I tried to connect 2 Lora Bee (868MHz) to 2 Teensy 3.5. I run the master/client example and it worked as long as both devices (Teensy+Lora) are connected to my computer via USB (running both in separate terminals). However, my goal is to disconnect one device from my computer, run it autonomously from battery and send sensor data to the other one. But this is not working at the moment. As soon as I power one Teensy+Lora from battery (or USB external power supply) no data are transmitted. My guess is that this has something to do with interrupts. Sorry for my stupid question - but what do I need to change in the code that I can plug off the USB cable?
I run the "standard" RadioHead-Library example, adopting to "my" pins:
Client:
server:
thanks a lot
Client:
#include <RH_RF95.h>
RH_RF95 rf95(15,14);
pinMode(24, OUTPUT);
digitalWrite(24, HIGH);
digitalWrite(24, LOW);
delay(10);
delay(10);
while (!Serial) ; // Wait for serial port to be available
if (!rf95.init())
Serial.println("init failed");
// rf95.setTxPower(5, true);
rf95.setFrequency(868.0);
Serial.println("Sending to rf95_server");
// Send a message to rf95_server
uint8_t data[] = "Hello World!";
rf95.send(data, sizeof(data));
rf95.waitPacketSent();
// Now wait for a reply
uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);
if (rf95.waitAvailableTimeout(3000))
// Should be a reply message for us now
if (rf95.recv(buf, &len))
Serial.print("got reply: ");
Serial.println((char*)buf);
// Serial.print("RSSI: ");
// Serial.println(rf95.lastRssi(), DEC);
Serial.println("recv failed");
Serial.println("No reply, is rf95_server running?");
delay(400);
server:
int led = 9;
delay(10);
delay(10);
pinMode(led, OUTPUT);
if (!rf95.init())
if (rf95.available())
// Should be a message for us now
digitalWrite(led, HIGH);
// RH_RF95::printBuffer("request: ", buf, len);
Serial.print("got request: ");
// Send a reply
uint8_t data[] = "And hello back to you";
Serial.println("Sent a reply");
digitalWrite(led, LOW);
delay(1);
thanks a lot
