View Full Version : Teensyduino 1.32 Beta #2 Available
Paul
12-04-2016, 07:44 AM
Here is a second beta test for Teensyduino 1.32.
Edit: old beta test linkes removed. Full non-beta release is here:
Changes since Teensyduino 1.32-beta1:
Improved sync between Arduino IDE and Teensy Loader
Arduino IDE Tools > Ports menu labels ports as "Teensy"
Fix Arduino Verify starting upload when Teensy already in bootloader mode
Teensy Loader wrong chip dialog is now nonblocking.
pinMode supports INPUT_DISABLE on 32 bit Teensy boards
attachInterrupt supports uninitialized pins
Serial RTS watermarks scale with buffer size (Frank B)
Optimized Adafruit_ST7735 improved & renamed to ST7735_t3
Ethernet library optimizations & Ethernet.init(CS_PIN)
PaulStoffregen
12-04-2016, 03:44 PM
Teensy Loader has a 4 dialog boxes for error conditions. Until now they've all been modal, meaning Teensy Loader halts until you click OK or Cancel. USB changes and events from Arduino are ignored while the modal dialog boxes are on the screen, and of course everything in the main window is unresponsive to mouse clicks.
wrong board for compiled code <-- nonblocking :)
file not readable
file too large for board
rebooting too fast <-- nonblocking :)
With this beta, I've tried to make 2 of them non-modal. Simple as this sounds, GUI programming (especially on top of the wxWidgets targeting 3 operating systems) for non-modal usage is far more complex. There's a reason so much software uses Yes/No/Cancel modal dialogs! If you have a chance to use this beta, please give these a try and let me know how they work (or fail) on your system?
On top of non-modal programming, I've also tried to make these dialogs automatically close themselves if you do something (not in Teensy Loader) which makes the error condition no longer apply. Both USB changes and events from Arduino are supposed to be able to make these non-modal dialogs automatically close themselves, without you having to click OK.
I also tried to fix two other long-standing problems.
The dialog box could be rendered out of view, if Teensy Loader is covered by other windows or minimized to the tray/dock.
It could appear somewhere far away from the original Teensy Loader window if you have a large screen or multi-monitor setup.
As you can probably imagine, GUI programming isn't my strongest skill. Especially getting the window to appear when behind other windows was quite a challenge, and I'm not entirely sure it's working in all cases on all 3 systems. If you have a little time to try this beta, please keep an eye out for these dialogs and let me know how they work on your system. If things go badly, I can put them back to modal mode. Ideally, I'd like to make all 4 non-modal if these 2 work out well.
KurtE
12-04-2016, 04:46 PM
Just installed on Arduino 1.6.13 with Windows 10 64 bit. Arduino installed from ZIP file.
Tried compiling a program (graphic test for ST7735_t3) to download to T3.2...
Opening Teensy Loader...
Sketch uses 33,428 bytes (12%) of program storage space. Maximum is 262,144 bytes.
Global variables use 4,756 bytes (7%) of dynamic memory, leaving 60,780 bytes for local variables. Maximum is 65,536 bytes.
C:\arduino-1.6.13\hardware\teensy/../tools/teensy_post_compile -test -file=graphicstest.ino -path=C:\Users\Kurt\AppData\Local\Temp\arduino_buil d_356634 -tools=C:\arduino-1.6.13\hardware\teensy/../tools -board=TEENSY31 -reboot
Unable find Teensy Loader. (r) Is the Teensy Loader application running?
Is a firewall (eg, ZoneAlarm) blocking localhost communication?
Shows current Comm port 9(Teensy).
Clicking on program button does program the chip.
Tried rebooting to make sure there was not some random app still running. Still fails
KurtE
12-04-2016, 08:35 PM
I also installed on MAC with Arduino 1.6.12 and it appears to work.
Likewise installed on UP board running Ubuntu 16.04 on Arduino 1.6.13 and it and it appears to work there as well.
So only my main windows machine not working...
PaulStoffregen
12-05-2016, 01:45 AM
Looks like I have more work to do on the sync issue. But I can't produce it here. Tried many times just now on my Windows test machine.
9015
defragster
12-05-2016, 08:35 AM
Installed the TD_1.32b2 on my Win 10 IDE 1.6.13 system - no install problems!
I see the PORTS labelled as TEENSY ( if only it knew the model # :) )
So I was programming using 2 Teensy's and that is still not great with Teensy.exe - that is below. But to test your current work As noted above:
A single T_3.6 does UPLOAD and SERMON restart from IDE just fine.
If I select T_3.5 I get the Error popup and it displays and dismisses properly.
Going back to T_3.6 all goes well with no hiccups.
------- until I modified my current work this is what I found:
Not Using TYQT - of course I have a T_3.0 and a T_3.6 online and it picks the T_3.0 as FIRST to get a T_3.6 sketch.
Paul QUESTION:: [ so it is in that state - after acknowledging 'wrong chip dialog' ]
>I expected touching the T_3.6 program button to have Teensy.exe push over the code and it didn't? The Teensy_VERBOSE window shows nothing for the T_3.6, is it still tied to the T_3.0 left in Program mode? T_3.0 button push registers in Verbose. After Button on T_3.0 a button on T_3.6 registers only the first time and does not attempt to program the T_3.6 I just pushed the button on? And on the next 'Verify' it immediately tried to push to the T_3.0 again.
Yes, I know I must do Verify given the target isn't 'first' - but as I noted months back - Teensy.exe seems fixated on the wrong Teensy - when the right Teensy is asking for code.
I suppose this is because the T_3.0 is left offline in program mode? It leads to a confusing situation to navigate out of.
Still finding IDE SerMon doesn't start anew when the programmed Teensy comes back online with Verify and Button - I need to hit the IDE SerMon GUI button.
More - Why two Teensys: I have the T_3.0 doing pin 3 FreqMeas() of the T_3.6 and I want SerMon on both - so I use TYQT and tell it to ignore T_3.6 Serial - leaving it open to IDE and Teensy, and watch T_3.0 output in TYQT window.
Even with this - the T_3.0 tied up in USB with TYQT should be invisible to Teensy.exe? The first UPLOAD fails and the second reports this with SerMon open on COM3 to T_3.6::
Found serial '\\.\COM17', but unable to open for reboot request
Found serial '\\.\COM3', but unable to open for reboot request
Teensy did not respond to a USB-based request to automatically reboot.
The Teensy 3.6 on COM3 is unencumbered - except by the IDE with open SerMon. I close SerMon and then I get just this with UPLOAD:
Though it has reprogrammed new UPLOAD code to the T_3.6 as expected - as long as SerMon doesn't have Com3 open.
And I see a long stream of this in Teensy_Verbose: "00:09:55: remote cmd: "status" 00:09:55: status data sent"
Not sure if this shows anything not already known - Would be nice if the IDE port selection could be used for the USB program when UPLOAD is used - to close SerMon - Program - Restore SerMon.
Note: When OTA programming multiple ESP8266's the program is sent by IDE port device selection to one of many IP addresses.
... this is why I always go back to TYQT as it handles Multi-Teensy and Multi-SerMon in a way that makes Teensy even better as I typically use it.
lucafelici
12-05-2016, 10:44 AM
Installed the TD_1.32b2 on my Mac OS IDE 1.6.13 system - no install problems!
Can't see ETHERNET library any more...
My problem???
defragster
12-05-2016, 11:11 AM
I see "examples / Ethernet" in the standard group - not Teensy specific lower group - with a T_3.6 selected on my similar Win 10 install
lucafelici
12-05-2016, 11:27 AM
I looked again in the Teensyduino installer list of libraries, and there is no ETHERNET library.
As Paul listed - Ethernet library optimizations & Ethernet.init(CS_PIN), I expected to see a new library.
KurtE
12-05-2016, 03:28 PM
9015
Not sure, It was working before... First time I had this issue. To make sure, I deleted my 1.6.13 install, reinstalled from zip file I had on machine, reinstalled teensyduino and it still reproduces.
Yesterday it still worked with TYQT...
PaulStoffregen
12-05-2016, 03:40 PM
Teensyduino's versions of Arduino's built in libraries are always installed. They're not offered in the list of optional libraries. You can't choose to not install Ethernet, Servo and a few others.
pix-os
12-05-2016, 09:10 PM
request for Paul:
the datasheet of the k66 family shows me that there is a total of 1mb of flash, with an additional 256KB of FlexNVM for extra program code.
maybe make use of that bank of code in the near future?
PaulStoffregen
12-05-2016, 10:01 PM
The extra FlexNVM memory is used to implement EEPROM.
PaulStoffregen
12-07-2016, 02:00 PM
@KurtE - Could you give this a try? These 2 utilities go into hardware/tools within Arduino. Does it fix the erroneous "Unable find Teensy Loader" message on your Windows system?
KurtE
12-07-2016, 02:33 PM
Sorry No :o
Sketch uses 20,728 bytes (1%) of program storage space. Maximum is 1,048,576 bytes.
Global variables use 3,964 bytes (1%) of dynamic memory, leaving 258,180 bytes for local variables. Maximum is 262,144 bytes.
C:\arduino-1.6.13\hardware\teensy/../tools/teensy_post_compile -test -file=Blink.ino -path=C:\Users\Kurt\AppData\Local\Temp\arduino_buil d_900934 -tools=C:\arduino-1.6.13\hardware\teensy/../tools -board=TEENSY36 -reboot
I then tried running 1.6.12 with 1.31 and uploaded blink without issue.
KurtE
12-07-2016, 05:07 PM
While looking at one of the forum posts, I was looking through the ADC library code and noticed that with this beta, the code still talks about Teensy3.4 and Teensy 3.5. Looking up at pedvide updated that on his github awhile ago.
Not sure what all else changed.
PaulStoffregen
12-07-2016, 11:24 PM
@KurtE - Here's yet another attempt. I know this is probably getting tedious, but it's a huge help if you can give this a try. I *really* want to get this sync issue fixed for the 1.32 release.
KurtE
12-07-2016, 11:57 PM
Sorry to say still same results. - As a sanity test, should I try installing 1.31 on this build and see if it acts differently?
PaulStoffregen
12-08-2016, 12:01 AM
Yes, would be good to compare with 1.31.
I've been unable to reproduce the problem on my windows test machine, so there's not much I can other than guessing. :(
defragster
I dropped those exe's on my Win_10/IDE 1.6.13/TD_1.32b2 and plugged in a T_3.2 for a couple uploads with no problems. I had no problems before as noted.
Paul: Looking at PULL request (https://github.com/PaulStoffregen/cores/pull/196) to move the waits around usb_init() it occurred to me:
Given that delay() calls yield - shouldn't delay(400); be replaced with delayMicroseconds(400000); as USB and other Serial stuff is offline so far?
Where my edit is in pins_teensy.c
//delay(400);
usb_init();
I'm not sure if there is anyway the above could relate - thought it was time I made note of it in case.
UI of Teensy.exe was low left on second display - opened VERBOSE and it dropped below that barely showing the title bar.
PaulStoffregen
12-08-2016, 12:02 AM
Anyone else using Windows? Could you give 1.32-beta2 a try, and if the problem happens, try these changes?
PaulStoffregen
12-08-2016, 12:34 AM
Thanks for testing.
This is fine.
It's also completely unrelated to the sync issues between Teensy Loader and teensy_post_compile & teensy_reboot. This sync problem is occurring entirely on the PC.
I have no idea what you mean by this? Maybe a screenshot would make it clearer?
KurtE
12-08-2016, 01:39 AM
Paul, not sure what to say?
I tried redownloading a fresh copy of Arduino, just in case.
I then downloaded TD 1.31, but of course not supported.
So downloaded TD 1.32b1 and installed and the upload worked fine.
I then downloaded the 1.32b2 and reproduced not able to sync..
Tried test 4 above again and still:
Running windows 10 Pro
Intel Core i7-2600 @ 3.4ghz, 12gb mem
PaulStoffregen
12-08-2016, 01:42 AM
I'll sleep on it and think of something else to try tomorrow.....
defragster
12-08-2016, 03:17 AM
Thanks for testing.
My Win 10 is Pro_x64 also. This Laptop is just an i5 but working fine from a USB_2 port to an AMAZON Basics HUB. Also works fine direct to that USB_2 port, tested a few uploads. And with a single Teensy online - the IDE even works the SerMon restart correctly.
I do have a USB_3 port that is in an odd mood - powers a T_3.2 - but NEVER connects in any way - needs a system reboot.
This is fine.
Cool
Looks like this where Teensy was low left on the right display - and you can see the VERBOSE window is dropped below that barely showing the title bar::
9064
PaulStoffregen
12-08-2016, 12:06 PM
Ok, here's yet another attempt at the sync problem on Windows.
If this *still* fails with "Unable find Teensy Loader", can you give me the last several lines from Teensy Loader's verbose info window?
PaulStoffregen
12-08-2016, 01:28 PM
9064
Oh, so you're saying Windows is placing most of the Verbose Info window off-screen if you open it while Teensy Loader is near the bottom of the screen? Or is the problem something else?
KurtE
12-08-2016, 02:17 PM
Here is from T3.6 beta board:
06:09:18: Teensy Loader 1.32-beta2, begin program
06:09:18: Listening for remote control on port 3149
06:09:18: initialized, showing main window
06:09:19: remote connection opened
06:09:19: remote cmd: "comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)"
06:09:19: remote cmd: "status"
06:09:19: status data sent
06:09:19: remote cmd: "dir:C:\Users\Kurt\AppData\Local\Temp\arduino_build _109154\"
06:09:19: remote cmd: "file:Blink.ino.hex"
06:09:19: File "Blink.ino.hex". 20732 bytes, 2% used
06:09:19: remote cmd: "auto:on"
06:09:19: remote connection closed
06:09:19: HID/win32: vid:045E pid:07A5 ver:0767
06:10:04: Verbose Info event
And from a T3.5
06:13:23: file changed
06:13:35: remote connection opened
06:13:35: remote cmd: "comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)"
06:13:35: remote cmd: "status"
06:13:35: status data sent
06:13:35: remote cmd: "dir:C:\Users\Kurt\AppData\Local\Temp\arduino_build _109154\"
06:13:35: remote cmd: "file:Blink.ino.hex"
06:13:35: File "Blink.ino.hex". 20268 bytes, 2% used
06:13:35: remote connection closed
06:13:36: remote connection opened
06:13:36: remote cmd: "comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)"
06:13:36: remote cmd: "status"
06:13:36: status data sent
06:13:36: remote cmd: "dir:C:\Users\Kurt\AppData\Local\Temp\arduino_build _109154\"
06:13:36: remote cmd: "file:Blink.ino.hex"
06:13:36: File "Blink.ino.hex". 20268 bytes, 2% used
06:13:36: remote connection closed
06:13:43: Verbose Info event
Don't know if it helps, but if I then press the program button on the T3.5, it does program and Verbose info
06:15:09: Device came online, code_size = 524288
06:15:09: Board is: Teensy 3.5 (MK64FX512), version 1.03
06:15:09: File "Blink.ino.hex". 20268 bytes, 4% used
06:15:09: set background IMG_ONLINE
06:15:09: elf size appears to be 524288
06:15:09: elf binary data matches hex file
06:15:09: Code size from .elf file = 524288
06:15:09: begin operation
06:15:09: flash, block=0, bs=1024, auto=1
06:15:09: flash, block=1, bs=1024, auto=1
06:15:09: flash, block=2, bs=1024, auto=1
06:15:09: flash, block=3, bs=1024, auto=1
06:15:09: HID/win32: waiting for device
06:15:09: flash, block=4, bs=1024, auto=1
06:15:09: flash, block=5, bs=1024, auto=1
06:15:09: flash, block=6, bs=1024, auto=1
06:15:09: flash, block=7, bs=1024, auto=1
06:15:09: flash, block=8, bs=1024, auto=1
06:15:09: flash, block=9, bs=1024, auto=1
06:15:09: flash, block=10, bs=1024, auto=1
06:15:09: flash, block=11, bs=1024, auto=1
06:15:09: flash, block=12, bs=1024, auto=1
06:15:09: flash, block=13, bs=1024, auto=1
06:15:09: flash, block=14, bs=1024, auto=1
06:15:09: flash, block=15, bs=1024, auto=1
06:15:09: flash, block=16, bs=1024, auto=1
06:15:09: flash, block=17, bs=1024, auto=1
06:15:09: flash, block=18, bs=1024, auto=1
06:15:09: flash, block=19, bs=1024, auto=1
06:15:09: sending reboot
06:15:09: begin wait_until_offline
06:15:09: offline, waited 3
06:15:09: end operation
06:15:09: set background IMG_REBOOT_OK
06:15:09: redraw timer set, image 14 to show for 1200 ms
06:15:09: HID/win32: vid:045E pid:07A5 ver:0767
06:15:11: redraw, image 9
06:15:17: Verbose Info event
manitou
12-08-2016, 08:07 PM
Hurrah! In January, 2013 in my very first Teensy post (https://forum.pjrc.com/threads/17515-teensy-3-crystal-freq-check-with-NTP-and-GPS), I whined about having to set the pinMode for interrupt pin.:D
9079
PaulStoffregen
12-08-2016, 10:33 PM
@KurtE - Does any extra info show up if you turn on verbose info during upload in File > Preferences?
Those multiple lines of "remote connection opened" aren't normal, but so far I have no idea what's really going wrong. Will try to add logging to the teensy_reboot side and post yet another set of files soon.
Here's how the verbose info is supposed to look when things go as planned (as they always do on my test machine)
12:44:45: remote connection opened
12:44:45: remote cmd: "comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)"
12:44:45: remote cmd: "status"
12:44:45: status data sent
12:44:45: remote cmd: "dir:C:\Users\me\AppData\Local\Temp\arduino_build_8 99015\"
12:44:45: remote cmd: "file:Blinky.ino.hex"
12:44:45: File "Blinky.ino.hex". 34812 bytes, 13% used
12:44:45: remote connection closed
12:44:45: remote cmd: "comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_reboot)"
12:44:45: remote cmd: "auto:on"
12:44:45: elf size appears to be 262144
12:44:45: elf binary data matches hex file
12:44:45: Code size from .elf file = 262144
12:44:45: begin operation
KurtE
12-08-2016, 10:56 PM
It is sort of strange. I turned on verbose and the first time I ran it actually programmed properly, turned it off, it failed, turned it back on it succeeded first time, but then failed the next 3 times, then 1 success and then several more failures. Maybe 1 out 10 worked...
Does not give much more information
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637 172/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637 172\core\usb_flightsim.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637 172/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637 172\core\usb_inst.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637 172/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637 172\core\yield.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1481208461 "-TC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3/mk66fx1m0.ld" -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637 172/Blink.ino.elf" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637 172\sketch\Blink.ino.cpp.o" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637 172/core\core.a" "-LC:\Users\Kurt\AppData\Local\Temp\arduino_build_63 7172" -larm_cortexM4lf_math -lm
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637 172/Blink.ino.elf" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637 172/Blink.ino.eep"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637 172/Blink.ino.elf" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_637 172/Blink.ino.hex"
"C:\arduino-1.6.13\hardware\teensy/../tools//teensy_post_compile" "-file=Blink.ino" "-path=C:\Users\Kurt\AppData\Local\Temp\arduino_buil d_637172" "-tools=C:\arduino-1.6.13\hardware\teensy/../tools/" "-board=TEENSY36"
Sketch uses 20,584 bytes (1%) of program storage space. Maximum is 1,048,576 bytes.
C:\arduino-1.6.13\hardware\teensy/../tools/teensy_post_compile -test -file=Blink.ino -path=C:\Users\Kurt\AppData\Local\Temp\arduino_buil d_637172 -tools=C:\arduino-1.6.13\hardware\teensy/../tools -board=TEENSY36 -reboot
defragster
12-08-2016, 11:15 PM
Indeed - said and shown - that only the title bar is barely on the screen when the window is opened. In a recent post you noted you were looking after window open locations - I was following up that this Verbose window is opened all but off screen.
In this case if I place the TEENSY.exe any lower on the screen ( so I can just see when 'Reboot Ok' flashes by ) then the verbose window is opened fully off screen #2.
I also tried to fix two other long-standing problems. Teensyduino-1-32-Beta-2-Available (https://forum.pjrc.com/threads/40552-Teensyduino-1-32-Beta-2-Available?p=126080&viewfull=1#post126080)
huffine
12-08-2016, 11:32 PM
This is the first release I have tried on a Raspberry Pi. I am unable to program my Teensy 3.1 with this release with basically any combination of cold start (ie power removal and insertion), pressing the reset button, or automatic programming.
Programming from my Mac works perfectly with the same cable, so I believe the cable is "exonerated."
Serial console works perfectly, so we know that communications is working at some level on the Pi.
I don't see any error messages in dmesg during the programming sequence.
This is a raspberry pi 3 fwiw.
Any ideas?
Thanks,
Chris
defragster
12-08-2016, 11:34 PM
Have you done the udev/rules thing needed for Linux system (https://www.pjrc.com/teensy/loader_linux.html)?
PaulStoffregen
12-08-2016, 11:59 PM
Any ideas?
Look in Help > Verbose Info to find out what Teensy Loader is really seeing.
KurtE
12-09-2016, 01:03 AM
FYI - I tried installing Arduino... this beta on UP board (http://up-shop.org/up-boards/44-up-board-4gb-ram-64-gb-emmc.html) running Windows 10 64 bit, and it works fine...
PaulStoffregen
12-09-2016, 01:15 AM
I'm working right now to add a logging layer into the post compile and reboot programs. By tomorrow I'll have another test that'll give us a *lot* more info about what's going wrong on your system. I *really* want to get this figured out and hopefully make these more robust for the upcoming 1.32 release.
PaulStoffregen
12-09-2016, 06:13 AM
Here is yet another attempt. These will create a log file named teensy_reboot_log.txt. Hopefully together with the Verbose Info from Teensy Loader it will shine some light on what's really happening here.
On Windows, it will be created in the default temp folder, which defaults to C:\Users\username\AppData\Local\Temp. The AppData may be hidden, but can be accessed from the command line or other tools.
defragster
12-09-2016, 07:13 AM
Hit: Start Key + R :: to get RUN, enter %appdata% and you open to C:\Users\user\AppData\Roaming ... navigate to ..\local
Question- @KurtE - is any/all Teensy doing this for you on this Win_10 machine? Has it worked before until a new build?
And it seems to work using tyqt - so hardware seems to be fine? Any of the machine's USB ports? Using a hub?
PaulStoffregen
12-09-2016, 07:19 AM
This sync issue appears to be only related to the communication between Teensy Loader and Arduino (teensy_post_compile & teensy_reboot).
I'm not completely ruling out USB overhead or other issues somehow playing a factor. But I'm trying to focus on the sync problem between these two without getting distracted by other stuff.
So far Kurt has the only machine reproducing the problem, of anyone willing to reply here with test results. If anyone else has a Windows machine doing this, please please please speak up. I can't get it to happen here, and I *REALLY* want to get to the bottom of this problem. I could really use all the help I can get with running these tests on problematic Windows machines.
defragster
12-09-2016, 07:49 AM
Understood ... loader HID - but it plugs in to the USB port right? - just trying to make sure going to other machines to test I was set up knowing the repro scenario. On that machine it is any Teensy on any port with or without a hub with IDE 1.6.13 and 1.32b2?
PaulStoffregen
12-09-2016, 07:58 AM
Good questions. Most of Kurt's tests look like a Teensy was plugged in and running a previously uploaded sketch. Which USB Type is was, and whether plugged in directly to a USB2 or USB3 port or through a hub is unknown.
But the problems seen are happening before teensy_reboot can send the request to auto reboot. They're inter-process communication issues between programs running entirely on the PC, which happens before any USB communication takes place.
I really wish I knew a way to reproduce the problem here. But I don't...
defragster
12-09-2016, 08:59 AM
Two other Win_10 Pro x64 desktops (i5/i7) to 1.6.13 w/ TD_1.32vb2 and programmed T_3.1's a few times each no issue. Did fresh directory unzip of IDE on both, then TeensyInstaller.
Kurt has noted intermittent ability to program, once after TD_1.32b1, and again once each time after hitting Verbose (p#31)?
KurtE
12-09-2016, 02:32 PM
Just started computer up and getting ready to download latest.
But some more info: again windows 10 64 bit. Trying to program blink to teensys that already have been programmed, USB Serial, USB2 directly connected to computer (which of course has it's own HUB).
9089
Above shows the USB connections...
I can try other connections if desired, like USB3 or the 2nd USB2 controller 1C26...
The same connections/setup works with TyQt. Also works fine with Teensyduino 31 and 32b1.
Now to download and see what I get.
KurtE
12-09-2016, 02:53 PM
Here is the log file:
.152 post_compile: Begin
.153 post_compile: Connect attempt to port 3149
.320 post_compile: Connect attempt to port 3149
.472 post_compile: Connect attempt to port 3149
.622 post_compile: Connect attempt to port 3149
.625 post_compile: Connected to port 3149
.629 post_compile: Sending command: comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)
.630 post_compile: Sending status request
.631 post_compile: Receive status dir = C:\Users\Kurt\AppData\Local\Temp\arduino_build_100 474\
.631 post_compile: Receive status file = Blink.ino.hex
.631 post_compile: Receive status readable = 0
.631 post_compile: Receive status auto = 0
.631 post_compile: Receive status online = 0
.631 post_compile: Receive status online_count = 0
.631 post_compile: Receive status offline_count = 0
.631 post_compile: Receive status state = 0
.631 post_compile: Receive status EOT
.631 post_compile: Sending command: dir:C:\Users\Kurt\AppData\Local\Temp\arduino_build _756528\
.632 post_compile: Sending command: file:Blink.ino.hex
.646 post_compile: Sending status request
.648 post_compile: Receive status dir = C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\
.648 post_compile: Receive status file = Blink.ino.hex
.648 post_compile: Receive status readable = 1
.648 post_compile: Receive status auto = 0
.648 post_compile: Receive status online = 0
.648 post_compile: Receive status online_count = 0
.648 post_compile: Receive status offline_count = 0
.648 post_compile: Receive status state = 0
.648 post_compile: Receive status EOT
.648 post_compile: Sending command: auto:on
.649 post_compile: Disconnect
.857 post_compile: Begin
.859 post_compile: Connect attempt to port 3149
.012 post_compile: Connect attempt to port 3149
.162 post_compile: Connect attempt to port 3149
.313 post_compile: Connect attempt to port 3149
.313 post_compile: Connected to port 3149
.314 post_compile: Sending command: comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)
.314 post_compile: Sending status request
.315 post_compile: Receive status dir = C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\
.315 post_compile: Receive status file = Blink.ino.hex
.315 post_compile: Receive status readable = 1
.315 post_compile: Receive status auto = 1
.315 post_compile: Receive status online = 0
.315 post_compile: Receive status online_count = 0
.315 post_compile: Receive status offline_count = 0
.315 post_compile: Receive status state = 0
.315 post_compile: Receive status EOT
.315 post_compile: Sending command: dir:C:\Users\Kurt\AppData\Local\Temp\arduino_build _756528\
.315 post_compile: Sending command: file:Blink.ino.hex
.325 post_compile: Sending status request
.327 post_compile: Receive status dir = C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\
.327 post_compile: Receive status file = Blink.ino.hex
.327 post_compile: Receive status readable = 1
.327 post_compile: Receive status auto = 1
.327 post_compile: Receive status online = 0
.327 post_compile: Receive status online_count = 0
.327 post_compile: Receive status offline_count = 0
.327 post_compile: Receive status state = 0
.328 post_compile: Receive status EOT
.328 post_compile: Disconnect
.339 post_compile: Running teensy_reboot
.390 reboot: Begin
.400 reboot: Device Instance: 1
.400 reboot: PortName: "COM12"
.400 reboot: pathname: \\.\COM12
.400 reboot: add_serial_name, \\.\COM12
.402 reboot: Connect attempt to port 3149
The verbose information:
06:35:10: Teensy Loader 1.32-beta2, begin program
06:35:10: Listening for remote control on port 3149
06:35:10: initialized, showing main window
06:35:10: remote connection opened
06:35:10: remote cmd: "comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)"
06:35:10: remote cmd: "status"
06:35:10: status data sent
06:35:10: remote cmd: "dir:C:\Users\Kurt\AppData\Local\Temp\arduino_build _756528\"
06:35:10: remote cmd: "file:Blink.ino.hex"
06:35:10: File "Blink.ino.hex". 20732 bytes, 2% used
06:35:10: remote cmd: "auto:on"
06:35:10: HID/win32: vid:045E pid:07A5 ver:0767
06:35:10: remote connection closed
06:35:11: remote connection opened
06:35:11: remote cmd: "comment: Teensyduino 1.32-beta3 - WINDOWS (teensy_post_compile)"
06:35:11: remote cmd: "status"
06:35:11: status data sent
06:35:11: remote cmd: "dir:C:\Users\Kurt\AppData\Local\Temp\arduino_build _756528\"
06:35:11: remote cmd: "file:Blink.ino.hex"
06:35:11: File "Blink.ino.hex". 20732 bytes, 2% used
06:35:11: remote connection closed
06:38:50: Verbose Info event
Output from verbose compile:
C:\arduino-1.6.13\arduino-builder -dump-prefs -logger=machine -hardware C:\arduino-1.6.13\hardware -hardware C:\Users\Kurt\AppData\Local\Arduino15\packages -hardware C:\Users\Kurt\Documents\Arduino\hardware -tools C:\arduino-1.6.13\tools-builder -tools C:\arduino-1.6.13\hardware\tools\avr -tools C:\Users\Kurt\AppData\Local\Arduino15\packages -built-in-libraries C:\arduino-1.6.13\libraries -libraries C:\Users\Kurt\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180opt,k eys=en-us -vid-pid=0X16C0_0X0483 -ide-version=10613 -build-path C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528 -warnings=all -verbose C:\arduino-1.6.13\examples\01.Basics\Blink\Blink.ino
C:\arduino-1.6.13\arduino-builder -compile -logger=machine -hardware C:\arduino-1.6.13\hardware -hardware C:\Users\Kurt\AppData\Local\Arduino15\packages -hardware C:\Users\Kurt\Documents\Arduino\hardware -tools C:\arduino-1.6.13\tools-builder -tools C:\arduino-1.6.13\hardware\tools\avr -tools C:\Users\Kurt\AppData\Local\Arduino15\packages -built-in-libraries C:\arduino-1.6.13\libraries -libraries C:\Users\Kurt\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180opt,k eys=en-us -vid-pid=0X16C0_0X0483 -ide-version=10613 -build-path C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528 -warnings=all -verbose C:\arduino-1.6.13\examples\01.Basics\Blink\Blink.ino
Using board 'teensy36' from platform in folder: C:\arduino-1.6.13\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\arduino-1.6.13\hardware\teensy\avr
Detecting libraries used...
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\sketch\Blink.ino.cpp" -o "nul"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\sketch\Blink.ino.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\arduino-1.6.13\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\sketch\Blink.ino.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\memcpy-armv7m.S" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\memcpy-armv7m.S.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\memset.S" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\memset.S.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\analog.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\analog.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\eeprom.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\eeprom.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\keylayout s.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\keylayouts.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\math_help er.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\math_helper.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\mk20dx128 .c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\mk20dx128.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\nonstd.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\nonstd.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\pins_teen sy.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\pins_teensy.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\ser_print .c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\ser_print.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\serial1.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\serial1.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\serial2.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\serial2.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\serial3.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\serial3.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\serial4.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\serial4.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\serial5.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\serial5.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\serial6.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\serial6.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\serial6_l puart.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\serial6_lpuart.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\touch.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\touch.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_desc. c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_desc.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_dev.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_dev.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_joyst ick.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_joystick.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_keybo ard.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_keyboard.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_mem.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_mem.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_midi. c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_midi.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_mouse .c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_mouse.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_mtp.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_mtp.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_rawhi d.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_rawhid.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_serem u.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_seremu.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_seria l.c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_serial.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_touch .c" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_touch.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\AudioStre am.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\AudioStream.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\DMAChanne l.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\DMAChannel.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\HardwareS erial1.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\HardwareSerial1.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\HardwareS erial2.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\HardwareSerial2.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\HardwareS erial3.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\HardwareSerial3.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\HardwareS erial4.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\HardwareSerial4.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\HardwareS erial5.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\HardwareSerial5.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\HardwareS erial6.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\HardwareSerial6.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\IPAddress .cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\IPAddress.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\IntervalT imer.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\IntervalTimer.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\Print.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\Print.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\Stream.cp p" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\Stream.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\Tone.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\Tone.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\WMath.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\WMath.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\WString.c pp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\WString.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\avr_emula tion.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\avr_emulation.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\main.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\main.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\new.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\new.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_audio .cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_audio.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_fligh tsim.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_flightsim.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\usb_inst. cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_inst.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3" "C:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3\yield.cpp" -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\yield.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\memcpy-armv7m.S.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\memset.S.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\analog.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\eeprom.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\keylayouts.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\math_helper.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\mk20dx128.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\nonstd.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\pins_teensy.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\ser_print.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\serial1.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\serial2.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\serial3.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\serial4.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\serial5.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\serial6.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\serial6_lpuart.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\touch.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_desc.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_dev.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_joystick.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_keyboard.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_mem.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_midi.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_mouse.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_mtp.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_rawhid.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_seremu.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_serial.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_touch.c.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\AudioStream.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\DMAChannel.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\HardwareSerial1.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\HardwareSerial2.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\HardwareSerial3.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\HardwareSerial4.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\HardwareSerial5.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\HardwareSerial6.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\IPAddress.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\IntervalTimer.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\Print.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\Stream.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\Tone.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\WMath.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\WString.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\avr_emulation.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\main.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\new.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_audio.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_flightsim.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\usb_inst.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core/core.a" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\core\yield.cpp.o"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1481265297 "-TC:\arduino-1.6.13\hardware\teensy\avr\cores\teensy3/mk66fx1m0.ld" -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/Blink.ino.elf" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528\sketch\Blink.ino.cpp.o" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/core\core.a" "-LC:\Users\Kurt\AppData\Local\Temp\arduino_build_75 6528" -larm_cortexM4lf_math -lm
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/Blink.ino.elf" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/Blink.ino.eep"
"C:\arduino-1.6.13\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/Blink.ino.elf" "C:\Users\Kurt\AppData\Local\Temp\arduino_build_756 528/Blink.ino.hex"
"C:\arduino-1.6.13\hardware\teensy/../tools//teensy_post_compile" "-file=Blink.ino" "-path=C:\Users\Kurt\AppData\Local\Temp\arduino_buil d_756528" "-tools=C:\arduino-1.6.13\hardware\teensy/../tools/" "-board=TEENSY36"
Opening Teensy Loader...
Sketch uses 20,728 bytes (1%) of program storage space. Maximum is 1,048,576 bytes.
Global variables use 3,964 bytes (1%) of dynamic memory, leaving 258,180 bytes for local variables. Maximum is 262,144 bytes.
C:\arduino-1.6.13\hardware\teensy/../tools/teensy_post_compile -test -file=Blink.ino -path=C:\Users\Kurt\AppData\Local\Temp\arduino_buil d_756528 -tools=C:\arduino-1.6.13\hardware\teensy/../tools -board=TEENSY36 -reboot
Unable find Teensy Loader. (r) Is the Teensy Loader application running?
Is a firewall (eg, ZoneAlarm) blocking localhost communication?
Strange: If I do a sleep operation on my computer and right after I awake the computer, do an upload, it worked twice in a row. But if I wait a little while then it fails again...
Weird!
PaulStoffregen
12-09-2016, 07:40 PM
Thanks Kurt. I know it doesn't seem like progress, but that actually helps quite a lot.
Here's another attempt, which might fix this problem, and if it doesn't it has even more info that might help.
KurtE
12-09-2016, 08:18 PM
:D - I thought it failed the first time, but then I tried it many different ways, With T3.2, T3.5 and a couple of T3.6s and it is working fine every time. I tried with Teensyduino already loaded, or without it already open. I tried with and without Verbose.
PaulStoffregen
12-09-2016, 08:33 PM
Whew, glad it's *finally* resolved!
I'm going disable the excessive logging and start packaging up 1.32 now.
Paul
12-09-2016, 11:40 PM
Teensyduino 1.32 has been released.
