imaradiostar
I poked around a bit with the audio tool and searched the forum a bit and haven't found the answer, so I'll ask.
In the SGTL5000 datasheet it states that it's possible to route the mic input to the A/D and D/A to the line output while simultaneously directly routing the stereo line in to the headphone amp. Has anyone attempted this? This would allow (in a musical instrument application) the ability to route a mono signal in and have an "insert" before the stereo headphone amplifier for external stereo effects.
If it is truly possible it opens a huge door for me!
Furthermore, the SGTL5000 datasheet seems to indicate that there is some amount of internal equalization/filtering available in hardware. Again, does one of access to this with the existing Teensy audio libraries?
Thanks!
Jamie
Thanks!
Jamie
