stylefungus
I am connecting an NS-RS232-01 TTL Serial board to the Teensy LC.
RS-232 signal works fine with Hyper Terminal sending data so long as I connect USB to my PC. If I use an external Power supply such as a phone charger (tried 5 different ones) the Teensy program works (led blinking appropriately) but no more rs-232 data. This is a Teensy LC board. I tried different grounds and things. Checked the white ground wire for continuity etc... I am thinking it has something to do with a common ground but I am not sure.
Thank you all in advance
www.scaleprogrammers.com
