Hello,
I'm trying to reuse the MotionCal tool for an IMU project using LSM9DS1 and having hard time setting it up:
1) what is the input format MotionCal expect? looking at examples, I'm formatting the stream as:
"Raw:0.67,4.44,8.42,-3.03,-7.00,-1.82,-9.25,21.15,-26.52" per line
with first 3 numbers accel data in m/s2, then Gyro in deg/s and compass in uT ; is this correct?
2) I'm using windows10, board is a TinyDuino using TinyShield 9-AXIS SENSOR BOARD. The MotionCal sees properly my com port and the default values in the GUI "flicker" when my sketch is running but I don't get any numerical values updated and the graph stays empty. does that sound like a common issue? any hint?
Thanks Much!
Thanks Much!
