Teensy LC, Logic Pro X help
bobo
I've recently built a simple midi controller that I want to use in Logic X, but I'm having some problems. If I use the controller in Ableton, it seems to work fine, but as soon as I try to use it in Logic, it registers briefly on the midi input in Logic, but then disconnects. If I then go back to Ableton it's still disconnected. Once I unplug and plug in again it works as normal in Ableton, but I get the same issue in Logic. I've put the code I've used below. Sorry if there's some glaringly obvious mistake in there, very new to this! Quite the learning curve.
If anyone could offer any help it would be massively appreciated.
Thanks!
/* Buttons to USB MIDI Example
You must select MIDI from the "Tools > USB Type" menu
To view the raw MIDI data on Linux: aseqdump -p "Teensy MIDI"
#include <Bounce.h>
// the MIDI channel number to send messages
const int channel = 1;
// Create Bounce objects for each button. The Bounce object
// automatically deals with contact chatter or "bounce", and
// it makes detecting changes very simple.
Bounce button0 = Bounce(0, 5);
Bounce button1 = Bounce(1, 5); // 5 = 5 ms debounce time
Bounce button2 = Bounce(2, 5); // which is appropriate for good
Bounce button3 = Bounce(3, 5); // quality mechanical pushbuttons
Bounce button4 = Bounce(4, 5);
Bounce button5 = Bounce(5, 5); // if a button is too "sensitive"
Bounce button6 = Bounce(6, 5); // to rapid touch, you can
Bounce button7 = Bounce(7, 5); // increase this time.
Bounce button8 = Bounce(8, 5);
Bounce button9 = Bounce(9, 5);
Bounce button10 = Bounce(10, 5);
Bounce button11 = Bounce(11, 5);
// Configure the pins for input mode with pullup resistors.
// The pushbuttons connect from each pin to ground. When
// the button is pressed, the pin reads LOW because the button
// shorts it to ground. When released, the pin reads HIGH
// because the pullup resistor connects to +5 volts inside
// the chip. LOW for "on", and HIGH for "off" may seem
// backwards, but using the on-chip pullup resistors is very
// convenient. The scheme is called "active low", and it's
// very commonly used in electronics... so much that the chip
// has built-in pullup resistors!
pinMode(0, INPUT_PULLUP);
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP); // Teensy++ 2.0 LED, may need 1k resistor pullup
pinMode(7, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
pinMode(10, INPUT_PULLUP);
pinMode(11, INPUT_PULLUP); // Teensy 2.0 LED, may need 1k resistor pullup
// Update all the buttons. There should not be any long
// delays in loop(), so this runs repetitively at a rate
// faster than the buttons could be pressed and released.
button0.update();
button1.update();
button2.update();
button3.update();
button4.update();
button5.update();
button6.update();
button7.update();
button8.update();
button9.update();
button10.update();
button11.update();
// Check each button for "falling" edge.
// Send a MIDI Note On message when each button presses
// Update the Joystick buttons only upon changes.
// falling = high (not pressed - voltage from pullup resistor)
// to low (pressed - button connects pin to ground)
if (button0.fallingEdge()) {
usbMIDI.sendNoteOn(60, 99, channel); // 60 = C4
if (button1.fallingEdge()) {
usbMIDI.sendNoteOn(61, 99, channel); // 61 = C#4
if (button2.fallingEdge()) {
usbMIDI.sendNoteOn(62, 99, channel); // 62 = D4
if (button3.fallingEdge()) {
usbMIDI.sendNoteOn(63, 99, channel); // 63 = D#4
if (button4.fallingEdge()) {
usbMIDI.sendNoteOn(64, 99, channel); // 64 = E4
if (button5.fallingEdge()) {
usbMIDI.sendNoteOn(65, 99, channel); // 65 = F4
if (button6.fallingEdge()) {
usbMIDI.sendNoteOn(66, 99, channel); // 66 = F#4
if (button7.fallingEdge()) {
usbMIDI.sendNoteOn(67, 99, channel); // 67 = G4
if (button8.fallingEdge()) {
usbMIDI.sendNoteOn(68, 99, channel); // 68 = G#4
if (button9.fallingEdge()) {
usbMIDI.sendNoteOn(69, 99, channel); // 69 = A5
if (button10.fallingEdge()) {
usbMIDI.sendNoteOn(70, 99, channel); // 70 = A#5
if (button11.fallingEdge()) {
usbMIDI.sendNoteOn(71, 99, channel); // 71 = B5
// Check each button for "rising" edge
// Send a MIDI Note Off message when each button releases
// For many types of projects, you only care when the button
// is pressed and the release isn't needed.
// rising = low (pressed - button connects pin to ground)
// to high (not pressed - voltage from pullup resistor)
if (button0.risingEdge()) {
usbMIDI.sendNoteOff(60, 0, channel); // 60 = C4
if (button1.risingEdge()) {
usbMIDI.sendNoteOff(61, 0, channel); // 61 = C#4
if (button2.risingEdge()) {
usbMIDI.sendNoteOff(62, 0, channel); // 62 = D4
if (button3.risingEdge()) {
usbMIDI.sendNoteOff(63, 0, channel); // 63 = D#4
if (button4.risingEdge()) {
usbMIDI.sendNoteOff(64, 0, channel); // 64 = E4
if (button5.risingEdge()) {
usbMIDI.sendNoteOff(65, 0, channel); // 65 = F4
if (button6.risingEdge()) {
usbMIDI.sendNoteOff(66, 0, channel); // 66 = F#4
if (button7.risingEdge()) {
usbMIDI.sendNoteOff(67, 0, channel); // 67 = G4
if (button8.risingEdge()) {
usbMIDI.sendNoteOff(68, 0, channel); // 68 = G#4
if (button9.risingEdge()) {
usbMIDI.sendNoteOff(69, 0, channel); // 69 = A5
if (button10.risingEdge()) {
usbMIDI.sendNoteOff(70, 0, channel); // 70 = A#5
if (button11.risingEdge()) {
usbMIDI.sendNoteOff(71, 0, channel); // 71 = B5
I figured this out if anyone has the same problem, well didn't figure it out, but wrote out the code again and it's working now. Code is below for 8 potentiometers and 6 buttons.
#include <Bounce.h>
// define how many pots are active up to number of available analog inputs
#define analogInputs 8
// make arrays for input values and lagged input values
int inputAnalog[analogInputs];
int iAlag[analogInputs];
// make array of cc values
int ccValue[analogInputs];
// index variable for loop
int i;
// cc values for buttons
int cc_off = 0;
int cc_on = 65;
int cc_super = 127;
// map buttons to cc for button
int cc0 = 51;
int cc1 = 52;
int cc2 = 53;
int cc3 = 54;
int cc4 = 55;
int cc5 = 56;
Bounce button0 = Bounce(0, 3);
Bounce button1 = Bounce(1, 3);
Bounce button2 = Bounce(2, 3);
Bounce button3 = Bounce(3, 3);
Bounce button4 = Bounce(4, 3);
Bounce button5 = Bounce(5, 3);
  // MIDI rate
  Serial.begin(31250);
  // loop trough active inputs for knobs
  for (i=0;i<analogInputs;i++){
    // read current value at i-th input
    inputAnalog[i] = analogRead(i);
    // if magnitude of difference is 8 or more...
    if (abs(inputAnalog[i] - iAlag[i]) > 7){
      // calc the CC value based on the raw value
      ccValue[i] = inputAnalog[i]/8;
      // send the MIDI
      usbMIDI.sendControlChange(i, ccValue[i], 3);
      // set raw reading to lagged array for next comparison
      iAlag[i] = inputAnalog[i];
  delay(5); // limits MIDI messages to reasonable number
  // Push Button code
  button0.update();
  button1.update();
  button2.update();
  button3.update();
  button4.update();
  button5.update();
    usbMIDI.sendControlChange(cc0, cc_on, 3);
    usbMIDI.sendControlChange(cc1, cc_on, 3);
    usbMIDI.sendControlChange(cc2, cc_on, 3);
    usbMIDI.sendControlChange(cc3, cc_on, 3);
    usbMIDI.sendControlChange(cc4, cc_on, 3);
    usbMIDI.sendControlChange(cc5, cc_on, 3);
    usbMIDI.sendControlChange(cc0, cc_off, 3);
    usbMIDI.sendControlChange(cc1, cc_off, 3);
    usbMIDI.sendControlChange(cc2, cc_off, 3);
    usbMIDI.sendControlChange(cc3, cc_off, 3);
    usbMIDI.sendControlChange(cc4, cc_off, 3);
  }if (button5.risingEdge())
    usbMIDI.sendControlChange(cc5, cc_off, 3);
    // MIDI Controllers should discard incoming MIDI messages.
  while (usbMIDI.read()) {
