Audio board - Using mic in as input from Teensy ADC
Hello, I'm currently setting up my audio adapter board, and realized I could potentially connect the Teensy's DAC to the mic input somehow, so that I do not have to use one of the line in channels or make any funky mixing circuitry if I want to utilize the DAC with the handy output jack.
I have looked over the SGTL5000 datasheet and it appears that internally the mic input functions the same as the line inputs aside from the programmable gain.
What would I need to do, hardware-wise, in order to connect the pins? Here is what I've come up with so far, please guide me and feel free to correct me.
- Make a voltage divider to keep the voltage below the ~2.8v maximum.
- Remove the 2.2k resistor between mic bias and the mic pin. (I am perfectly fine with permanently modifying the board in this way, if it is necessary)
