I would like to build a midi drum pad assembly that can be triggered with sticks like the Alesis Sample Pad Pro or a Rolland Octapad only with at least 30 and up to 42 pads, also foot pedals for hi hat, bass drum and triggering events. I have built pedals using a piezo for the bass drum and a FSR for the hi hat which work great with the Sample Pad Pro. The sample pad only has 8 pads and cannot change kits fast enough for live performance, since I'm using a DAW for all samples and instruments etc. I only need a trigger interface. Is this doable with the Tennsy and could it be used with Ableton live? If so do piezos need analog inputs or is there a way to use the digital inputs? If this is possible any help would be greatly appreciated.
