf
Next up Teensyduino 1.30 beta 2... I downloaded it and it would not run. Was able to get it to run by
adding: sudo apt-get install libxft2:armhf
Started up Arduino, loaded blink, plugged T3.2 into C2 and clicked upload. The program compiled, but the Teensy loader failed to load. Tried in command line and the reboot also failed to load. Fixed by
adding: sudo apt-get install libusb-0.1-4:armh
Still failed until I added the udev rules. But now my Teensy is blinking :D
Note: it sometimes fails to program and I need to hit program button...
1101010
08-06-2016, 02:55 AM
Audio.h still needs
#include "synth_simple_drum.h"
to make AudioSynthSimpleDrum work, and keywords.txt needs
AudioSynthSimpleDrum KEYWORD2
(plus maybe some methods of AudioSynthSimpleDrum)
PaulStoffregen
08-06-2016, 04:11 AM
Done
https://github.com/PaulStoffregen/Audio/commit/9c57e1cb19476abc264d3a0f9289a26787fd32c7
Firepixie
08-06-2016, 05:23 PM
Won't let me install this.. here's what I get when I click the ? button:
Checking Arduino 1.6.10:
version: "Contents/Java/lib/version.txt" file missing
Does not match Arduino 1.6.10
PaulStoffregen
08-06-2016, 06:38 PM
Every copy of Arduino is supposed to have that version.txt file. Perhaps your copy got corrupted or damaged somehow? Maybe try downloading a fresh copy from Arduino.cc?
Also, please be aware Arduino 1.6.10 is going to be replaced with 1.6.11 sometime next week. Teensyduino will drop support for 1.6.10 when that happens. Unless you have an urgent need, might be simplest to just wait to upgrade.
Firepixie
08-06-2016, 06:48 PM
Hmm it was a fresh download.. perhaps I'll just wait. Thanks!
Markus_L811
08-10-2016, 08:14 PM
I rewrite the RTC-Libray for the Arduino DUE and added it to the library and add it to the Library-Manager from the IDE, I modified your TimeArduinoDue.ino, Paul can you add it to your time library?
* TimeArduinoDue.pde
* example code illustrating Time library with Real Time Clock.
* This example requires Markus Lange's Arduino Due RTC Library
* https://github.com/MarkusLange/RTCDue
#include <TimeLib.h>
#include <RTCDue.h>
// Select the Slowclock source
//RTCDue rtc(RC);
RTCDue rtc(XTAL);
rtc.begin();
if (rtc.isDateAlreadySet() == 0) {
// Unfortunately, the Arduino Due hardware does not seem to
// be designed to maintain the RTC clock state when the
// board resets. Markus described it thusly: "Uhh the Due
// does reset with the NRSTB pin. This resets the full chip
// with all backup regions including RTC, RTT and SC. Only
// if the reset is done with the NRST pin will these regions
// stay with their old values."
rtc.setTime(__TIME__);
rtc.setDate(__DATE__);
// However, this might work on other unofficial SAM3X boards
// with different reset circuitry than Arduino Due?
setSyncProvider(getArduinoDueTime);
if(timeStatus()!= timeSet)
Serial.println("Unable to sync with the RTC");
Serial.println("RTC has set the system time");
time_t getArduinoDueTime()
return rtc.unixtime();
digitalClockDisplay();
void digitalClockDisplay(){
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(day());
Serial.print(" ");
Serial.print(month());
Serial.print(" ");
Serial.print(year());
void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
Hope you like it.
dikkedimi
08-11-2016, 04:27 PM
Ok so I bought a teensy, to use as midi control for an analog synth. Installed Teensyduino in my Arduino 1.6.10 IDE. Managed to upload one sketch using serial. But now, when put into program mode by pushing the button, I can't upload another sketch.
Using Arduino + Teensyduino on a mac I get the following error:
"Teensy did not respond to a USB-based request to automatically reboot.
Please press the PROGRAM MODE BUTTON on your Teensy to upload your sketch."
I already tried the following:
- Unplugging the teensy, rebooting, plugging in the teensy, press program mode button, start up IDE. -> No success.
- Repeating the same, but with a different USB port on the same system. -> No success.
- Tried it on a windows machine. Did not work. -> No success
- Tried it on another USB port, on the windows machine. -> no success.
I use the stable build of the arduino IDE. The latest Mac OS X (10.11.6), the latest Windows 10 updates.
PaulStoffregen
08-11-2016, 04:50 PM
I'm confused. Is this a mac or windows computer?
Do not use a virtual machine. The USB emulation in virtual machines is often problematic for Teensy's quick rebooting, where it disconnects and reconnects as another device.
Also, please understand Teensy Loader always uses HID protocol for uploading, not serial. More details here:
http://www.pjrc.com/teensy/troubleshoot.html
dikkedimi
08-11-2016, 06:31 PM
Turns out my issue was due to a charging only cable. N00b oversight. Now it works like a charm! my complements for integrating it into the arduino IDE :)
now I can get going with this again http://www.marc-nostromo.com/midi-control-for-the-monotron-using-a-teensy-3-0/#comment-109498
Frank B
08-13-2016, 11:35 AM
Paul, is it possible to include the mmCau library ?
http://www.nxp.com/products/microcontrollers-and-processors/more-processors/coldfire-plus-coldfire-32-bit-mcus/coldfire-plus-mcus/crypto-acceleration-unit-cau-and-mmcau-software-library:CAUAP?code=CAUAP&nodeId=0150522F50YTLC9804&fpsp=1&tab=Design_Tools_Tab
It's a precompiled *.a (the assembler-source is included in the download) and a header-file.
Possible issue with teensy_reboot:
Observation:
programs compiled for Serial-Midi break Arduino reprogram feature, requiring button press.
System PC win10, A1.6.9, TD 1.29
test procedure (using Arduino IDE):
download blink.hex compiled with Serial.
download succeeds, will generate, say com19
download blink.hex compiled with Serial-MIDI
download succeeds, will generate midi (new device for me) and, say com8 (as PID is different, windows will generate different com port)
download again blink.hex compiled with Serial
download fails, requires button press, but com8 is clearly indicated.
(to avoid button press, I opened com8 on terminal with baud 134, which put T3.2 into program mode)
TD downloads blink.hex
download succeeds, will generate, again com19
My hunch is, that teensy_reboot.exe, needs upgrade.
PaulStoffregen
08-13-2016, 06:45 PM
Let's do this as a library from source. Here's a first attempt...
https://github.com/PaulStoffregen/CryptoAccel
Markus_L811
08-13-2016, 07:47 PM
A way to use ssh with the teensy, not only telnet?
PaulStoffregen
08-13-2016, 09:04 PM
SSH requires much more. This could be used as one small piece, but among many other things needed are asymmetric cyphers for key exchange. This library is limited to only computing a few specific symmetric ciphers and one-way hashes. Even for those ciphers, it only does the basic computation. You'd still need to add at least block chaining since ECB mode is not secure.
Frank B
08-13-2016, 09:53 PM
Great, thank you!
Wozzy
08-14-2016, 07:06 PM
Update: Problem Solved by disabling Trend Micro Internet & Micro Security Version 10.0.1288 (see #38 (https://forum.pjrc.com/threads/35700-Teensyduino-1-30-Beta-2-Available?p=113263&viewfull=1#post113263))
I am setting up a new Arduino installation on my Windows 10 PC to start testing my Teensy 3.6
I created a new directory and unzipped the latest Arduino 1.6.10 download into it.
I applied Teensyduino 1.30 Beta 2 without problems.
I have the new boards.txt file from post 910 of the K66 thread but the problem occurs both with the K66 boards.txt file and the Teensyduino 1.30B2 boards.txt file.
For now I'm just working with a Teensy 3.2.
It seems like Arduino is trying to recompile the entire core even when just trying to run the blink example.
This takes close to 20 minutes.
Here's an example verbose output from the Arduino console:
C:\Arduino1610Teensyduino130B2\arduino-builder -dump-prefs -logger=machine -hardware "C:\Arduino1610Teensyduino130B2\hardware" -hardware "C:\Users\Bob\AppData\Local\Arduino15\packages" -tools "C:\Arduino1610Teensyduino130B2\tools-builder" -tools "C:\Arduino1610Teensyduino130B2\hardware\tools\avr" -tools "C:\Users\Bob\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Arduino1610Teensyduino130B2\libraries" -libraries "C:\Users\Bob\Documents\Arduino\libraries" -fqbn=teensy:avr:teensy31:usb=serial,speed=96opt,ke ys=en-us -ide-version=10610 -build-path "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp" -warnings=default -verbose "C:\Arduino1610Teensyduino130B2\examples\Teensy\Tut orial1\Blink\Blink.pde"
Compiling libraries...
Compiling core...
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\memcpy-armv7m.S" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\memcpy-armv7m.S.o"
C:\Arduino1610Teensyduino130B2\arduino-builder -compile -logger=machine -hardware "C:\Arduino1610Teensyduino130B2\hardware" -hardware "C:\Users\Bob\AppData\Local\Arduino15\packages" -tools "C:\Arduino1610Teensyduino130B2\tools-builder" -tools "C:\Arduino1610Teensyduino130B2\hardware\tools\avr" -tools "C:\Users\Bob\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Arduino1610Teensyduino130B2\libraries" -libraries "C:\Users\Bob\Documents\Arduino\libraries" -fqbn=teensy:avr:teensy31:usb=serial,speed=96opt,ke ys=en-us -ide-version=10610 -build-path "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp" -warnings=default -verbose "C:\Arduino1610Teensyduino130B2\examples\Teensy\Tut orial1\Blink\Blink.pde"
Using board 'teensy31' from platform in folder: C:\Arduino1610Teensyduino130B2\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Arduino1610Teensyduino130B2\hardware\teensy\avr
Detecting libraries used...
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\sketch\Blink.pde.cpp" -o "nul"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\memset.S" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\memset.S.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\sketch\Blink.pde.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\preproc\ctags_target_for_g cc_minus_e.cpp"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\analog.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\analog.c.o"
"C:\Arduino1610Teensyduino130B2\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\preproc\ctags_target_for_g cc_minus_e.cpp"
Compiling sketch...
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\sketch\Blink.pde.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\sketch\Blink.pde.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\eeprom.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\eeprom.c.o"
Compiling core...
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\memcpy-armv7m.S" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\memcpy-armv7m.S.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\keylayouts.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\keylayouts.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\memset.S" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\memset.S.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\math_helper.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\math_helper.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\analog.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\analog.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\mk20dx128.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\mk20dx128.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\eeprom.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\eeprom.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\nonstd.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\nonstd.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\keylayouts.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\keylayouts.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\pins_teensy.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\pins_teensy.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\math_helper.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\math_helper.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\ser_print.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\ser_print.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\mk20dx128.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\mk20dx128.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\serial1.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\serial1.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\nonstd.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\nonstd.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\serial2.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\serial2.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\pins_teensy.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\pins_teensy.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\serial3.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\serial3.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\ser_print.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\ser_print.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\serial4.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\serial4.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\serial1.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\serial1.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\serial5.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\serial5.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\HardwareSerial6.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\HardwareSerial6.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\Stream.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\Stream.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\IPAddress.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\IPAddress.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\Tone.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\Tone.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\IntervalTimer.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\IntervalTimer.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\WMath.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\WMath.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\Print.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\Print.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\WString.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\WString.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\Stream.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\Stream.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\avr_emulation.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\avr_emulation.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\Tone.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\Tone.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\main.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\main.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\WMath.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\WMath.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\new.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\new.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\WString.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\WString.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\usb_audio.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_audio.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\avr_emulation.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\avr_emulation.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\usb_flightsim.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_flightsim.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\main.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\main.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\usb_inst.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_inst.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\new.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\new.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\yield.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\yield.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\usb_audio.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_audio.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\memcpy-armv7m.S.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\memset.S.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\analog.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\usb_flightsim.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_flightsim.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\eeprom.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\keylayouts.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\math_helper.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\usb_inst.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_inst.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\mk20dx128.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\nonstd.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\pins_teensy.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr \cores\teensy3\yield.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\yield.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\ser_print.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\serial1.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\serial2.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\memcpy-armv7m.S.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\serial3.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\memset.S.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\serial4.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\analog.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\serial5.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\eeprom.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\serial6.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\keylayouts.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\serial6_lpuart.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\math_helper.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\touch.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\mk20dx128.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_desc.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\nonstd.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_dev.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\pins_teensy.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_joystick.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\ser_print.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_keyboard.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\serial1.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_mem.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\serial2.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_midi.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\serial3.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_mouse.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\serial4.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_mtp.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\serial5.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_rawhid.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\serial6.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_seremu.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\serial6_lpuart.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_serial.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\touch.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_touch.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_desc.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\AudioStream.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_dev.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\DMAChannel.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_joystick.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\HardwareSerial1.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_keyboard.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\HardwareSerial2.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_mem.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\HardwareSerial3.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_midi.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\HardwareSerial4.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_mouse.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\HardwareSerial5.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_mtp.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\HardwareSerial6.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_rawhid.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\IPAddress.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_seremu.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\IntervalTimer.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_serial.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\Print.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_touch.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\Stream.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\AudioStream.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\Tone.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\DMAChannel.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\WMath.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\HardwareSerial1.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\WString.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\HardwareSerial2.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\avr_emulation.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\HardwareSerial3.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\main.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\HardwareSerial4.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\new.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\HardwareSerial5.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_audio.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\HardwareSerial6.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_flightsim.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\IPAddress.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\usb_inst.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\IntervalTimer.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\core\yield.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\Print.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1471185117 "-TC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3/mk20dx256.ld" -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp\sketch\Blink.pde.cpp.o" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/core\core.a" "-LC:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d5 17cca58e20d969e006a7.tmp" -larm_cortexM4l_math -lm
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\Stream.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\Tone.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\WMath.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/Blink.pde.eep"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\WString.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d51 7cca58e20d969e006a7.tmp/Blink.pde.hex"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\avr_emulation.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools//teensy_post_compile" "-file=Blink.pde" "-path=C:\Users\Bob\AppData\Local\Temp\buildb0adeeb3 23d517cca58e20d969e006a7.tmp" "-tools=C:\Arduino1610Teensyduino130B2\hardware\teen sy/../tools/" "-board=TEENSY31"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\main.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\new.cpp.o"
Sketch uses 14,292 bytes (5%) of program storage space. Maximum is 262,144 bytes.
Global variables use 3,536 bytes (5%) of dynamic memory, leaving 62,000 bytes for local variables. Maximum is 65,536 bytes.
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_audio.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_flightsim.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\usb_inst.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\core\yield.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1471185188 "-TC:\Arduino1610Teensyduino130B2\hardware\teensy\av r\cores\teensy3/mk20dx256.ld" -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp\sketch\Blink.pde.cpp.o" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/core\core.a" "-LC:\Users\Bob\AppData\Local\Temp\build10d9ede01f91 cc9811b250df4f403d55.tmp" -larm_cortexM4l_math -lm
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/Blink.pde.eep"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91c c9811b250df4f403d55.tmp/Blink.pde.hex"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools//teensy_post_compile" "-file=Blink.pde" "-path=C:\Users\Bob\AppData\Local\Temp\build10d9ede0 1f91cc9811b250df4f403d55.tmp" "-tools=C:\Arduino1610Teensyduino130B2\hardware\teen sy/../tools/" "-board=TEENSY31"
Sketch uses 14,212 bytes (5%) of program storage space. Maximum is 262,144 bytes.
C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/teensy_post_compile -test -file=Blink.pde -path=C:\Users\Bob\AppData\Local\Temp\build10d9ede0 1f91cc9811b250df4f403d55.tmp -tools=C:\Arduino1610Teensyduino130B2\hardware\teen sy/../tools -board=TEENSY31 -reboot
Settings are;
Board: Teensy 3.1/3.2
USB: Serial
Keyboard layout: US English
CPU speed: 96 MHz optimize speed (overclock)
Port: COM5
Does anyone know what may be going on here?
Everything is still fine with my 1.6.9 setup.
Thanks
Wozzy
08-15-2016, 12:30 AM
I'm still not having any luck.
It's taking over 20 minutes each time I try to build a sketch with Arduino 1.6.10
The same Blink sketch in Arduino 1.6.9 takes under 5 seconds to build.
I verified that the sketch folder is not read-only as discussed here https://forum.pjrc.com/threads/34233-Build-options-changed-rebuilding-all
I going to try and redownload and reinstall Arduino again this time using the installer.
Edit: Well that didn't work either.
Update: Problem Solved by disabling Trend Micro Internet & Micro Security Version 10.0.1288 (see #38 (https://forum.pjrc.com/threads/35700-Teensyduino-1-30-Beta-2-Available?p=113263&viewfull=1#post113263))
Zekiel
08-15-2016, 06:10 AM
Arduino 1.6.10 + Beta Teensyduino + WS8211 = SAD
FYI, I just spent today trying to figure out what I broke and/or where all the signal noise was coming from. Turn out that Ardunio 1.6.10 + the Teensyduino beta does not produce correct code to drive OctoWS2811. I tried plain FastLED, OctoWS2811 (dma), and a vast array of combinations of cables, Teensy's, level shifters, power supplies, etc :)
Downgrading to Arduino 1.6.9 and the non-beta Teensyduino fixed it.
PaulStoffregen
08-15-2016, 09:05 AM
Can you save me some time by posting the code to reproduce this problem?
PaulStoffregen
08-15-2016, 09:14 AM
Yikes, 20 minutes is horrible.
Does 1.6.10 do this for Arduino Uno or Arduino Due, or only when compiling for Teensy?
Wozzy
08-15-2016, 10:24 AM
I don't have any Arduinos to test on, only Teensys. I'll see if I can borrow one from a friend.
PaulStoffregen
08-15-2016, 10:46 AM
No need for a real Arduino. Just select it in the Tools > Boards menu and then click Verify. We're just looking for the compile time, right?
Wozzy
08-15-2016, 12:04 PM
Yes, good point. Tonight, I'll reload a fresh Arduino 1.6.10, then try to "verify" before and after applying the Teensyduino 1.30B2 update.
bperrybap
08-15-2016, 09:10 PM
Paul,
I'm curious as to how you intend to handle the IDE 1.6.10 AVR PIN_A0 to PIN_A7 names that collide with existing Teensy++ defines.
There is no way to fully resolve this to support both the new 1.6.10 IDE analog pin defines and and be fully backward compatible with Teensy PORTA pin defines.
One or the other "wins".
While you won't have actual collisions from #define redeclarations since the names come from the variant files which you control for teensy++, there will be the issue that if someone uses something like PIN_A0 and expects it to be the same as using A0, their code will break.
And it has the potential to create some confusion since An and PORT_An are not the same pin like all the other arduino boards.
i.e. A0 will be PORTF0 and PIN_A0 will PORTA0 whereas on all other Arduinos PIN_A0 and A0 are the same physical pin.
In my avrio code I also have this same issue and have decided to take the unfortunate 1 time hit to change the raw port pin define names
from PIN_Pb notation to AVRPIN_Pb notation. It REALLY sucks as it breaks all the existing code that happened to use PIN_Pb but I never want to deal wit this again
and it will also allow users to use the new PIN_An names to indicate the analog ports - well except on Teensy++, unless you also make some kind of change.
It also has a nice benefit in that the name tends to reflect that it is AVR specific.
I came to the conclusion that it becomes a documentation and support issue or you get shafted with a backward compatibility hit.
It sucks either way.
I went round and round before I finally decided to just take the backward compatibility hit,
and unlike some of the arduino.cc core developers, I take backward compatibility very seriously.
--- bill
Zekiel
08-16-2016, 01:57 AM
Yep sorry for being vague.
I used OctoWS2811Demo (Examples->FastLED->Multiple->OctoWS2811Demo) most of the time but also tried a few others such as OctoWS2811->Rainbow and BasicTest I think. They all showed the same problem of barely lighting up the first few LEDs, if at all.
Patched OctWS2811Demo code that blinks LED for sanity check. It fails on 1.6.10 + beta teensyduino and worked right away on 1.6.9 and stable teensyduino.
AND!!! Huge cheers for helping us make cool stuff Paul :)
#define USE_OCTOWS2811
#include<OctoWS2811.h>
#include<FastLED.h>
#define NUM_LEDS_PER_STRIP 100
#define NUM_STRIPS 8
CRGB leds[NUM_STRIPS * NUM_LEDS_PER_STRIP];
int led = 13;
int on = 0;
// Pin layouts on the teensy 3:
// OctoWS2811: 2,14,7,8,6,20,21,5
LEDS.addLeds<OCTOWS2811>(leds, NUM_LEDS_PER_STRIP);
LEDS.setBrightness(32);
pinMode(led, OUTPUT);
static uint8_t hue = 0;
for(int i = 0; i < NUM_STRIPS; i++) {
for(int j = 0; j < NUM_LEDS_PER_STRIP; j++) {
leds[(i*NUM_LEDS_PER_STRIP) + j] = CHSV((32*i) + hue+j,192,255);
// Set the first n leds on each strip to show which strip it is
for(int j = 0; j <= i; j++) {
leds[(i*NUM_LEDS_PER_STRIP) + j] = CRGB::Red;
hue++;
LEDS.show();
LEDS.delay(10);
on++;
digitalWrite(led, (on % 40) ? LOW : HIGH);
Wozzy
08-16-2016, 02:47 AM
Following up from earlier.
So I did the following:
Restored Windows to an earlier date (just prior to the first Arduino1.6.10 install)
Re-download and installed Arduino 1.6.10 from the Windows installer.
Compiled (using verify) Blink with Board set to Arduino Uno - Program compiled quickly and without errors
Compiled Blink with Board set to Arduino Due - Program compiled quickly and without errors
Re-downloaded Teensyduino 1.30B2 and applied it to the Arduino 1.6.10 installation
Compiled Blink with Board set to Arduino Uno - Program compiled quickly and without errors
Compiled Blink with Board set to Teensy 2.0 - Program compiled quickly and without errors
Compiled Blink with Board set to Teensy 3.1/3.2 - Program compiled very slowly and rebuilt the Core as discussed above.
Re-download the K66 Boards.txt file and copied it to ~Arduino1610/hardware/teensy/avr/
Compiled Blink with Board set to Teensy 3.6 - Program compiled very slowly and rebuilt the Core as discussed above.
Using Arduino 1.6.9, compiled Blink with Board set to Teensy 3.1/3.2 - Program compiled quickly and without errors
I'm not sure what to try next. Is anyone else having this problem with 64 bit Windows 10?
I have a bunch of older Arduino installations (each in a separate directory), They seem to work fine, and I'm hesitant to remove them as some are modified for special projects.
Thanks
defragster
08-16-2016, 03:06 AM
Wozzy - with the note that 1.6.10 should be short lived I never left 1.6.9 [on win10x64] as time was too short to play with beta hardware already without asking for grief, like you all is well in 1.6.9. Even a rebuild full compile under a minute on my slow i5.
Odd and bad behavior - what do you have in the Boards Manager section? That is GLOBAL across IDE right? Maybe something there is treated oddly in the 1.6.10?
KurtE
08-16-2016, 03:19 AM
I have 1.6.10 plus 1.30.beta2 W10 64 bit... And I build Blink, I tried for T3.6 as well as T3.2 and the verify takes under a minute. About 5 year old I7..
Have you tried running Task manager.
Warning, however I am running a modified 1.6.10 after Paul mentioned that there was a test version of arduino-builder.exe which hopefully tried to keep from rebuilding everything...
But Can not find that posting anymore...
Wozzy
defragster- The boards managers seem similar between my 1.6.9 and 1.6.10 Arduino installations.
Just for grins I rolled back the Uno and Due versions defaulted in my 1.6.10 installation to be the same as 1.6.9, but that didn't solve the problem.
Wozzy
08-16-2016, 03:32 AM
Hmmm... This modified arduino-builder intrigues me.
Task manager shows no unusual activity... actually I use Process Explorer (https://technet.microsoft.com/en-us/sysinternals/processexplorer.aspx) from Microsoft TechNet - Highly recommended!
Thanks
--Wozzy
defragster
08-16-2016, 05:04 AM
KurtE - I lost track of that compile speedup posting too?? Almost considered 1.6.10 to try it.
Wozzy - that was the only 'innocent'/simple but global thing that came to mind - hoped it might inspire something. Otherwise 1.6.10 seems like it might be double plus ungood. Is it the CORE recompile that runs the time toward 10 minutes? After the LONG Teensy compile - do the Uno/Due compile again normally or did it break the tree they use too?
Wozzy
08-16-2016, 10:42 AM
defragster,
Yes almost all the time is spent with compiling core.
Even after compiling for 3.1/3.2/3.6 it still works normally for Uno/Due/T2.0.
I guess it's time to punt back to Arduino 1.6.9 until 1.6.11 is ready,
Other than the K66 Boards.txt change, are there any other must-do's required for Teensy 3.6 under Arduino 1.6.9?
defragster
08-16-2016, 11:24 AM
Reading that I wonder if the 1.6.10 issue WRT default tools /processor {Paul linked to} is getting confused now with the ARM is AVR placement Paul does is getting confused?
KurtE
08-16-2016, 02:07 PM
Wozzy, you probably already tried this, but have you:
Removed install of 1.6.10, reinstall, Install Teensyduino stuff. Rename your Arduino sketch folder to something else (or at least the libraries) and tried building?
i.e. maybe there is some form of conflict between libraries installed by this beta and other stuff you have installed?
Wozzy
08-25-2016, 02:43 AM
Sorry, I was out of town for several days.
I updated to Arduino 1.6.11 and Teensyduino 1.30 b3 and I'm still having the same problem as noted above.
I restored my PC to a date before I loaded 1.6.10 + 1.30 b2 then installed a freshly downloaded Arduino 1.6.11 and Teensyduino 1.30 b3.
I let the installer use all default locations this time.
It still works fine with Uno and Teensy 2.0, But rebuilds the core (very slowly) every time with the ARM boards.
I noted two possible clues.
1) is that I also see it doing the following processes (verbose) with 1.6.11 but not 1.6.9:
These processes happen very quickly with Uno and Teensy 2.0, but very slowly with the ARM boards
Detecting libraries used...
Compiling sketch...
Compiling libraries...
Compiling core...
2) is that if I swap in the 1.6.9 C:\Program Files (x86)\Arduino\hardware\tools directory to 1.6.11, then the Uno and T2.0 boards also compile very slowly.
Everything is still working as normal with 1.6.9
This is becoming very frustrating as I'm unable to try all the updated Teensy 3.6 modifications.
Wozzy
08-25-2016, 09:04 PM
OK... I finally solved the problem by Disabling Trend Micro Security Version 10.0.1288.
It's very odd that it only affects compiling for ARM devices with Arduino versions after 1.6.9.
With the virus scanner disabled, I'm back to 4 to 5 second compile times with Arduino 1.6.11 with Teensyduino 1.30 B3.
I have to completely disable the Trend Micro Virus scanner.
I tried to add the following folders to the exception list, but It doesn't help. I couldn't find any info about if the Trend Micro program handles subfolders recursively.
C:\Arduino1611Teensyduino130B3
C:\Users\Bob\AppData\Local\Arduino15
C:\Users\Bob\AppData\Roaming\Arduino15
C:\Users\Bob\AppData\Local\Temp\builda44fb12b0eba7 c0e7e6f3fadbd5c9e7e.tmp
C:\Users\Bob\Documents\Arduino
Anyway... I'm happy now and can move on to trying out the Teensy 3.6
Thanks to all who helped along the way.
Frank B
08-29-2016, 08:09 PM
Let's do this as a library from source. Here's a first attempt...
https://github.com/PaulStoffregen/CryptoAccel
I had some trouble to use it, because it wants the *.s files to be *.S (uppercase) and i had to rename it (?!).
Then, i guess we need some additional functions. Today, i played a bit with MD5. It needs a special padding (see wikipedia md-5 page) which is not trivial to do fast in a potential library since it is needed to extend the last block with padding bytes.
PaulStoffregen
10-31-2016, 07:57 AM
My hunch is, that teensy_reboot.exe, needs upgrade.
Yes, it doesn't know about many of the newer USB Types.
1.31-beta3 will have fully updated teensy_reboot. I just tested it (and teensy_gateway) on all 3 systems with all Tools > USB Type settings.
