I wrote this to learn how to use the audio library design tool and for testing my audio board. I am moving on to hooking up my display and learning how that works.
I thought I would post this code in case someone finds it interesting. That someone would probably not be a serious musician but maybe someone learning to write code and has an interest in guitar. The code is somewhat rough.
Ron
The code.... guitar_tab_player
And the header pipeline.h
Ron
Copyright (c) 2017 Ron Carr
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
// Just playing with the teensy design tool and audio library to get aquainted with the teensy.
// Possible improvements would be to parse the tab out of a text file on SD card and
// maybe use an array of pointers to the guitar strings to avoid duplicate code.
#include <SerialFlash.h>
#include "pipeline.h" // our song as a big char array
#define MIXER_GAIN 0.20
#define END_BAR -5
#define MUTE -4 // mute
#define RING -3 // ring
#define MAX_BAR 160
// some integer arrays to hold our local copy of which fret to play
int s1[MAX_BAR];
int s2[MAX_BAR];
int s3[MAX_BAR];
int s4[MAX_BAR];
int s5[MAX_BAR];
int s6[MAX_BAR];
int tab_pos;
int tempo = 50; // probably should parse this value out of the tab
// original idea was an extra A string to play the 2nd guitar part, but changed the plan
AudioSynthKarplusStrong string2; //xy=104,175
AudioSynthKarplusStrong string3; //xy=105,222
AudioSynthKarplusStrong string4; //xy=105,271
AudioSynthKarplusStrong string1; //xy=106,127
AudioSynthKarplusStrong string5; //xy=109,322
AudioSynthKarplusStrong string6; //xy=112,369
// AudioSynthKarplusStrong string7; //xy=113,420
AudioMixer4 mixer2; //xy=281,286
AudioMixer4 mixer1; //xy=282,204
AudioMixer4 mixer3; //xy=403,239 // guess could have used just two mixers
AudioOutputI2S i2s1; //xy=529,234
AudioConnection patchCord1(string2, 0, mixer1, 1);
AudioConnection patchCord2(string3, 0, mixer1, 2);
AudioConnection patchCord3(string4, 0, mixer1, 3);
AudioConnection patchCord4(string1, 0, mixer1, 0);
AudioConnection patchCord5(string5, 0, mixer2, 0);
AudioConnection patchCord6(string6, 0, mixer2, 1);
// AudioConnection patchCord7(string7, 0, mixer2, 2);
AudioConnection patchCord8(mixer2, 0, mixer3, 1);
AudioConnection patchCord9(mixer1, 0, mixer3, 0);
AudioConnection patchCord10(mixer3, 0, i2s1, 0);
AudioConnection patchCord11(mixer3, 0, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=271,49
AudioMemory(15);
sgtl5000_1.enable();
sgtl5000_1.volume(0.6);
mixer1.gain(0, MIXER_GAIN);
mixer1.gain(1, MIXER_GAIN);
mixer1.gain(2, MIXER_GAIN * 1.3);
mixer1.gain(3, MIXER_GAIN * 1.3);
mixer2.gain(0, MIXER_GAIN * 1.3);
mixer2.gain(1, MIXER_GAIN);
mixer2.gain(2, 0.0);
mixer2.gain(3, 0.0); // no connection
mixer3.gain(0, 0.5);
mixer3.gain(1, 0.5);
mixer3.gain(2, 0.0);
mixer3.gain(3, 0.0);
tab_pos = load_bar_local(0); // load initial frets information to local arrays
static int i;
float note;
if( s6[i] == END_BAR ){ // need to load more from the tab
tab_pos = load_bar_local( tab_pos );
if( tab_pos == 0 ){ // end of the song was reached
delay(5000);
tab_pos = load_bar_local( 0 ); // start song again
if( tab_pos == 0 ) while(1); // hang on error
i = 0;
note = get_note( 6, s6[i] );
if( note > 20.0 ) string6.noteOn( note, 0.9);
else if( s6[i] == MUTE ) string6.noteOff( 0.9);
note = get_note( 5, s5[i] );
if( note > 20.0 ) string5.noteOn( note, 0.9);
else if( s5[i] == MUTE ) string5.noteOff( 0.9);
note = get_note( 4, s4[i] );
if( note > 20.0 ) string4.noteOn( note, 0.9);
else if( s4[i] == MUTE ) string4.noteOff( 0.9);
note = get_note( 3, s3[i] );
if( note > 20.0 ) string3.noteOn( note, 0.9);
else if( s3[i] == MUTE ) string3.noteOff( 0.9);
note = get_note( 2, s2[i] );
if( note > 20.0 ) string2.noteOn( note, 0.9);
else if( s2[i] == MUTE ) string2.noteOff( 0.9);
note = get_note( 1, s1[i] );
if( note > 20.0 ) string1.noteOn( note, 0.9);
else if( s1[i] == MUTE ) string1.noteOff( 0.9);
delay ( tempo );
++i;
float get_note( int string, int fret ){
const float base_note[] = { 0.0, 329.63, 246.94, 196.00, 146.83, 110.00, 82.41 };
float note;
if( fret == RING || fret == MUTE ) return 0.0;
if( fret < 0 || fret > 30 ) return 0.0; // just in case an error makes it into the array
note = base_note[string];
while( fret-- ) note *= 1.059463094358; // 12th root of 2. Freq doubled on 12th fret.
// Serial.println( note );
return note;
// parse the .h char file and convert to internal integer storage
int load_bar_local( int pos ){
// our sample tab has two guitar parts. We will merge both and our player will play both
// parts at the same time on one guitar. He is very clever.
clear_bar_local();
pos= load_bar_local1(pos);
if( pos != 0 ) pos= load_bar_local1(pos); // merge 2nd part. Comment out for tab with one guitar part.
return pos;
int load_bar_local1( int pos ){
int i;
int *str;
char c, c2;
i= 0; str = &s1[0]; // assume e string is first for safety
while( (c = tab[pos++]) ){
c2 = tab[pos]; // look ahead may be needed
if( c2 == 'e' && i > 0 ) break; // normal done condition when part way through the tab
if( c == 'Z' ) break; // end of tab array character
if( i >= MAX_BAR - 3 ) break; // line is too long. Y3 - need extra place for END_BAR
// and last parsed may be a number 10-19 which takes two
// if off by one it is on the conservative side.
switch( c ){
case 'e': str = &s1[0]; i = 0; break;
case 'B': str = &s2[0]; i = 0; break;
case 'G': str = &s3[0]; i = 0; break;
case 'D': str = &s4[0]; i = 0; break;
case 'A': str = &s5[0]; i = 0; break;
case 'E': str = &s6[0]; i = 0; break;
case '|': break; // ignore these
case '-': if( str[i] == END_BAR ) str[i] = RING;
++i; break; // merge rather than overwrite
case 'x': str[i++] = MUTE; break;
case '0': str[i++] = 0; break; // get this one out of the way
case '1': // special case as it may be followed by another number for frets 10 to 19
// no code written for frets above 19
if( c2 >= '0' && c2 <= '9' ){
str[i++] = 10 + ( c2 - '0' );
str[i++] = RING; // keep the tempo correct as extra number would normally be a '-'
pos++; // skip past the 2nd number in tab file
else str[i++] = 1;
default:
if( c >= '2' && c <= '9' ) str[i++] = c - '0';
} // end case
} // end while
if( c == 'Z' && i == 0 ) return 0;
if( c == 0 ) return 0;
return pos;
void clear_bar_local(){
// put something in the arrays to show no strings are to be played
int i;
for( i = 0; i < MAX_BAR; ++i ){
s1[i] = END_BAR;
s2[i] = END_BAR;
s3[i] = END_BAR;
s4[i] = END_BAR;
s5[i] = END_BAR;
s6[i] = END_BAR;
// I marked the end of the "file" with a Z
const char tab[] = "\
e|-------------------------------------|\
B|-------------------------------------|\
G|-------------------------------------|\
D|-------------------------------------|\
A|-14--13-12-11-10-9-8-7-6-5-4-3-2-1-0-|\
E|-------------------------------------|\
e|---------------------------------|---------------------------------|\
B|---------------------------------|---------------------------------|\
G|---------------------------------|---------------------------------|\
D|---------------------------------|---------------------------------|\
A|-----2-------2-------2-------2---|-----2-------2-------2-------2---|\
E|-0-------3-------0-------3-------|-0-------3-------0-------3-------|\
e|0--------------------------------|0--------------------------------|\
B|-0-------------------------------|-0-------------------------------|\
G|--0------------------------------|--0------------------------------|\
D|---2-----------------------------|---2-----------------------------|\
A|----2----------------------------|----2----------------------------|\
E|-----0---------------------------|-----0---------------------------|\
D|---------0-------2-------0---2---|-4---2---0---2-------4-------2---|\
A|-2-------------------------------|---------------------------------|\
E|---------------------------------|---------------------------------|\
e|0--------------------------------|---------------------------------|\
B|-0-------------------------------|---------------------------------|\
G|--0------------------------------|---------------------------------|\
D|---2-----------------------------|---------------------------------|\
A|---------------------------------|---------------------------------|\
D|-4-------2-------0---2---0-------|---------------------------------|\
A|-----------------------------2---|---------------------------------|\
e|---------------------------------|---------------------7---5---3---|\
B|---------------------------------|---------5---8-------------------|\
D|---------------------------------|-----7---------------------------|\
G|---------0-------2-------0---2---|-4---2---0---2-------4-------2---|\
D|-2-------------------------------|---------------------------------|\
e|-5-------------------------------|---------------------------------|\
G|-4-------2-------0---2---0-------|---------------------------------|\
D|-----------------------------2---|---------------------------------|\
e|---------------------------------|---------5---8-------12--10--8---|\
B|---------------------------------|-----5---------------------------|\
G|-4-----4-4---4-------4---4---4---|-5-----5-5---5-------5---5---5---|\
D|-4-----4-4---4-------4---4---4---|-5-----5-5---5-------5---5---5---|\
A|-2-----2-0---2-------0---2---0---|-3-----3-0---3-------0---3---0---|\
e|-7-------------------------------|-----3---------------------------|\
B|---------------------------------|----5----------------------------|\
G|---------------------------------|---5-----------------------------|\
D|---------------------------------|--5------------------------------|\
A|---------------------------------|-3-------------------------------|\
e|-----2---------------------------|-----3---------------------------|\
B|----4----------------------------|----5----------------------------|\
G|---4-----------------------------|---5-----------------------------|\
D|--4------------------------------|--5------------------------------|\
A|-2-------------------------------|-3-------------------------------|\
G|-4-----4-4---4-------4---4---4---|-4-----4-4---4-------4---4---4---|\
D|-4-----4-4---4-------4---4---4---|-4-----4-4---4-------4---4---4---|\
A|-2-----2-0---2-------0---2---0---|-2-----2-0---2-------0---2---0---|\
e|-----2---------------------------|-----2---------------------------|\
B|----4----------------------------|----4----------------------------|\
G|---4-----------------------------|---4-----------------------------|\
D|--4------------------------------|--4------------------------------|\
A|-2-------------------------------|-2-------------------------------|\
G|---------------------------------|-2-------------------------------|\
D|-2-----2-0---2-------0---2---0---|-2-------------------------------|\
A|-0-----0-0---0-------0---0---0---|-0-------------------------------|\
e|-----0---------------------------|---------------------------------|\
B|----2----------------------------|---------------------------------|\
G|---2-----------------------------|---------------------------------|\
D|--2------------------------------|---------------------------------|\
A|-0-------------------------------|-14--131211109-8-7-6-5-4-3-2-1-0-|\
Z";
