thefirebrandforge
So without a doubt I would like to come up with a 'shield' to allow this, unless someone else does.
My main interest is extending the prop shield to allow at least 120 LED, APA102/WS2812 strip to be used. Which means about 5A current output. But It should work as a stand alone extension that provides 5V and portability with lipo/li-ion batteries as well.
There's 2 ideas I've been playing with. One is to simply use a battery charger IC, and a boost converter IC capable of at least 5A output at 5V.
The other is to allow additional boost modules to be stack-able by setting the boost converter output to about 5.5V, which is then connected to a rectifier diode with a voltage drop of .5. We should be able to connect the output of the rectifier diodes together. So in theory additional boards can be stacked on (with additional Lipo/Li-ion batteries) each would allow an additional 120 LEDs to be used. However this stack-able approach results in a straight loss of efficiency for those who only want to use ~120 LED's with no benefits. Would that even matter? Which seems more appealing?
