laughingrice
I have this weird behavior when working with TeensyDelay to trigger a digitalWriteFast on a teensy 3.1 board (digitalWriteFast is a small library to use the FTM clock as a single shot timer)
With the following code, all interrupts are called (a and b variables are continuously updated and remain in sync), but the digitalWriteFast function is only called on the first iteration (led blinks once and stays off). If I remove the first = !first; line from timer() then everything works fine (but timer won't run for the 50ms I need, only 40ms, for some reason, beyond that it aliases down)
Timer() is a timer interrupt function that reschedules itself every 40ms in this case and should call SignalUp every second iterations in send a rising edge, and that in turn schedules SignalDown for the falling edge
Any ideas?
Thanks
Any ideas?
Thanks
#include <TeensyDelay.h>
volatile int a = 0;
volatile int b = 0;
void Timer() {
static bool first = true;
TeensyDelay::trigger(40000, 0);
if (first)
TeensyDelay::trigger(1000, 1);
first = !first;
void SignalUp() {
digitalWriteFast(LED_BUILTIN, HIGH);
TeensyDelay::trigger(5000, 2);
a++;
void SignalDown() {
digitalWriteFast(LED_BUILTIN, LOW);
b++;
pinMode(LED_BUILTIN, OUTPUT);
TeensyDelay::begin();
TeensyDelay::addDelayChannel(Timer, 0);
TeensyDelay::addDelayChannel(SignalUp, 1);
TeensyDelay::addDelayChannel(SignalDown, 2);
Timer();
Serial.print(a);
Serial.print(" ");
Serial.println(b);
