JazzBrewer
Greetings, all! This is my first post: I'm fairly new to all this so please bear with me. I've tried searching for some clarification, but have so far come up empty-handed. On the Sparkfun tutorial that's commonly referenced for setting up a Teensy with two audio boards, it states that a few traces need to be cut:
So my questions are:
1) Do I cut the trace between left and center as posted, or right and center as pictured?
2) If the left-center trace is cut, what's the point in reconnecting the pads with solder?
My final goal for this project is to incorporate a 4-channel Teensy device into a RPi-based carputer so that I can have all the capabilities that were part of the stock stereo (balance, fade, EQ, etc.) I'm sure it'll be a long road if I'm already hung up on step 1, but I'm learning more each day.
Thanks!
but then you apparently have to reconnect the center and left I2C pads with a solder blob. Also, the pictures shows an arrow pointing to the trace between the center and right I2C pads instead of the center-left:The pairs of pads near pins 13 and 22 need to be cut apart. The trace between the center and left pads of the I2C address selector also need to be cut.
Thanks!
