I have (2) 4m rolls of 5v WS2812B's (60/m) from Ray Wu.
One roll works great. The other roll just has one led that is lit blue somewhere in the middle of the roll and is always on when power is applied, whether the data line is hooked up or not and whether the sketch is running or not. The whole roll flashes at first when power is applied (like normal) but then just the one led remains lit. Nothing else happens. It's hooked up properly (using the arrows on the led strip) and I'm just swapping the data/gnd lines (blue/black pair) from the roll that works to the one that doesn't. Rebooted Teensy, etc. I'm using a 5v60a switching supply powering the teensy/octo as well as the strip and the gnd lines to each are tied (at the power supply).
I'm using an Octo2811 just as a level shifter with a Teensy 3.2 and only have one line hooked up (using orange pair on TOP ethernet port) and just using "DATA_PIN 2" in my sketch for the data line input. I'm not including the octo library at all and only using pure fastled, if that matters. It's just running the DemoReel100 demo.
I really don't know where to start troubleshooting this. The thing that is confusing is why it's just a single led in the middle of the strand that's lit.
I measure 5.1v going in and 4.875v coming out the other end of the 4m strip, which seems about normal with nothing except one led lit.
