weeky
I just have a simple question. I'm using the Audio Library to play a wav file from SD card to an external I2S Amplifier. So no audio adaptor is used. This amp does not need MCLK. Can i simply use this pin as input for a button, when I define pinMode(11,INPUT_PULLUP); after I initialised the audio connections? Or shouldn't that be done?
Best Regards
Best Regards
