cnthetford
I am very new to this, but I am trying to understand the wiring diagram at this site:
http://sishchess.blogspot.com/p/building-sish-board-tutorial.html
Most of the tutorials I've read connect a to power, through a resistor to a pin and the button then to ground. It looks like the circuits here would simply pass from one pin to another with power or ground. How does this work? Would you simply write to one pin and read another to see if the message was received to see if the button is pushed? If that was the case, I guess you would continuously write to one bank of pins (the letters for example) and read the other bank and based on which message is delivered and where it is received then you would no which button in the matrix was pushed.
