MacroMachines
I've been working on a project using the teensy/audio and FV-1 effects chip, and in the process I am learning many efficient techniques to make assembler dsp code for the FV-1. I just found a sine/cosine oscillator technique that uses only a few multiply/accumulate and registers to create a sine/cosine oscillator. I wanted to post the PDF here in case anyone wanted to check them out and possibly implement them before I get to it.
http://www.claysturner.com/dsp/digital_resonators.pdf
I think its possible with these methods to make an extremely efficient group of library objects that could allow for loads of oscillators.
The Assembler code for the FV-1 implementation is :
equ oscSin reg0
equ oscCos reg1
equ oscFreq pot0
;----------- load ---------------
SKP RUN , 3 ; skips the next 3 instructions after the initial first run
WRAX oscSin, 0 ; writes to the register defined by equ oscSin above (reg0)
; and multiplies the accumulator by 0
SOF 0, -1 ; scale and offset the accumulator, times 0 plus -1
WRAX oscCos, 0 ; write to cosine register and clear accumulator
;___________________
;------ Oscillator--------------
RDAX oscSin, 0.6 ; read sine register multiplied by 0.6
MULX oscFreq ; multiply by register defined by equ above (pot input 0)
RDAX oscCos, 1 ; add cosine register times 1
WRAX oscCos, -0.6 ; write to cosine register and multiply accumulator by -0.6
MULX oscFreq ; multiply by register currently defined as pot0
RDAX oscSin, 1 ; add sine register times 1
WRAX oscSin, 0 ; write to sine register and clear accumulator
