I just installed teensyduino 1.32 and updated Arduino to 1.6.13. This is the first time I'm using this Teensy 3.2 and when I click the compile button the IDE tells me (verbose output):
In the little teensy program window it does show a Teensy 3.2 when I click the button on the device. The window also says "No file specified".
Unfortunately this is not a bare Teensy 3.2. I'm trying to create an guitar effects pedal according to https://learn.sparkfun.com/tutorials/proto-pedal-example-programmable-digital-pedal so I've already modified the teensy according to that. (The teensy has the trace cut so that it's no longer powered by USB, it's soldered to teensy audio board, and the audio board is soldered into the circuit.)
Any ideas what might be wrong?
Arduino: 1.6.13 (Mac OS X), TD: 1.32, Board: "Teensy 3.2 / 3.1, Serial, 72 MHz optimize speed, US English"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/drew/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/drew/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/drew/dev/ee-arduino/libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=72opt,keys=en-us -ide-version=10613 -build-path /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975 -warnings=all -verbose /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_modified_sketch_712292/Blink.pde
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/drew/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/drew/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/drew/dev/ee-arduino/libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=72opt,keys=en-us -ide-version=10613 -build-path /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975 -warnings=all -verbose /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_modified_sketch_712292/Blink.pde
Using board 'teensy31' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr
Using core 'teensy3' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr
Detecting libraries used...
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=72000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/sketch/Blink.pde.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=72000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/sketch/Blink.pde.cpp" -o "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/preproc/ctags_target_for_gcc_minus_e.cpp"
"/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/preproc/ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=72000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/sketch/Blink.pde.cpp" -o "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/sketch/Blink.pde.cpp.o"
Compiling libraries...
Compiling core...
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/memcpy-armv7m.S.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/memset.S.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/analog.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/eeprom.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/keylayouts.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/math_helper.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/mk20dx128.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/nonstd.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/pins_teensy.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/ser_print.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/serial1.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/serial2.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/serial3.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/serial4.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/serial5.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/serial6.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/serial6_lpuart.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/touch.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_desc.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_dev.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_joystick.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_keyboard.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_mem.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_midi.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_mouse.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_mtp.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_rawhid.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_seremu.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_serial.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_touch.c.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/AudioStream.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/DMAChannel.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/HardwareSerial1.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/HardwareSerial2.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/HardwareSerial3.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/HardwareSerial4.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/HardwareSerial5.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/HardwareSerial6.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/IPAddress.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/IntervalTimer.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/Print.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/Stream.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/Tone.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/WMath.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/WString.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/avr_emulation.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/main.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/new.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_audio.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_flightsim.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_inst.cpp.o
Using previously compiled file: /var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/yield.cpp.o
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/memcpy-armv7m.S.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/memset.S.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/analog.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/eeprom.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/keylayouts.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/math_helper.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/mk20dx128.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/nonstd.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/pins_teensy.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/ser_print.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/serial1.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/serial2.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/serial3.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/serial4.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/serial5.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/serial6.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/serial6_lpuart.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/touch.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_desc.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_dev.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_joystick.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_keyboard.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_mem.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_midi.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_mouse.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_mtp.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_rawhid.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_seremu.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_serial.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_touch.c.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/AudioStream.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/DMAChannel.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/HardwareSerial1.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/HardwareSerial2.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/HardwareSerial3.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/HardwareSerial4.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/HardwareSerial5.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/HardwareSerial6.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/IPAddress.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/IntervalTimer.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/Print.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/Stream.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/Tone.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/WMath.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/WString.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/avr_emulation.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/main.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/new.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_audio.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_flightsim.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/usb_inst.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/yield.cpp.o"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1481462404 "-T/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/mk20dx256.ld" -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/Blink.pde.elf" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/sketch/Blink.pde.cpp.o" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/core/core.a" "-L/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975" -larm_cortexM4l_math -lm
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/Blink.pde.elf" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/Blink.pde.eep"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/Blink.pde.elf" "/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975/Blink.pde.hex"
"/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools//teensy_post_compile" "-file=Blink.pde" "-path=/var/folders/kk/fgwrzqnx3490zhnjt253lhw00000gn/T/arduino_build_790975" "-tools=/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/" "-board=TEENSY31"
Opening Teensy Loader...
Error compiling for board Teensy 3.2 / 3.1.
