Forum bug
Welocs
hi there,
it is sad, that you cannot search for words with two charakters in this forum, so threads for SD card apllications might be hard to find, cause user may only use the letters "SD" without using the word "card" so u may not find many discussions about this.
Also the site prints out a php-error when searching for words shorter than three charakters, which maybe should be disabled:
Warning: Declaration of vBForum_Item_SocialGroupMessage::getLoadQuery() should be compatible with that of vB_Model::getLoadQuery() in ..../packages/vbforum/search/result/socialgroupmessage.php on line 24
Warning: Declaration of vBForum_Item_SocialGroupDiscussion::getLoadQuery() should be compatible with that of vB_Model::getLoadQuery() in ..../packages/vbforum/search/result/socialgroupdiscussion.php on line 24
greetings,
Welocs
