TelephoneBill
I have just bought a new Teensy 3.6. I soldered pins to it. I plugged this into my Win7 desktop. The OS recognised a new device. It claimed to have installed a driver and BLINKY began to flash the on-board LED. OK so far.
I then attempted to find the board with Arduino 1.8.4 and Teensyduino 1.39. I changed the "board" to "Teensy 3.6" and searched for the "port" - but I could not find it in the list.
I closed Arduino IDE and looked under "Control Panel"/"Device Manager" to see if there was a new COM under "PORTS (COM & LPT)" - but it was not there.
If I unplugged the USB 2.0 cable connected to the board, I heard the the familiar "Hi-Lo" sound from the speakers, indicating a USB device removal. If I plugged the USB 2.0 cable into the desktop socket again, I got the familiar "Lo-Hi" sound to indicate a new USB device attached.
I connected a (previously used) Teensy 3.1 board via the same cable, and this was recognised OK both within "Arduino" and "Device Manager". I tried an older Teensy 3.6 with the same cable - and this one worked OK under "Device Manager" (as COM10).
I then tried connecting the Teensy 3.6 to another (different) Win7 desktop. Same thing happens. After driver install, the Teensy 3.6 gives the "Lo-Hi" sound when plugged in (USB connected), but fails to show in either "Device Manager" or "Arduino IDE". But another (different) Teensy 3.1 works OK. on this alternative desktop.
Any suggestions? (The Teensy's that do work OK were installed under a previous version of Arduino IDE and Teensyduino).
