davestephans
I didn't see where this was asked before, so forgive me if it has been.
I have a Teensy3.1, and I see it has 24 I/O pins. I need 23 I/O pins as outputs to represent a 23 bit BCD code, and also need to receive serial ASCII characters. I know I can use a breakout board, but I am trying to do it with the native 28 pins that are soldered already.
Can I use the Pin 0 Rx1 to receive the data, and then use Pin 1 as an output for another purpose...? Or will using the serial port mess up using TX1 pin 1 as just a regular output.
And if so, do I need to change something in my code to block it from trying to transmit on that pin...?
I absolutely love the Teensy 3.1....amazing chip for sure..!!
Thanks so much for your help!!
