judgedrewdy
(here's the project I'm doing-https://learn.adafruit.com/animated-electronic-eyes-using-teensy-3-1/overview-)
Ok so I made sure there were no repeating files and everything went in the right place.
I've included the #include <Adafruit_SSD1351.h> // OLED display library even though I need the code to work for the <Adafruit_ST7735.h> // TFT display library
just wanted to see if I could get the sketch to run before I returned my TFT display {since the code apparently doesn't work for this project } for a OLED
now I just cannot compile.
none of the example teensy sketches are able to upload or verify
I've done a fresh install of windows and a fresh install of arduino.
only been able to get this far because I didn't install the Adafruit_ST7735 drivers included with teensyduino. installed it from sketch/include library/manage library
this stopped an error due to "INITR_144GREENTAB not being defined in the Teensy ST7735 source"-MIchaelMeissner from forum.pjrc.com
https://forum.pjrc.com/threads/35701-Teensy-version-of-Adafruit_ST7735-needs-updating
here's the error message
Any help would be greatly appreciated.
It doesn't seem like I'm able to make any of the example teensy sketches to work. =/
Arduino: 1.6.13 (Windows 10), TD: 1.32, Board: "Teensy 3.2 / 3.1, Serial, 72 MHz optimize speed, US English"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\drewc\Documents\libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=72opt,keys=en-us -ide-version=10613 -build-path C:\Users\drewc\AppData\Local\Temp\arduino_build_351769 -warnings=none -verbose C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Teensy3.1_Eyes-master\uncannyEyes\uncannyEyes.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\drewc\Documents\libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=72opt,keys=en-us -ide-version=10613 -build-path C:\Users\drewc\AppData\Local\Temp\arduino_build_351769 -warnings=none -verbose C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Teensy3.1_Eyes-master\uncannyEyes\uncannyEyes.ino
Using board 'teensy31' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=72000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\sketch\uncannyEyes.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=72000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\sketch\uncannyEyes.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=72000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Adafruit_GFX_Library" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\sketch\uncannyEyes.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=72000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Adafruit_GFX_Library" "-IC:\Users\drewc\Documents\libraries\Adafruit_SSD1351_library" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\sketch\uncannyEyes.ino.cpp" -o "nul"
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI\SPI.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Adafruit_GFX_Library\glcdfont.c
Using cached library dependencies for file: C:\Users\drewc\Documents\libraries\Adafruit_SSD1351_library\Adafruit_SSD1351.cpp
Using cached library dependencies for file: C:\Users\drewc\Documents\libraries\Adafruit_SSD1351_library\glcdfont.c
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=72000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Adafruit_GFX_Library" "-IC:\Users\drewc\Documents\libraries\Adafruit_SSD1351_library" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\sketch\uncannyEyes.ino.cpp" -o "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=132 -DARDUINO=10613 -DF_CPU=72000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Adafruit_GFX_Library" "-IC:\Users\drewc\Documents\libraries\Adafruit_SSD1351_library" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\sketch\uncannyEyes.ino.cpp" -o "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\sketch\uncannyEyes.ino.cpp.o"
uncannyEyes: In function 'void frame(uint16_t)':
uncannyEyes:327: warning: comparison between signed and unsigned integer expressions
if((t - eye[eyeIndex].blink.startTime) >= eye[eyeIndex].blink.duration) {
uncannyEyes:404: warning: comparison between signed and unsigned integer expressions
if(s >= eye[eyeIndex].blink.duration) s = 255; // At or past blink end
Compiling libraries...
Compiling library "SPI"
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\libraries\SPI\SPI.cpp.o
Compiling library "Adafruit_GFX_Library"
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\libraries\Adafruit_GFX_Library\glcdfont.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp.o
Compiling library "Adafruit_SSD1351_library"
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\libraries\Adafruit_SSD1351_library\glcdfont.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\libraries\Adafruit_SSD1351_library\Adafruit_SSD1351.cpp.o
Compiling core...
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\memcpy-armv7m.S.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\memset.S.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\analog.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\eeprom.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\keylayouts.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\math_helper.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\mk20dx128.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\nonstd.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\pins_teensy.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\ser_print.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\serial1.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\serial2.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\serial3.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\serial4.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\serial5.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\serial6.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\serial6_lpuart.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\touch.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_desc.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_dev.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_joystick.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_keyboard.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_mem.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_midi.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_mouse.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_mtp.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_rawhid.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_seremu.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_serial.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_touch.c.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\AudioStream.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\DMAChannel.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\HardwareSerial1.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\HardwareSerial2.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\HardwareSerial3.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\HardwareSerial4.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\HardwareSerial5.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\HardwareSerial6.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\IPAddress.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\IntervalTimer.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\Print.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\Stream.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\Tone.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\WMath.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\WString.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\avr_emulation.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\main.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\new.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_audio.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_flightsim.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_inst.cpp.o
Using previously compiled file: C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\yield.cpp.o
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\memcpy-armv7m.S.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\memset.S.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\analog.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\eeprom.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\keylayouts.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\math_helper.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\mk20dx128.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\nonstd.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\pins_teensy.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\ser_print.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\serial1.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\serial2.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\serial3.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\serial4.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\serial5.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\serial6.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\serial6_lpuart.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\touch.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_desc.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_dev.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_joystick.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_keyboard.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_mem.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_midi.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_mouse.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_mtp.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_rawhid.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_seremu.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_serial.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_touch.c.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\AudioStream.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\DMAChannel.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\HardwareSerial1.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\HardwareSerial2.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\HardwareSerial3.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\HardwareSerial4.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\HardwareSerial5.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\HardwareSerial6.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\IPAddress.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\IntervalTimer.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\Print.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\Stream.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\Tone.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\WMath.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\WString.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\avr_emulation.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\main.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\new.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_audio.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_flightsim.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\usb_inst.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core/core.a" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\core\yield.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1481579388 "-TC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/mk20dx256.ld" -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/uncannyEyes.ino.elf" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\sketch\uncannyEyes.ino.cpp.o" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\libraries\SPI\SPI.cpp.o" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\libraries\Adafruit_GFX_Library\glcdfont.c.o" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp.o" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\libraries\Adafruit_SSD1351_library\glcdfont.c.o" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769\libraries\Adafruit_SSD1351_library\Adafruit_SSD1351.cpp.o" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/core\core.a" "-LC:\Users\drewc\AppData\Local\Temp\arduino_build_351769" -larm_cortexM4l_math -lm
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/uncannyEyes.ino.elf" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/uncannyEyes.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/uncannyEyes.ino.elf" "C:\Users\drewc\AppData\Local\Temp\arduino_build_351769/uncannyEyes.ino.hex"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools//teensy_post_compile" "-file=uncannyEyes.ino" "-path=C:\Users\drewc\AppData\Local\Temp\arduino_build_351769" "-tools=C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" "-board=TEENSY31"
Opening Teensy Loader...
Error reading Teensy Loader status! (tpc)This error should never happen (when using Arduino). Please report this to paul@pjrc.com, hopefully with enough information to reproduce the problem so it can be understood and fixed!===info ||| Using library {0} at version {1} in folder: {2} {3} ||| [SPI 1.0 C%3A%5CProgram+Files+%28x86%29%5CArduino%5Chardware%5Cteensy%5Cavr%5Clibraries%5CSPI ]
Using library Adafruit_GFX_Library at version 1.1.4 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Adafruit_GFX_Library
Using library Adafruit_SSD1351_library at version 1.0.1 in folder: C:\Users\drewc\Documents\libraries\Adafruit_SSD1351_library
Error compiling for board Teensy 3.2 / 3.1.
Compiling sketch...
Compiling core...
