dave@huckleberrycove.ca
Hi
I have several LC's and all but the newest work perfectly. Let me call a good one LC1 and the problem unit LC2. I have read your notes on Bricked Teensy, Troble shooting... I am running teensydunio in Linux Mint. I remove my teensy from the target board for programming. When I plug it back in, it drives an LCD display, responds to a keypad and drives a stepper motor.
But I cannot reprogram LC2. I programmed it at least once and the program in it works in the target, drives the display and responds to the keypad. But I cannot update it. If i plug in LC1 to the USB, it programs and runs normally so my code, drivers, and cable must be ok. (I also tried a third unit and it programs correctly). The serial port outputs properly for LC1 and LC2. But I cannot reprogram LC2. I tried the button while connected and while I plugged the USB cable all to no avail.
Then I read about the 15 reset. I did that and it must have reset because it no longer works in the target system. But I still cannot program it. Do I have to do something special after the 15 second reset?
Or is it toast?
Dave
Or is it toast?
Dave
