I just got a teensy 3.5 and I'm having problems understanding whether or not I'm doing something wrong or if I'm hitting a limitation. The code I'm running on my teensy is not closed source. Once I upload it with the teensy uploader tool I cannot get the teensy's com port to show up in the application that comes with this hex file. With my old 3.1 teensy this was not a problem. Is this a limitation because I dont have the actual sketch and have to load the hex file? If I load an example file from the arduino IDE then the com port shows up fine in the IDE. Once I load the custom hex then its impossible to select the com port in the custom app. I have to select a com port in the app before it can connect. Why did the old board work while the newer 3.5 doesn't?
