Teensy 3.5 RTC Not Working
mjs513
Senior Member+
Hi
I loaded the example sketch settime from the DS1307RTC library. When I open the serial monitor not happens it remains blank. I am using Arduino IDE 1.6.12. Any help would be appreciated.
Thanks
Mike
Did you actually connect a DS1307 chip?
If you want to use the built in RTC, upload File > Examples > Time > TimeTeensy3
Hi Paul
Thanks for getting back to me so fast. I ran TimeTeensy3 and worked like a charm. I assumed the RTC on board was a DS1307. That's what I get for not reading the whole Time Lib page you set up.
Thanks
Mike
Are you able to retain the time after disconnecting power supply (while keeping a coin cell attached)?
