I am seeing in select cases that the teensy board (w/ audio adapter) is losing its programming. I believe it happens when the voltage goes too low for the regulator to keep regulating. I looked at the datasheet and see some of the LVD registers. Are these enabled by default? I am trying to keep the board in reset when low voltage flag is set to see if it rids of this problem - that is the only lead I have right now.
Any advice is appreciated.
