Hello!
I want to power a teensy 3.5 with a variable voltage of about 6-8.2V but i read that the "Vin" pin has to be "3.6 to 6.0 volts" (from the little piece of page -brochure- i had with the board when i bought them).
So, by reading this i can't do that. That what makes me use an extra 7805, which i don't want to.
Next, by following the schematics i can see that the LDO is a LP38691.
From the manual it seems that this LDO's input is "Wide Input Voltage Range (2.7 V to 10 V" and if i read the absolute maxing rating can be up to 12V.
So, what is the correct one?
Thank you in advance!!!
