View Full Version : Teensyduino 1.38 Released
Paul
08-28-2017, 12:53 PM
Teensyduino 1.38 has been released.
These changes were made after the last beta (https://forum.pjrc.com/threads/46011-Teensyduino-1-38-Beta-4):
Symbol table and disassembly listing are placed in temp build folder
Fix audio memory usage stats when more than 255 blocks allocated
Fix USB audio transmit with null data
Audio library support for external delay with CY15B104 (FrankB)
I'm having trouble with the Raspberry Pi used to build for Linux ARM. Looking for Raspberry Pi feedback (https://forum.pjrc.com/threads/46069-Raspberry-Pi-Hardware)...
mnstri
08-28-2017, 06:06 PM
A customer (I'm a Teensy reseller) reported this error with Teensyduino 1.38 and Arduino 1.8.4 when trying to upload the Blink example to a Teensy LC https://pastebin.com/6xL8meDC
Tried it myself and got the same error.
tni
08-28-2017, 06:28 PM
It looks like this commit is responsible:
https://github.com/PaulStoffregen/cores/commit/632f311db1b60a5b6a89f2d9c1dee782e2747e71
Since Teensy LC has a shared interrupt for the PIT channels, it should probably be wrapped in a '#ifdef KINETISK'.
PaulStoffregen
08-28-2017, 07:30 PM
Opps, that's embarrassing! Looks like 1.39 might be coming later today....
TomM
08-28-2017, 11:45 PM
Having the same issues with Teensyduino 1.38 but with Arduino 1.8.1 and 1.8.3.
KurtE
08-29-2017, 03:37 PM
@Paul - I have been running into some interesting types of errors, not sure if related to latest Arduino or latest Teensyduino...
That is sometimes when I do a build (not sure if only verify or also with upload).
The build will complete, but then fail at the end like:
Arduino: 1.8.4 (Windows 10), TD: 1.38, Board: "Teensy 3.6, Serial, 180 MHz, Faster, US English"
d:\arduino-1.8.4\hardware\tools\arm\bin\../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ar.exe: unable to rename 'C:\Users\kurte\AppData\Local\Temp\arduino_build_2 29766/core/core.a'; reason: File exists
Multiple libraries were found for "USBHost_t36.h"
Used: C:\Users\kurte\Documents\Arduino\libraries\USBHost _t36
Not used: D:\arduino-1.8.4\hardware\teensy\avr\libraries\USBHost_t36
Using library USBHost_t36 at version 0.1 in folder: C:\Users\kurte\Documents\Arduino\libraries\USBHost _t36
Error compiling for board Teensy 3.6.
And if I try to build again, it gets even stranger errors:
"D:\arduino-1.8.4\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1503989929 "-TD:\arduino-1.8.4\hardware\teensy\avr\cores\teensy3/mk66fx1m0.ld" -lstdc++ -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766/xxx.ino.elf" "C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766\sketch\xxx.ino.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766\libraries\USBHost_t36\ehci.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766\libraries\USBHost_t36\enumeration.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766\libraries\USBHost_t36\hub.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766\libraries\USBHost_t36\keyboard.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766\libraries\USBHost_t36\memory.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766\libraries\USBHost_t36\midi.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766\libraries\USBHost_t36\mouse.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766\libraries\USBHost_t36\print.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766/core\core.a" "-LC:\Users\kurte\AppData\Local\Temp\arduino_build_2 29766" -larm_cortexM4lf_math -lm
C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766\libraries\USBHost_t36\ehci.cpp.o: In function `usb_serial_class::write(unsigned char const*, unsigned int)':
D:\arduino-1.8.4\hardware\teensy\avr\cores\teensy3/usb_serial.h:95: undefined reference to `usb_serial_write'
C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766\libraries\USBHost_t36\ehci.cpp.o: In function `Print::print(unsigned long)':
D:\arduino-1.8.4\hardware\teensy\avr\cores\teensy3/Print.h:68: undefined reference to `Print::printNumber(unsigned long, unsigned char, unsigned char)'
C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766\libraries\USBHost_t36\ehci.cpp.o: In function `Print::print(unsigned long, int)':
D:\arduino-1.8.4\hardware\teensy\avr\cores\teensy3/Print.h:74: undefined reference to `Print::printNumber(unsigned long, unsigned char, unsigned char)'
D:\arduino-1.8.4\hardware\teensy\avr\cores\teensy3/Print.h:70: undefined reference to `Print::printNumber(unsigned long, unsigned char, unsigned char)'
C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766\libraries\USBHost_t36\print.cpp.o: In function `usb_serial_class::write(unsigned char)':
D:\arduino-1.8.4\hardware\teensy\avr\cores\teensy3/usb_serial.h:94: undefined reference to `usb_serial_putchar'
C:\Users\kurte\AppData\Local\Temp\arduino_build_22 9766\libraries\USBHost_t36\print.cpp.o: In function `USBHost::print_hexbytes(void const*, unsigned long)':
C:\Users\kurte\Documents\Arduino\libraries\USBHost _t36/print.cpp:184: undefined reference to `Serial'
C:\Users\kurte\Documents\Arduino\libraries\USBHost _t36/print.cpp:184: undefined reference to `Print::println()'
Note: there were lots and lots of the same errors.... Edited down so not so big!
I exited Arduino IDE, cleaned out the temp folder of Arduino build and cache... Tried again and it failed like first one... File existed...
So I then reran the install for the last Beta install and then tried building code again and it worked... Will try reinstalling latest released again (tried this yesterday and it worked).
But maybe it was also due to using the integration of TyCommander...
Frank B
08-29-2017, 07:43 PM
Is this the right one ? ;-)
KurtE
08-29-2017, 07:45 PM
Yep,
That is the version I am currently editing to handle Mice better. It is grabbing the HID descriptor data, parsing it to know where fields are and their sizes... And now starting to use that information.
Still WIP - https://github.com/KurtE/USBHost_t36/tree/Mouse-Rabbit-Hole
Po Ting
08-31-2017, 04:35 PM
Hello, i found that
the DMASPI library doesn't compile well with newer arduino/teensy loader , with T3.5/3.6 and I guessevery setting.
the library was from
https://github.com/crteensy/DmaSpi
i tried 1.81/1.82/1.83/1.84 with 1.37/1.38 teensyloader
the empty sketch with "#include <DmaSpi.h>"
gets error like below
In file included from C:\Users\PoTing\Documents\Arduino\sketch_aug31a\sk etch_aug31a.ino:1:0:
G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:575:48: error: 'SPI1Class' was not declared in this scope
class DmaSpi1 : public AbstractDmaSpi<DmaSpi1, SPI1Class, SPI1>
G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:575:63: error: template argument 2 is invalid
G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:575:63: note: invalid template non-type parameter
G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h: In static member function 'static void DmaSpi1::begin_setup_txChannel_impl()':
G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:580:16: error: 'txChannel_' was not declared in this scope
txChannel_()->disable();
G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h: In static member function 'static void DmaSpi1::begin_setup_rxChannel_impl()':
G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:588:16: error: 'rxChannel_' was not declared in this scope
rxChannel_()->disable();
G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:592:35: error: 'rxIsr_' was not declared in this scope
rxChannel_()->attachInterrupt(rxIsr_);
G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h: In static member function 'static void DmaSpi1::post_cs_impl()':
G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:604:16: error: 'rxChannel_' was not declared in this scope
rxChannel_()->enable();
G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:605:16: error: 'txChannel_' was not declared in this scope
txChannel_()->enable();
my last success of using the DMASPI library is with Arduino1.80 and Teensy 1.34
KurtE
08-31-2017, 05:05 PM
Yes - With the last few releases of Teensyduino, the SPI class is one class with multiple instances instead of different classes.
I had it working a long time on my machine and forgot to push a Pull request...
https://github.com/crteensy/DmaSpi/pull/23
Note: What I had on my machine had a second example which is copy of first but set for SPI1... Not necessary. but...
You can see the version with changes up at: https://github.com/kurte/DmaSpi/tree/SPI-One-Class
