brink.of.disaster
Good evening - I've been trying to find a similar problem posted, but am having trouble. I have an array of ~3k LEDs that I'm controlling with a pair of Teensy + Octows2811's. Everything is wired up and lighting well (I had previously controlled this array with an Arduino Mega and FastLED, but I'm wanting to use the movie2serial to up the complexity of patterns displayed. Also, since I was simply creating random fades and wipes, I never worried much about the specific colors being displayed).
Once everything was wired up, i started with BasicTest to make sure I had the LEDs set up correctly, and have hit a snag - I can't find the right color channel order to make it work.
(from BasicTest.ino)
I've tried altering the line:
with every permutation of "_GRB" and get the following wipe patterns:
above
Expected wipe pattern in code above: Red, Green, Blue...
_GRB = Red, Blue, Green
_GBR = Green, Blue, Red
_BGR = Blue, Red, Green
_BRG = Blue, Red, Green
_RGB = Blue, Red, Green
_RBG = Blue, Green, Red
Can you think of something I'm doing wrong? I'm new to all this, but trying to put in the time to understand the code I'm writing. I'm concerned though that the super cheap knock off LED strips I got from China are SO non-standard that they would require me to alter the octows2811 library.
Any help you can provide is VERY appreciated!
#include <OctoWS2811.h>
const int ledsPerStrip = 50;
DMAMEM int displayMemory[ledsPerStrip*6];
int drawingMemory[ledsPerStrip*6];
const int config = WS2811_GRB | WS2811_800kHz;
OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
leds.begin();
leds.show();
#define RED 0xFF0000
#define GREEN 0x00FF00
#define BLUE 0x0000FF
#define YELLOW 0xFFFF00
#define PINK 0xFF1088
#define ORANGE 0xE05800
#define WHITE 0xFFFFFF
int microsec = 2000000 / leds.numPixels(); // change them all in 2 seconds
colorWipe(RED, microsec);
colorWipe(GREEN, microsec);
colorWipe(BLUE, microsec);
colorWipe(YELLOW, microsec);
colorWipe(PINK, microsec);
colorWipe(ORANGE, microsec);
colorWipe(WHITE, microsec);
void colorWipe(int color, int wait)
for (int i=0; i < leds.numPixels(); i++) {
leds.setPixel(i, color);
leds.show();
delayMicroseconds(wait);
above
