View Full Version : Teensyduino 1.33 Beta #2 Available
Here is a second beta test for Teensyduino 1.33.
This version attempts to fix a serious bug in version 1.32 which prevents uploading sketches.
Changes since Teensyduino 1.33-beta1 (https://forum.pjrc.com/threads/40784-Teensyduino-1-33-Beta-1-Available):
Fix first-use communication error between Arduino & Teensy Loader
kophi
12-13-2016, 09:42 AM
I can confirm that the problem from 1.33-beta1 (error on first-use) is fixed in my setup.
Thanks for the quick fix!
znevans
12-13-2016, 01:13 PM
Confirmed here as well (same setup as kophi though, on mac, T3.2, A1.6.13). Thanks for working on this!
MichaelR
12-13-2016, 02:34 PM
Thank you Paul, this solved the compiler error problems (MacBook Pro macOS 10.11.6).
glenngineer
12-13-2016, 02:46 PM
Paul, I can confirm 1.33-Beta2 works with Teensy 3.2 under Windows 10 - Arduino1.6.13 and vMicro/VS.
Thank you so much - Glenn
PaulStoffregen
12-14-2016, 12:52 AM
Looks like this fixed the trouble.
I'm going to do another round of testing here tomorrow, and then release this as 1.33... unless I discover any problems, or anyone reports any more issues.
If anyone sees anything wrong, please please please speak up ASAP.
drewfish
12-14-2016, 05:14 AM
This worked for me as well. For completeness the log is attached.
9148
PaulStoffregen
12-14-2016, 03:37 PM
I've released Teensyduino 1.33. There were no substantial changes after 1.33-beta2.
This 1.33 release is mainly to fix the bug with first-time upload errors from Arduino.
KurtE
12-14-2016, 04:24 PM
I ran into an issue installing Teensyduino on my Windows 10 64 bit Arduino 1.6.13... I get error messages like:
9152
I tried with the current one 1.33 as well as the current one here and get this error.
I tried rebooting, I deleted the old Arduino and unzipped a new 1.6.13 to c:\ tried running as Admin... Will try to download fresh copies again...
el_supremo
12-14-2016, 04:57 PM
I had that error while installing 1.13b2 but I had forgotten to kill a T3.6 project that I had open in the IDE. Killed it, started again, all OK.
Pete
KurtE
12-14-2016, 05:42 PM
This time I tried it again, with a freshly downloaded Arduino IDE, I just rebooted, then unzipped the Arduino IDE to c:\ and then tried running the Teensyduino, same error...
Maybe should try on another machine... Will try later, now getting ready for company...
Edit: I also tried installing Arduino in my Documents folder and rerun the Teensyduino... Failed there too.
At times like this I wonder if 1.6.13 now is the same 1.6.13 when it was released
defragster
12-14-2016, 05:54 PM
I ran the TD_1.33b2 install over my prior 1.6.13 install with no problems with TD install
el_supremo
12-14-2016, 08:06 PM
BTW. I install Arduino/Teensyduino on a SSD. I start by unzipping the Arduino stuff and that goes really fast. Up until recently, the Teensyduino install was really slow. But 1.33 installs MUCH faster than previous versions.
Excellent ;)
Pete
KurtE
12-14-2016, 10:07 PM
Update: I think it is the Virus detector:mad: must have changed. I turned McAfee real time scanning off for 15 minutes and was able to update the two directories that failed earlier :D
PaulStoffregen
12-14-2016, 10:20 PM
Oh, yeah... I made a couple little improvements to the installer. Should speed things up on Mac and Windows. Linux was already very fast.
Markus_L811
12-16-2016, 11:59 AM
Woah really fast, damn.
