Hello Everyone,
I am trying to communicate serially with the PC at 460800 bauds, in order to do it, I am connecting a FTDI circuit, and I am using the flow control signals CTS and RTS. I'm able to read and write using this setup at 460800 bauds, however when I try to communicate using the I2C using the <i2c_t3.h> library, linked to Wire1 PIN 29 AND 30, at the same time, it stops working, I mean by stop working that it allow me to upload the firmware, but does not send anything through the hardware serial.
Is it possible to use the Serial1 hardware port, and at the same time use the Wire1 communication port?
Is there any reused part of the circuit and this is making not possible?
Thanks for your support or ideas,
