Epyon
I have a Teensy 3.2, a Adafruit FONA GPRS modem, SD card and a battery connected to the VBAT pin. I use this for datalogging, and I need the logs to be timestamped, so I use the Timelib.
On boot, the Teensy checks if the internal RTC is set and prints the time (using now()), initialises the FONA and then queries the network for the time. The network gives local time (CET) and the offset (in quarter hours) to UTC. I need UTC to avoid problems with daylight savings, different timezones etc. So I calculate UTC time and then set the time (setTime()). I then set the RTC with the time (Teensy3Clock.set(now()). UTC is one hour behind my local time.
On a reboot I would expect the RTC to be set to UTC, but most of the times it is set as local time. Sometimes it is set as UTC time. This is problematic, because after a reboot the unit timestamps the logs in local time until a network time fix (and UTC calculation) can be made.
I'll just post the relevant time snippets of my code:
Setup:
My checkTime function:
This is the serial output I'm getting (at 00:15 local time, 23:15 UTC)
I would think the RTC is now set with UTC time. However after a reboot:
Am I missing something here to set the RTC correctly? It always reverts to local time, with some offset sometimes .
Setup:
//Check to see if the RTC has been set before
if (timeStatus()!= timeSet) {
Serial.println("RTC not set");
else {
Serial.print("Time set by RTC: ");
printTime();
Serial.println("");
setTime(houri, minutei, secondi, dayi, monthi, yeari);
Serial.print(F("Received timestamp: "));
Serial.print(dayi);
Serial.print('/');
Serial.print(monthi);
Serial.print('/');
Serial.print(yeari);
Serial.print(' ');
Serial.print(houri);
Serial.print(':');
Serial.print(minutei);
Serial.print(':');
Serial.print(secondi);
Serial.print(':');
Serial.println("");
Serial.print("Adjusted for UTC time: ");
if(offsetplus){
utc = now() - offseti*900; //offset is the amount of quarters of an hour the timezone is offset to UTC
else {
utc = now() + offseti*900;
setTime(utc);
printTime();
Teensy3Clock.set(now());
Booting...Time set by RTC: 1480637669 2016/12/02 00:14:29
1480637689 2016/12/02 00:14:49 CEL: Getting local time from cellular network: "16/12/02,00:15:56+04"
Received timestamp: 2/12/16 0:15:56:
Adjusted for UTC time: 1480634156 2016/12/01 23:15:56
1480637689 2016/12/02 00:14:49 CEL: Getting local time from cellular network: "16/12/02,00:18:09+04"
Received timestamp: 2/12/16 0:18:9:
Adjusted for UTC time: 1480634289 2016/12/01 23:18:09
