I know that Teensy LC (TLC) has limited RAM and Flash.
But I plan to use it with a Wiz850io to interface a custom Analogue adapter board to the Internet.
Question is now, if the different Ethernet libraries are suited (small enough) to run on TLC?
I may need NTP, UDP, and TCP, and run a small webserver as functionality.
but normal function is to send 4 kByte/s 24/7 with TCP to the Internet.
Why TLC? it has 2 SPI (one for ADC and one for Wiz850io) and is small.
Obviously, I have no problems with changing internal hardware dependencies of existing code and 'optimizing' the size of the executable.
