maitreya.maity
I am new to this thread as well as with Teensy.
I am working on a project. I need to store large files (avg 10 MByte) from my computer to a microSD card. For the setup, I have connected the Teensy board to my PC through USB cable. And on the other side, I have used the microSD card shield to connect SD card with the Teensy. So, Now data will transfer from my PC to Tennsy and then SD card. I have programmed a Java code to write file data as bytes over the Serial. At the same time, I am trying to read those data from Serial in Teensy and then trying to write those data to SD card.
I need help on the Teensy part. I failed to write data on the SD card. How can I successfully write files in SD card? My primary concerns are speed and successful file writing.
Your valuable suggestion is highly appreciable.
Thank in advance.
Maity
Thank in advance.
Maity
